Reading: Practical Level Sensors Questions and Answers
Inst Tools > Blog > Level Measurement > Practical Level Sensors Questions and Answers
Learn the top 4 real-time practical questions and answers on level measuring sensors and transmitters on instrumentation blog.
Last updated: January 27, 2021 11:12 am
Level Measurement Practical Questions
Level Sensors Question 1
A person is floating in a swimming pool on an inflatable plastic cushion, holding a cup of drinking water.
Level Sensors Question 1AnswerLevel Sensors Question 2AnswerLevel Sensors Question 3AnswerLevel Sensors Question 4Answer
If this person accidently dumps their drinking water into the pool, does the water level in the pool increase, decrease, or stay the same? Explain why.
Answer
The level in the pool remains the same, because the water displaced by the inflatable cushion is the amount of water equal in weight to the cushion plus the person plus the cup plus the water in the cup.
Spilling that cup-worth of water in the pool lightens the weight on the cushion which makes it displace less water, but this reduced displacement is precisely equal to the amount of water spilled into the pool.
Therefore, there will be no change whatsoever in the pool’s level.
If an ultrasonic level instrument is used to measure the level of nitric acid in a vessel, and the density of that acid increases over time due to increased concentration, how will the instrument respond?
Will it register an increased acid level, a decreased acid level, or will its indication remain the same as before? Explain your answer.
Answer
There will be no change in instrument indication resulting from a density change of the acid.
Only the vapor density above the liquid affects the speed of sound, which is the primary non-level variable affecting level measurement.
A person is floating in a swimming pool on an inflatable plastic cushion, holding a bowling ball.
If this person accidently dumps the bowling ball into the pool, does the water level in the pool increase, decrease, or stay the same? Explain why.
Answer
The level in the pool will decrease, because the water displaced by the inflatable cushion is the amount of water equal in weight to the cushion plus the person plus the bowling ball.
Dropping the bowling ball into the pool lightens the weight on the cushion which makes it displace less water.
The bowling ball will only displace as much water as its volume, which is less water than what it weighs.
Therefore, the total amount of displaced water will decrease and the pool’s level will correspondingly decrease.
If a tape-and-float level instrument is used to measure the level of alcohol in a vessel, and the density of that alcohol suddenly decreases, how will the instrument respond?
Will it register an increased alcohol level, a decreased alcohol level, or will its indication remain the same as before? Explain your answer.
Answer
There will be no change in instrument indication resulting from a density change of the alcohol, so long as the liquid remains denser than the float.
The buoyancy of the float will be slightly affected by the liquid’s density, but not much.
Share your answers & explanation with us through the below comments section.
  • Liquid Level Sensors Symbols
  • Level Gauge Interface Problem
  • Tank Design and Accuracy
  • Sump Tank Level Transmitter
  • Guided Wave Radar Level Sensor
Credits: Tony R. Kuphaldt
Float Level Measurement
Capacitance Level Sensor Principle, Limitations, Installation & Calibration
Indentify Faults in Simple Lamp Circuit including Failed Wires
Radar Level Transmitter in Briddle level Measurement
Transmitter Calibration Range of a Vessel Level
What are Mechanical Level Indicators? – Classification & Principle
Current-to-Pressure Transducer Calibration Table
Manual Level Measurement
Contact Type Guided Wave Radar Level Transmitter Working Principle
Drum Level Compensation and Range Calculation of DP Transmitter
As per Process Conditions, Find out the Circuit Components Status ?
Float Type Level Indicator Principle
Rotary Level Switch Working principle Animation
DP Level Transmitters Compensation Techniques
Calculate Hydraulic Pressure of a Drum
Calculate Hydraulic Pressure of a Process Vessel
Chemical Seal Pressure Transmitter
What is the Purpose of Chemical Seals Pressure Transmitter?
How a Level Switch Works
Questions on Level Switches
Submersible Pressure Transmitter
What is a Submersible Pressure Transmitter? Principle, Advantages
Span of Pressure Gauge
How to Decrease Span of Pressure Gauge?
DP transmitter Errors
DP Transmitter Calibration Errors
DP Transmitters Level Measurement Principle
DP Transmitters Level Measurement Principle Video
Heat Exchanger Differential Pressure Transmitter
Measurement of Voltage Objective Questions
PLC ON DELAY TIMER FUNCTION
#6 PLC Best Practices – Validate Timers and Counters
Guide to vibration severity per ISO 10816
Importance of Vibration Measurement
Use of Temperature Transmitters instead of Direct Wiring
Static and Dynamic Characteristics of an Instrument
Temperature Measurement Questions
Interview Questions on Temperature Measurement
Calculate Power in Parallel RL Circuit
