Reading: Convert Linear Percentage to Square root Percentage
Inst Tools > Blog > Instrumentation Tools > Convert Linear Percentage to Square root Percentage
Last updated: November 12, 2019 4:02 pm
0 Min Read
This tool is used to convert the transmitter Linear % signal into the equivalent square root % signal.
This calculation tool is used to Convert Linear % to Square root %
Level Measurement with Wet leg and Installed Below Tapping Point
4-20 mA to Measurement Converter Tool
Convert Process Variable to Percentage
Density Measurement using DP Transmitter for closed tank with wet leg
Instrumentation Calculator
Convert Linear mA to Square root mA
  • huarache says:
    October 18, 2015 at 8:01 am
    Thank you. Your article is very helpful to me.
DP Flow Transmitter Re-Ranging Calculation
Transmitter Current Conversion Tool
Density Measurement for Open Tank with Constant Level Application
Convert current (4-20mA) to Percentage (0-100%)
Conversion of Transmitter Output in Percentage to Process Variable
Boiler Drum Level Transmitter Calibration
Differential Pressure (DP) Level transmitter Installed Above Tapping Point
Calculate Current (4-20ma) from Process variable PV
0-20 mA Analog Signal to Measurement Converter Tool
Calculate Resistance from Temperature for RTD
RTD Calculator : Calculate Resistance from Temperature
DP-Level-Measurement-Calculation-Below-Tapping-Point-Open-Tank
Differential Pressure (DP) Level transmitter Installed Below Tapping Point
Closed-Tank-DP-Type-Level-Measurement-with-Dry-leg-and-transmitter-installed-below-tapping-point
Level Measurement with Dry leg and Installed Below Tapping Point
Convert-Percentage-to-current
Convert Percentage (0-100%) to current (4-20mA)
DP-Level-Transmitter-Diaphragm-with-capillary-tube-type
DP Level Transmitter Calibration for Diaphragm Seal with Capillary
Measurement Value to 4-20mA Signal Converter
Interface level Measurement
Interface Level Measurement using DP Transmitter
Purpose of Instrument Loop Diagrams
Purpose of Loop Diagrams
Elevator PLC Ladder Logic
Demultiplexers Quiz
Hardware Description Language Objective Questions
Process Control & Instrumentation Objective Questions – Set 3
Chlorine dioxide measurement principle
Chlorine dioxide Analyzer Principle
Static and Dynamic Characteristics of an Instrument
