Reading: 80+ PLC MCQ Questions
Inst Tools > Blog > Control Systems MCQ > 80+ PLC MCQ Questions
Prepare for exams with our collection of 80+ PLC MCQ questions covering programmable logic controllers, and automation concepts.
Last updated: July 29, 2024 12:26 pm
Control Systems MCQ Instrumentation MCQ PLC Tutorials
26 Min Read
PLC MCQ QuestionsWhat does PLC stand for?Which language is commonly used for PLC programming?What is the primary function of a PLC?What does the term “ladder” in ladder logic refer to?What does the abbreviation SCADA stand for in relation to PLC systems?Which component of a PLC executes the control program?What kind of memory is typically used to store a PLC’s program in latest models?What is the role of I/O modules in a PLC system?Which of the following is NOT a typical application of PLCs?What type of signal does a PLC digital input module process?Which PLC feature allows it to continue operating despite minor faults?Which of the following is a common communication protocol used by PLCs?What is the purpose of a PLC’s HMI (Human-Machine Interface)?What does the term “scan time” refer to in a PLC?What is ladder logic primarily based on?Which of these is NOT an advantage of using PLCs when compared to traditional electrical circuits?In a PLC analog control loop, what is an actuator typically responsible for?What is the primary benefit of using a PLC over traditional relay control systems?How are analog signals processed by a PLC?Which type of PLC memory is volatile and loses data when power is off?What does the term “hot-swapping” refer to in PLC systems?Which PLC component is responsible for interfacing with sensors and actuators?What is the role of a watchdog timer in a PLC?Which of the following is an example of a discrete input device for a PLC?In PLC terminology, what is a “bit” commonly referred to as?What type of signal is typically managed by an analog input module in a PLC?Which PLC feature allows it to communicate with other PLCs and devices?In a PLC, what is the function of a “timer“?What is the main purpose of using sensors with PLCs?What does “modular PLC” mean?Learning PLC BasicsWhat is a common characteristic of PLCs used in safety-critical applications?Which of the following is an advantage of using modular PLCs?What is the function of an Analog-to-Digital Converter (ADC) in a PLC?What type of PLC is typically used for small-scale applications?What does “real-time processing” mean in the PLC?What is the main use of a PLC’s relay output module?What is a characteristic feature of programmable logic controllers?What does the “scan rate” of a PLC refer to?Which of the following is a type of discrete output device controlled by a PLC?What does “I/O” stand for in the PLCs?What kind of tasks are PLCs specifically designed to handle?How is a PLC different from a general-purpose computer?What is the function of an EEPROM in a PLC?In PLC terminology, what is a “rung”?What is a key advantage of using ladder logic for PLC programming?What does “HMI” stand for in the PLC systems?What is the purpose of the power supply module in a PLC system?What is the function of a PLC’s communication protocol?Which type of PLC is typically used for applications requiring high processing power and extensive I/O capabilities?What does “redundancy” mean in the PLC systems?Which of the following is an example of an analog output device controlled by a PLC?Which programming language, apart from ladder logic, is commonly used for PLCs?What is a primary benefit of using a PLC over traditional relay-based control systems?What is the significance of the scan cycle time in a PLC system?What does the term “programming terminal” refer to in the PLC?Which of the following is an example of a discrete input device for a PLC?How can a PLC be protected from electrical noise and interference?What type of signal is processed by a digital input module in a PLC?How is the program stored in a PLC retained when the power is turned off?What type of communication protocol is commonly used by PLCs for industrial networking?Top PLC Q&A for New LearnersWhich feature of a PLC allows for easy troubleshooting and maintenance?What is the advantage of using an Ethernet-based communication protocol in PLC systems?What does “RTU” stand for in industrial automation?How does a PLC execute a control program?Which type of sensor is commonly used to detect the presence of an object in a PLC-controlled system?Which of the following describes a “redundant PLC system”?What is the primary advantage of using a modular PLC over a fixed PLC?What is the function of an Analog Output Module in a PLC?What type of sensor is commonly used to measure temperature in a PLC-controlled system?How can the scan cycle time of a PLC be optimized?Which of the following is an example of a discrete output device that a PLC can control?What is the main purpose of using timers in PLC programming?Which of the following is an example of a PLC output device?What does “redundant power supply” mean in a PLC system?How can “remote I/O” modules benefit a PLC system?What is the main advantage of using wireless communication in PLC systems?How do “soft PLCs” differ from traditional hardware PLCs?What is the purpose of using a “DIN rail” in PLC installations?What does “IO-Link” refer to in the PLC?How does a “servo drive” enhance a PLC-controlled system?
PLC MCQ Questions
The PLC video shares the detailed explanations for the first 30 programmable logic controller questions.
Basics of PLC Questions and Answers for Beginners
Question 1
A. Process Logic Controller
B. Programmable Logic Controller
C. Programmed Logic Computer
D. Programmable Logical Container
Show the Answer
Question 2
A. JavaScript
B. Ladder Logic
C. C++
D. Python
Show the Answer
Ladder Logic
Question 3
A. Networking
B. Process automation
C. Autonomous vehicle control
D. Data storage and analysis
Show the Answer
Process automation
Question 4
A. The hierarchy of operations
B. The steps in debugging
C. The sequential steps of a process
D. The structure resembling rungs on a ladder
Show the Answer
Question 5
A. Secure Control and Data Access
B. System Control and Data Acquisition
C. Supervisory Control and Digital Acquisition
D. Supervisory Control and Data Acquisition
Show the Answer
Question 6
A. Power Supply
B. CPU
C. I/O Modules
D. Communication Interface
Show the Answer
CPU
Question 7
A. RAM
B. Hard Disk
C. ROM
D. Flash Memory
Show the Answer
Flash Memory
Question 8
A. Handling input signals only
B. Handling input and output signals
C. Processing data
D. Storing data
Show the Answer
Question 9
A. Home appliance control
B. Robotics control
C. Traffic light control
D. Industrial automation
Show the Answer
Question 10
A. RF signals
B. Digital signals
C. Analog signals
D. Infrared signals
Show the Answer
Digital signals
Try these for best PLC questions:
Top 100 PLC Objective Questions and Answers
Question 11
A. Scalability
B. Compatibility
C. Redundancy
D. Modularity
Show the Answer
Redundancy
Question 12
A. HTTP
B. Modbus
C. FTP
D. MQTT
Show the Answer
Modbus
Question 13
A. Software development
B. Data analysis
C. User interaction with the PLC system
D. Network management
Show the Answer
Question 14
A. The time it takes to save the program to memory
B. The time it takes to complete one cycle of reading inputs, executing the program, and updating outputs
C. The time it takes to complete one cycle of reading outputs, executing the program, and updating inputs
D. The time it takes to boot up the PLC
Show the Answer
Question 15
A. Flowcharts
B. Boolean algebra
C. Sequential programming
D. Electrical relay logic
Show the Answer
Question 16
A. Low initial cost
B. High reliability
C. Flexibility in programming
D. Easy troubleshooting
Show the Answer
Low initial cost
Question 17
A. Detecting physical changes
B. Reading sensors values
C. Executing physical actions
D. Measuring temperature
Show the Answer
Question 18
A. Faster network speeds
B. Lower power consumption
C. Higher data storage capacity
D. Greater flexibility and programmability
Show the Answer
Question 19
A. Through special communication modules
B. Directly through digital I/O modules
C. By converting them to digital signals
D. By converting them to analog signals
Show the Answer
Question 20
A. RAM
B. EEPROM
C. ROM
D. Flash memory
Show the Answer
RAM
Check these for complex PLC questions:
PLC Multiple Choice Questions
Question 21
A. Reprogramming the PLC during operation without the shutdown
B. Changing I/O modules without shutting down the system
C. Upgrading the CPU in shutdown time only
D. Updating the firmware online to the latest version
Show the Answer
Question 22
A. I/O modules
B. Power supply
C. CPU
D. Communication module
Show the Answer
I/O modules
Question 23
A. Measure execution time of the PLC program
B. Monitor and reset the PLC if the program fails
C. Synchronize the PLC with external devices
D. Only monitors the PLC if the program fails
Show the Answer
Question 24
A. Flow meter
B. Proximity switch
C. Pressure sensor
D. Thermocouple
Show the Answer
Proximity switch
Question 25
A. Instruction
B. Byte
C. Word
D. Contact
Show the Answer
Contact
Question 26
A. RF signals
B. Digital signals
C. Variable voltage or current signals
D. PWM signals
Show the Answer
Question 27
A. Memory modules
B. I/O modules
C. Network protocols
D. CPU
Show the Answer
Network protocols
Question 28
A. Measure and control time intervals
B. Store program data
C. Convert analog signals to digital
D. Control the execution speed
Show the Answer
Question 29
A. To process control logic
B. To convert digital signals to analog
C. To store data
D. To detect and send input signals
Show the Answer
Question 30
A. A PLC with a fixed number of I/O points
B. A PLC with built-in HMI
C. A PLC that supports wireless communication
D. A PLC that allows adding/removing modules
Show the Answer
Learning PLC Basics
The below video shares the correct explanations for the next 30 PLC questions.
Learning PLC Basics: Best Q&A for Starters
Question 31
A. Compact size
B. Redundant systems
C. High capacity memory
D. High speed
Show the Answer
Redundant systems
Question 32
A. Limited expansion options
B. Fixed I/O configuration
C. Hardwired programming
D. Scalability and flexibility
Show the Answer
Question 33
A. Control output signals
B. Store digital data
C. Convert digital signals to analog
D. Convert analog signals to digital
Show the Answer
Question 34
A. Modular PLC
B. Compact PLC
C. Distributed PLC
D. Rack-mounted PLC
Show the Answer
Compact PLC
Question 35
A. Processing data in batch mode
B. Processing data with minimal delay
C. Processing data at scheduled intervals
D. Processing data using cloud services
Show the Answer
Question 36
A. Controlling high-power devices
B. Detecting input signals
C. Converting analog signals
D. Controlling low-power devices
Show the Answer
Question 37
A. Inability to handle complex tasks
B. Limited scalability
C. Reprogrammability
D. Only hardwired logic circuits
Show the Answer
Reprogrammability
Question 38
A. The speed at which the PLC to upload and download the program
B. The speed at which the PLC executes one cycle of reading inputs, processing logic, and updating outputs
C. The communication speed between PLC and external devices
D. The speed at which the PLC executes one cycle of reading outputs, processing logic, and updating inputs
Show the Answer
Question 39
A. Pressure transducer
B. Thermocouple
C. Motor starter
D. Flow meter
Show the Answer
Motor starter
Question 40
A. Instant Operations
B. Inside/Outside
C. Input/Output
D. Integrated Operations
Show the Answer
Input/Output
Check these for PLC Logic based questions:
PLC Ladder Logic Questions and Answers
Question 41
A. Network management tasks
B. Office automation tasks
C. Data analysis tasks
D. Real-time control tasks
Show the Answer
Question 42
A. It uses a different operating system
B. It has more memory and larger in size
C. It uses special hardware with inbuilt power backup
D. It is designed for industrial environments and real-time control
Show the Answer
Question 43
A. Temporary data storage
B. Permanent program storage
C. Executing control logic
D. Providing network connectivity
Show the Answer
Question 44
A. A step in the programming process
B. A type of memory module
C. A physical part of the PLC
D. A line in a ladder logic diagram
Show the Answer
Question 45
A. Uses natural language
B. Visually intuitive and easy to learn
C. Requires no training
D. Requires minimal hardware
Show the Answer
Question 46
A. Hardware Management Interface
B. Hybrid Machine Interaction
C. High-Mode Integration
D. Human-Machine Interface
Show the Answer
Question 47
A. Convert input signals
B. Interface with I/O devices
C. Provide electrical power to the PLC and its modules
D. Execute control logic
Show the Answer
Question 48
A. Store control logic
B. Provide user interface
C. Execute control programs
D. Ensure reliable data exchange between devices
Show the Answer
Question 49
A. Small PLC
B. Rack-mounted PLC
C. Micro PLC
D. Compact PLC
Show the Answer
Rack-mounted PLC
Question 50
A. Storing data on multiple servers
B. Having duplicate components to increase reliability
C. Running multiple programs simultaneously
D. Using outdated technology
Show the Answer
Check these for PLC interview questions:
PLC SCADA Engineers Interview Questions and Answers
Question 51
A. Relay
B. Solenoid valve
C. Push button
D. Variable frequency drive (VFD)
Show the Answer
Question 52
A. Structured Text
B. C++
C. Python
D. JavaScript
Show the Answer
Structured Text
Question 53
A. Higher power consumption
B. Lower initial cost
C. Simplicity of design
D. Easy reprogramming and scalability
Show the Answer
Question 54
A. Determines the network speed
B. Affects the speed and responsiveness of the control system
C. Determines memory capacity
D. Controls the power consumption
Show the Answer
Question 55
A. A device for monitoring network traffic
B. A storage device for PLC programs
C. A computer or device used to write and load programs into the PLC
D. A tool for measuring signal strength
Show the Answer
Question 56
B. Push button
C. Thermocouple
Show the Answer
Push button
Question 57
A. Increasing the clock speed
B. Using a plastic enclosure
C. Implementing proper grounding and shielding techniques
D. Using low-power devices
Show the Answer
Question 58
A. PWM signals
B. AC signals
C. Binary (on/off) signals
D. Analog signals
Show the Answer
Question 59
A. Using RAM
B. Using EEPROM or Flash memory
C. Using volatile memory
D. Using temporary buffers
Show the Answer
Question 60
A. HTTP
B. FTP
C. SMTP
D. Ethernet/IP
Show the Answer
Ethernet/IP
This PLC Q&A video shares the explanations for the remaining questions.
Understanding PLC: Top Q&A for New Learners
Question 61
A. Fixed I/O configuration
B. Individual I/O wiring for all modules
C. Online diagnostics and status indicators
D. Reprogramming capability
Show the Answer
Question 62
A. Limited device compatibility
B. Increased security risks
C. Faster data transfer and network integration
D. Higher power consumption
Show the Answer
Question 63
A. Redundant Transfer Unit
B. Remote Terminal Unit
C. Reliable Transmission Unit
D. Real-Time Unit
Show the Answer
Question 64
A. By processing each instruction in parallel
B. By randomly scanning and executing each instruction
C. By sequentially scanning and executing each instruction
D. By parallel scanning and executing each instruction
Show the Answer
Question 65
B. Thermocouple
C. Flow meter
D. Proximity sensor
Show the Answer
Proximity sensor
Question 66
A. A system with minimal error-checking
B. A system with duplicate components to enhance reliability
C. A system with no backup power
D. A system with excessive wiring
Show the Answer
Question 67
A. Simpler installation
B. Lower cost
C. Flexibility to expand and customize the system
D. Faster processing speed
Show the Answer
Question 68
A. Generate equivalent voltage signals
B. Convert analog signals to digital signals
C. To take the feedback from the sensors
D. Convert digital signals to analog signals
Show the Answer
Question 69
A. Thermocouple
B. Bellows
C. Pitot tube
D. Proximity switch
Show the Answer
Thermocouple
Question 70
A. By increasing the complexity of the control program
B. By adding more modules to the PLC system
C. By reducing the number of I/O points
D. By simplifying the control logic and optimizing program code
Show the Answer
Question 71
A. Relay
B. VFD
C. Sensors
D. Switch
Show the Answer
Relay
Question 72
A. To provide power to the PLC
B. To create delays and control the timing of events
C. To store control programs
D. To increase processing speed
Show the Answer
Question 73
A. Transducers
B. Solenoid valve
C. Proximity sensor
D. RTD
Show the Answer
Solenoid valve
Question 74
A. Using a single power source
B. Having backup power sources to ensure continuous operation
C. Reducing power consumption
D. Using low-quality power supplies
Show the Answer
Question 75
A. By eliminating the need for programming
B. By reducing the need for communication protocols
C. By increasing local processing speed
D. By extending the reach of the PLC to distant sensors and actuators
Show the Answer
Question 76
A. Lower data transfer speed
B. Elimination of physical cabling and increased flexibility
C. Increased power consumption
D. Reduced security
Show the Answer
Question 77
A. They are more expensive
B. They require no programming
C. They have fixed I/O configurations
D. They run on standard industrial PCs and offer greater flexibility
Show the Answer
Question 78
A. Facilitate the mounting of PLC components
B. It separates the power cables and data cables
C. It supports the installation of workstations
D. Provide cable routing to the incoming cables in the PLC panel
Show the Answer
Question 79
A. A type of memory storage
B. A programming language
C. A software development tool
D. A communication protocol for smart sensors and actuators
Show the Answer
Question 80
A. By providing the control of induction motors
B. By providing basic on/off control
C. By offering precise control of motor position, speed, and torque
D. By offering control of motor without feedback
Show the Answer
  • PLC Important Questions and Answers
  • 100 PLC True or False Quiz Questions
  • Siemens PLC Questions and Answers
  • Allen Bradley PLC Interview Questions
  • PLC Interview Questions and Answers
Water Fountain Control Logic – PLC Exercises and Solutions
Create User-Defined Data Types and Function Blocks in Studio 5000
Rockwell Automation Allen Bradley PLC for Smaller and Medium Projects
PID with Practical Example
How to Use Diagnostic Buffer for SIEMENS PLC?
Evaluating Industrial Automation Projects Return on investment (ROI)
Create a Function (FC) for a Valve Logic in Siemens PLC
T-Junction Traffic Control System – PLC Programming
Process Control & Instrumentation Objective Questions – Set 5
Open PLC Software
Open Source PLC and SCADA Software
HMI Simulation for PID Controller
PID Controller Output Types – PID_PWM and PID_Output
FIFO in STL Language in Siemens PLC
How to Code a FIFO Queue in STL Language in Siemens PLC?
SCADA Engineer
SCADA Engineer Job Responsibilities and Skills
If Else Statement in SCL Language
Control Systems Questions & Answers
Control Systems Objective Questions & Answers – Set 1
4–20 mA Process Control Loops
Digital Input and Output Devices Objective Questions
Digital Input Output Devices Objective Questions
Hazard Identification and Risk Assessment
Bit Shift Registers PLC Program
PLC Light Sequence Control using Bit Shift Registers
Free Industrial Control System (ICS) Cyber Security Training Course
Ladder Logic Vs. Other Programming Languages - PLC Basics
Ladder Logic Vs. Other Programming Languages – PLC Basics
Current to percentage conversion
Convert current (4-20mA) to Percentage (0-100%)
LVR Motor Controller Operation
Low Voltage Protection (LVP) and Low Voltage Release (LVR)
Fieldbus Transducer blocks
Foundation Fieldbus Standard Function Blocks
