Reading: OFF Delay Timer using PLC
Inst Tools > Blog > PLC Tutorials > OFF Delay Timer using PLC
Last updated: March 4, 2021 3:45 pm
3 Min Read
This article discusses about OFF delay timer instruction and its working principle using Allen Bradley Programmable Logic Controller (PLC) Ladder Logic.
OFF Delay TimerProgram DescriptionOFF Delay Timer using PLCOFF Delay Timer Video LessonConclusion
Timer OFF delay is to delaying the turning OFF of any output, Example-Setting timer to turn off Induction Stove, TV remote settings to turn OFF TV after certain time.
OFF Delay Timer
OFF Delay Timer
In the above OFF delay timer instruction, there are totally four parameter,
TIMER: T4:0 – Timer File name (Timer T4:0, T4:1, T4:2…)
TIMER BASE – How the time need to count, in Seconds, Milli Seconds.
PRESET – Limit value of Timer-Up to how much it should count
ACCUMULATOR – Running Value of timer when it is in ON condition.
Program Description
Off- delay timer instructions is used to program a time delay to begin after rung input goes false.
As an example, when an external cooling fan on a motor is provided, the fan has to run all the time the motor is running and also for certain time (say 10 min) after the motor is turned off.
This is a ten minute off- delay timer. The ten-minute timing period begins as soon as the motor is turned off.
Timer OFF Delay Logic
RUNG 0000 :
Start/ Stop Switch is to turn ON/OFF the timer.
RUNG 0001 :
When start switch is pressed, Timer Enable bit (T4:0/EN) is turned ON to show the status of TIMER ON/OFF condition along with timer done bit (T4:0/DN)
RUNG 0002 :
When Start/Stop switch is Turned OFF, timer enable bit, timer timing bit turned OFF to show the status of timer. Timer Timing bit turned ON to show the status of timer is running. Time done bit maintain its previous state.
RUNG 0003 :
If accumulator value reaches preset value, all the timer bits (EN,TT & DN) are turned off.
Conclusion
We can use this example program to understand the working of the OFF delay timer function in Allen Bradley PLC.
Author: Hema Sundaresan
One Shot Rising PLC Example
PLC Important Questions
DeltaV System Configuration
Process Control High Level Alarm
PLC Practice Questions
Basic Arithmetic Programming in Mitsubishi PLC
How to Configure PID Controller in Various Schneider PLCs?
MCQ on PLC (Programmable Logic Controller)
CODESYS HMI Interface
PLC Techniques for I/O Mapping
S7-1200 Hardware Configuration – Siemens PLC Tutorials
Allen Bradley RSLogix 500 PLC Programming
What is Interposing Relay in a PLC System ?
PLC, DCS, and ESD Marshalling Cabinet Checks
WHILE DO Statement in SCL Language
How to Choose the Right Industrial Automation Solution?
RSLogix5000 PLC Program Backup procedure
PLC Example with Switches
Difference between DCS, PLC, and RTU ?
Introduction to PLC
Introduction to PLC – Advantages of PLC
Human Machine Interface
What is Human Machine Interface (HMI) ?
ON and OFF a Group of Outputs by One Push button PLC Logic
PLC Best Practices
#1 PLC Best Practices – Split PLC Code into Modules
Ladder Logic for Stair-Case wiring using Toggle Switches
HMI configuration for Delta VFD
Modbus Communication between Delta PLC with VFD
PLC Programming Course Online Free
Instrumentation Engineering Standards Interview Questions & Answers
Electrical Machines Objective Questions & Answers
Instrumentation Engineering Standards Questions & Answers
Scaling in PLC
How to do Scaling for Analog Input in RSLogix 500?
Solenoid Actuated Valves
Control Valves - Repeat Actuator Diaphragm Bursts
Control Valves – Repeat Actuator Diaphragm Bursts
Split Range Control for Temperature Control Application
Weir Flow Meter Principle
Measure Flow rate using Level Sensors
Lamp Counter Logic
Function Block (FB) for Motor Control Logic
