Reading: Motor Operated Valve Problems and Troubleshooting
Inst Tools > Blog > Control Valves > Motor Operated Valve Problems and Troubleshooting
In this article, we will learn the common problems of motor operated valve and their troubleshooting steps.
Last updated: July 9, 2024 10:20 am
Control Valves
6 Min Read
Motor Operated Valve (MOV) is one of the most critical instruments installed in lines of feed or product supply or other important fluid supply in industries.
Mostly MOVs are installed at battery limits or in big lines as an isolation valve. Many times, we face problems with motor-operated valves, and troubleshooting is needed.
In this article, we will learn the troubleshooting steps for motor-operated valves.
Below mentioned steps can be followed to solve problems faced in motor-operated valves (MOV).
Check the display of MOV. If the power of MOV is lost, then only Open or Close Feedback is seen on the MOV display, (the 9 volt battery of the MOV should be ok).
If the power is ON, then the display will be shown with a text message as shown below.
Motor Valve Feedbacks with power ON
If the power is OFF, then the display will only show feedback as shown below:
Valve Motor Feedback without power
Only the open or close indication will be present. No text will be present on the screen when the power of the MOV is off. The backlight will also be in off condition.
Also, every MOV has a LED that shows power status (Refer to the vendor manual to know which LED is given for power indication). Also, the backlit is in ON condition when electrical power is present. If electrical power is not present, then check whether the MOV is electrically isolated or not. If MOV is not electrically isolated, then ask the electrical department to check the incoming power to the MOV.
If MOV is in power ON condition and not taking command from the control system, then check whether any interlock is inhibiting the operation of MOV or not.
If the interlock is healthy, then check the MOV mode of operation by physically inspecting it in the field. If MOV is in Local or Stop mode, then MOV will not operate on System commands. So put the MOV in Remote mode by using the push buttons on it.
If MOV is used with digital communication like Packscan or DeviceNet Loop, then check the device address as well as the Baud Rate. Check the standard technical document and confirm the device address and the Baud Rate.
If MOV is in Remote mode and still not taking command from the system, then check the cable connections (the cable which is used to operate MOV) in MOV as well as the system marshalling cabinet.
If MOV’s feedback is not coming to the control system, then set the feedback through the Setting Tool or through the local buttons present on MOV whichever is applicable.
If setting feedback does not work, then check the relay status (relays are present inside MOV for getting feedback) configuration for the particular feedback as per the installation guideline. Relay can also be faulty. Replace the relays if found faulty or check the relay wiring. You can also use a spare relay if available.
If MOV is showing a torque trip alarm, then recheck the torque value with the standard technical document. If found any deviation then correct the same. Do not increase the torque value without consulting the Mechanical team and referring to the data of the valve body. Increasing the torque can damage the gearbox and valve body.
MOV sometimes shows a Motor Stalled alarm when the MOV’s circuit does not detect any movement after the command. This happens when the Motor and the Gearbox are disengaged or when the MOV encoder for position feedback goes faulty.
If MOV is not operating, then operate the MOV locally through the local buttons or using the Setting Tool. If MOV does not operate properly or gets stuck, then try to operate the MOV through the handwheel. If still MOV doesn’t operate, then drop MOV for valve body inspection.
If MOV is showing the Thermostat Alarm, then allow MOV to cool down for some time. MOV generates Thermostat Alarm when the motor winding is overheated due to frequent operation. If after cooldown also MOV shows Thermostat Alarm, then check the temperature sensing element installed inside the MOV actuator casing.
  • Instrumentation and Control Quiz
  • Pneumatic Systems Objective Questions
  • Electrical Systems vs. Pneumatic Systems
  • Troubleshooting PLC Automation Systems
  • Troubleshooting Flow Meter Common Problems
Rotary Stem Valves
JT Valve Working Principle
Common Terms Used in Control Valves
Pressure Relief Valve Principle
Free Control Valves Course
Design and Accessories Required for Online Testing of Solenoid Valve
Basic Requirements of Control Valves Sizing
What is an Air Valve? Purpose, Types, Advantages, Disadvantages
Breather Valve Working Principle
What is a 3-way Solenoid Valve ?
Metal Seated Valves and Soft Seated Valves : Differences
Pressure Relief Valve Terminology
Control Valve Flow Direction
Control Valve Passing Problem after Overhauling Job
noise-abatement trim
Control Valve Noise Problems
Classification of Solenoid Valves
What is Partial Stroke Test
What is Partial Stroke Test?
actuated-valve-schematic
Components of Shutdown Valve
valve control system
Solenoid Valves Practical Problems
Y Body Globe Valve
Globe Valve Body Design
Control Valve Positioners
Full Bore or Reduced Bore Valves
When to choose Full Bore Valve or Reduced Bore Valve ?
Reflex Level Gauge Parts
What is Reflex Level Gauge?
Wiring-Connection-from-PLC-to-Solenoid-Valves
How to Connect a Solenoid Valve with PLC?
5-Port-2-Position-Valve-Animation
5 Port 2 Position Valve Working Principle
Single-Phase Induction Motors Multiple Choice Questions (MCQ)
125+ Single-Phase Induction Motors Multiple Choice Questions (MCQ)
Split Phase Motor
Single Phase AC Induction Motors
Bonding and Grounding Electrical Systems
Testing and Inspection of Bonding and Grounding Systems
Simulating Level Sensor and the Pump Logic in PLC
PLC Basics – Manual Control, Closed Loop, ON-OFF with Hysteresis
