Reading: Open Loop and Closed Loop System Questions Answers
Inst Tools > Blog > Control Systems > Open Loop and Closed Loop System Questions Answers
Learn the differences between open loop and closed loop systems with these questions and answers in control systems.
Last updated: July 24, 2024 3:13 pm
Control Systems Control Systems MCQ Electrical MCQ Instrumentation MCQ PLC Tutorials
9 Min Read
Open Loop and Closed Loop SystemWhich characteristic is typical of an open-loop control system?What is a key characteristic of a closed-loop control system?Identify a typical feature of an open-loop system.What is a disadvantage of an open-loop control system?Identify a feature that distinguishes open-loop systems from closed-loop systems.Which characteristic enhances the reliability of a closed-loop control system?What advantage do open-loop systems have over closed-loop systems?Which application is best suited for an open-loop control system?Which of the following is an example of a closed-loop control system?Which real-life example best illustrates an open-loop system?Which home appliance operates as a closed-loop control system?What type of control system does a basic light switch represent?How does an automatic irrigation system with soil moisture sensors function as a closed-loop system?Which transportation system is an example of a closed-loop control system?Identify the open-loop control system from the options below.Which of the following is an open-loop control system?Select the example that best represents a closed-loop control system.Identify the closed-loop control system from the following options.Which of the following is a closed-loop control system?In control systems, what does feedback refer to?Which feature is associated with closed-loop systems?Why might an open-loop system be preferred over a closed-loop system?Which of the following is a disadvantage of a closed-loop control system?How does feedback improve the performance of a control system?Which component is essential in a closed-loop control system but not in an open-loop system?Which term describes the difference between the desired and actual output in a control system?In which scenario would an open-loop system be more appropriate than a closed-loop system?Which control system is better suited for processes where the environment is highly variable?Identify a characteristic that is exclusive to closed-loop control systems.What type of control system uses a predetermined sequence of operations?
In this video, you will learn the open-loop and closed-loop control systems questions and answers with detailed explanations.
Open Loop and Closed Loop Control Systems - Q&A
Question 1
A. Uses feedback to adjust
B. Self-correcting errors
C. Predetermined output without adjustments
D. High accuracy and stability
Show the Answer
Question 2
A. Operates without feedback
B. Uses a fixed input
C. Controls based on output feedback
D. Simpler design
Show the Answer
Question 3
A. Feedback loop
B. Error detection
C. No feedback mechanism
D. Real-time adjustments
Show the Answer
Question 4
A. High complexity
B. High accuracy
C. Inability to correct errors
D. High cost
Show the Answer
Question 5
A. Feedback control
B. Real-time error correction
C. Predetermined control actions
D. High stability
Show the Answer
Question 6
A. Absence of sensors
B. Predetermined operation
C. Continuous monitoring and adjustment
D. Simple design
Show the Answer
Question 7
A. Higher accuracy
B. Real-time adjustments
C. Lower complexity and cost
D. Self-correction ability
Show the Answer
Question 8
A. Maintaining room temperature
B. Automated traffic lights
C. Cruise control in vehicles
D. Automatic braking system
Show the Answer
Question 9
A. A washing machine timer
B. A toaster
C. A thermostat-controlled heater
D. A microwave oven
Show the Answer
Question 10
A. Cruise control in a car
B. Microwave cooking for a set time
C. Refrigerator maintaining temperature
Show the Answer
Question 11
A. Toaster
B. Washing machine
C. Air conditioner
D. Electric kettle
Show the Answer
Air conditioner
Question 12
A. Open-loop system
B. Closed-loop system
C. Hybrid system
D. Adaptive system
Show the Answer
Open-loop system
Question 13
A. Waters plants at fixed intervals
B. Adjusts watering based on soil moisture levels
C. Uses a preset watering schedule
D. Operates manually by the user
Show the Answer
Question 14
A. Bicycle
B. Manual transmission car
C. Autonomous vehicle
D. Skateboard
Show the Answer
Autonomous vehicle
Question 15
B. Room heater with thermostat
C. Toaster
Show the Answer
Toaster
Question 16
A. Electric kettle with auto shutoff
B. Elevator system
C. Manual washing machine
D. Central heating system
Show the Answer
Question 17
A. Electric fan with speed settings
B. Timer-based sprinkler system
C. Refrigerator
D. Gas stove
Show the Answer
Refrigerator
Question 18
A. Electric oven with a timer
B. Bicycle
C. Cruise control in a car
D. Ceiling fan
Show the Answer
Question 19
A. Electric clock
B. Automatic door opener
C. Manual hand drill
D. Simple alarm clock
Show the Answer
Question 20
A. Input signal modification
B. Output signal comparison
C. Output signal feeding back into the system
D. Signal amplification
Show the Answer
Question 21
A. Fixed operation cycle
B. No error correction
C. Simple design
D. Feedback control
Show the Answer
Feedback control
Question 22
A. Higher accuracy
B. Better error correction
C. Simpler design
D. Higher reliability
Show the Answer
Simpler design
Question 23
A. It cannot self-correct
B. It is more complex and expensive
C. It lacks accuracy
D. It has no feedback
Show the Answer
Question 24
A. By eliminating the need for input
B. By reducing system cost
C. By comparing the output to the desired setpoint and adjusting accordingly
D. By increasing system complexity
Show the Answer
Question 25
A. Actuator
B. Sensor
C. Feedback mechanism
D. Controller
Show the Answer
Feedback mechanism
Question 26
A. Gain
B. Offset
C. Error
D. Hysteresis
Show the Answer
Error
Question 27
A. Precision temperature control
B. Automated control
C. Basic timed operations
D. Cruise control in vehicles
Show the Answer
Question 28
A. Open-loop control system
B. Feedforward control system
C. Closed-loop control system
D. Sequential control system
Show the Answer
Question 29
A. Fixed operation schedule
B. Lack of sensors
C. Continuous error correction
D. Low implementation cost
Show the Answer
Question 30
B. Closed-loop control system
C. Hybrid control system
D. Adaptive control system
Show the Answer
  • Ziegler-Nichols Open-Loop Method
  • Feedback Control Loop Questions
  • Control Gas Pressure with Closed-Loop
  • PID Simulator Download Free Software
  • PID Loop Tuning Questions and Answers
Main differences between Sinking and Sourcing Circuits
Schneider PLC Example Program for Star-Delta System
Tia Portal – Different Instances of Calling a Function Block
143 Process Control Terms and Glossary – Questions Answers
Electronics and Instrumentation Students Quiz
Use of Isolators and Barriers in Electrical Panel
Cybersecurity in PLC
Fluidic Systems Objective Questions
DC Generators Objective Questions and Answers
Heating and Mixing of Products using PLC Example Tutorial
PLC Analog I/O Potential Problems – Troubleshooting & Issues
Data Types in PLC
Data Types in PLC – Bit, Byte, Integer, Real, String
PLC Programmer Salary and Future Career Scope
Structured Control Language (SCL) Elements
Value Assignments in SCL Language – Single, Multiple, Combined
Shift Bit Register in PLC
Boolean Algebra to PLC Logic
From Boolean Algebra to PLC Logic
Save to Memory Card
How to Save a PLC Project to a Micro Memory Card?
Programming in Omron PLC
PLC Training Data Tables FIFO and LIFO
FIFO Instruction in Allen Bradley PLC Programming
Linear Programming in Excel
How to Do Linear Programming in Excel?
Corona-Ring-on-Surge-Arresters
Reverse Bias Diode Working Animation
Forward Bias & Reverse Bias Diode Working Animation
Namur Digital Input Card
What is Namur Digital Input Card?
What is Instrument Air Manifold
What is Instrument Air Manifold ?
Historical Scada graph
Configuration of InTouch Scada Trends
Capacitors Connected in Parallel
Series and Parallel Capacitors
Top 10 Facts about HART Technology
