Reading: PLC Interlock Logic with First Input Priority
Inst Tools > Blog > PLC Tutorials > PLC Interlock Logic with First Input Priority
The PLC interlock logic is used to provide priority to the input first operated to avoid any damage to the equipment and machines.
Last updated: October 17, 2023 1:58 pm
6 Min Read
In Industrial process control, we need different types of interlock logic to achieve the desired control and trip functions as per the requirements.
PLC Interlock ExampleMotor Forward and Reverse PLC Logic without InterlockInterlock Logic with First Input PriorityMotor Forward DirectionMotor Reverse DirectionPLC Interlock Video Tutorial
The PLC interlock logic is used to provide priority to the input first operated to avoid any damage to the equipment and machines or to avoid any undesired interruption.
One of the logic is interlock with first input priority. Say we have a machine that can do 5 different types of functions. We have 5 different types of inputs available to control the machine operation but the machine will do only one function at a time as per the selected input.
If input 1 is selected then the machine will do function 1. Similarly, if input 2 is given to the machine then the machine will do function 2 and so on. Be careful that the machine may be damaged if two or more inputs are given at the same time.
Here in this case we need to write a PLC interlock logic such that whatever the first selected input has high priority. Meanwhile, if any other input is given to the machine then it has to disregard the other input until the present operation completes.
Consider a motor that can operate in two directions as per the operator selection.
The motor can rotate in the forward direction or in the reverse direction. But the motor can rotate in only one direction at a time.
If we give both forward or reverse commands at the same time then the motor will be damaged.
The operator can start the motor in the forward direction using a Forward selector switch and similarly, the operator can start the motor in the reverse direction using a Reverse selector switch.
In general, the motor logics are equipped with many safety functions and other motor-related pushbuttons like start, stop, and emergency stop.
Here in this article, we are just focusing on simple forward and reverse logic for understanding the interlock program.
In the above PLC logic, when the forward selector switch is ON then the motor forward command will be initiated. Similarly, if the reverse selector switch is ON then the motor reverse command will be initiated.
In this logic, if both forward selector switch and reverse selector switch are ON at the same time then both forward and reverse commands will be initiated and these types of logic/situations damage the motors or any other machines.
Now we can avoid these problems with help of an interlock program. This program is called Interlock with the first input priority.
We have to insert the Normally-Close (N.C.) status of motor output commands in the input side to implement this interlock logic.
Insert N.C. status of motor reverse command with the motor forward selector switch as shown in the below figure.
Again insert N.C. status of motor reverse command with the motor reverse selection switch as shown in the below figure.
Initially, the motor will be in an OFF state so both N.C. contacts are in a close state.
Say if the operator started the motor in a forward direction then the N.C. contact of the motor forward command will be open in the second rung.
During this time, even if the operator activates the reverse selector switch then this command will not be initiated because N.C. contact is activated and it is open when the motor running in the forward direction.
Similarly, if the operator started the motor in a reverse direction then the N.C. contact of the motor reverse command will be open in the first rung.
During this time, even if the operator activates the forward selector switch then this command will not be initiated because N.C. contact is activated and it is open when the motor running in reverse direction.
In this video, I explained the importance of interlock logic with the first input priority.
Read Next
  • PLC Tanks Filling as per Priority
  • Selector Control Functions
  • Basics of Trips and Interlocks
  • PLC Conveyors with Interlock
  • Permissive and Interlock Circuits
Difference between Timer and Counter – PLC Basics
PLC Program for Automatic Bottle Rejection System
PLC Program for Trash Compactor
How to Create Templates in FactoryTalk View Studio?
How to Create New Project in Studio 5000?
SFC Language in PLC Programming
Schneider Electric: Car Parking System with Calculations in PLC
Complete PLC Project: Traffic Light Auto and Manual Automation
Industrial Automation and Control Systems (IACS)
PLC Ladder Logic for Tanks Filling as per Priority
PLC Programming for Train Detection and Gate Operation
PLC program for Latching and unlatched circuit
PID block from the PLC library
How to Configure PID Controller in Various Schneider PLCs?
Single-acting Cylinder OR operation (PLC and Sensors)
Single-acting Cylinder OR Logic Operation (PLC and Sensors)
Motor ON OFF Logic in PLC
Flood alert system using programmable logic controller
Flood Warning System using Programmable Logic Controller
PLC Program using Logic GATEs
PLC Logic GATE Program
Namur Digital Input Card
What is Namur Digital Input Card?
Siemens PLC-to-PLC Communication Project
How to Use Analog Input in Mitsubishi FX3U LOLLETTE PLC
How to Use Analog Input in Mitsubishi FX3U LOLLETTE PLC?
Electrical Machine Ratings Objective Questions
Dew Point Meter Principle
What is a Bus Coupler in Electrical Panel
What is a Bus Coupler in Electrical Panel?
PLC Conversion Program
How to use Converters in PLC
Transformer Tap changer
Transformer Mutual Induction
Direct & reverse actions control valve
Direct Acting Control Valves & Reverse Acting Control Valves
Solid State Devices Objective Questions and Answers
Top 300 Solid State Devices Objective Questions and Answers
