Reading: PLC Program for Alarm Security System
Inst Tools > Blog > PLC Tutorials > PLC Program for Alarm Security System
This is the PLC Program for Alarm Security Systems. Learn the PLC programming with this example problem.
Last updated: November 3, 2023 11:58 am
Alarm Security SystemProblem DiagramProblem SolutionList of Inputs and OutputsPLC Ladder Diagram for Alarm Security SystemProgram DescriptionResult
Problem Description
Make burglar alarm system program in S7-1200 PLC for the house.
Consider one house, in this we want to arrange automatic burglar alarm security system. Alarm should be ON when any person will be detected by the motion sensor.
Problem Diagram
PLC Program for Burglar Alarm Security System
Problem Solution
We can solve this problem by using simple logic. Here we can use two sensors, one motion sensor and second window sensor. Window sensor is the loop of wires.
The motion sensor is designed such that when person is detected in a house or room, then the sensor will be activated (change its state to 1 or true)
Here important point in window sensor is that current is always passing until the breakage occurs in the glass. Hence output always true and when someone will try to break the window glass, current will not flow in the circuit.
Inputs List
  • System START :- I0.0
  • System STOP :- I0.1
  • Motion detector :- I0.2
  • Window sensor :- I0.3
  • Alarm stop button :- I0.4
Outputs List
  • Alarm :- Q0.0
M Memory
  • M0.0 :- Master coil.
  • M0.1 :- Alarm on condition.
PLC Logic for Alarm Security Systems
PLC Alarm System
PLC Burglar System
Program Description
In this problem we will consider S7-1200 PLC and TIA portal software for programming.
Network 1:
This network shows simple latching circuit for system ON and system OFF.
we used Normally Open (NO) contact of system START button (I0.0) and NC contact of system STOP button (I0.1) for system activation.
Network 2:
When system is activate and motion sensor (I0.2) detects the person entry, alarm on (M0.1) condition will be ON and it will activate the alarm (Q0.0).
Normally NC contact of window sensor (I0.3) is used in parallel so in normal condition it is true. If breakage of glass or window condition is detected, window sensor (I0.3) input goes false and it will activate the alarm condition (M0.1).
Network 3:
In this network latching circuit is used for alarm (Q0.0). If alarm condition is detected (M0.1), alarm will be ON and it can be stopped by pressing alarm STOP PB (I0.4).
Note :- Above logic is for explanation purpose only. We can implement this example by using hard wired relay logic also. S7-1200 PLC system is so costly for this simple system.
Result
PLC based Security System
Author: Bhavesh
  • PLC Program for Motor Starter
  • Analog Input Sampling in PLC
  • Positive Edge Output for One Cycle
  • Automatic Liquid Mixing Application
  • PLC Program START & STOP Buttons
Will PLCs become obsolete?
How to Read an Electrical Wiring Diagram?
How to Backup and Restore from Simatic Prosave HMI?
Free Industrial Control System (ICS) Cyber Security Training Course
Step-by-Step Guide to Choose Right Fuse for a Panel
Proper Earthing Practices Used for PLC Control Panel
Structured Text PLC Programming for Automatic Gate Control
Difference between PLC and Computers
Siemens Tia Portal Function Block
Function Blocks in PLC (FBs) – What You Need To Know?
Count the Number of Bottles
Count the Number of Bottles in Packaging Carton PLC Logic
High-Speed and Fast Counters in PLC
What are High-Speed Counters and Fast Counters in PLC?
Liquid Tank Filling and Emptying PLC System
Auto and Manual Liquid Tank System: PLC Program Example
PLC Digital Inputs
PLC Digital Input and Digital Output Modules
PLC ON DELAY TIMER FUNCTION
#6 PLC Best Practices – Validate Timers and Counters
SCADA Interview Questions
Different PLC available in the Simatic S7 generation
Overview of SIEMENS PLC – S7-1500, S7-1200, S7-400, S7-300
What is Zero Trust Security
How a Single ZTNA Solution Can Help Overcome Cybersecurity Issues?
Pressure Sensor Specifications
Cycloconverters Objective Questions
Loop Current Step Response (LCSR) Test for RTD
Response Time Test of RTD and Thermocouple
Logic Gates Symbols & Truthtables
Logic Gates Animation
Advanced PLC Programming Training Course
de-energized-to-safe-mode
