Root Cause Analysis (RCA): Less than 40% available Plant Air Compressors made available 100% for operations.
| Category: | Mechanical |
| Equipment Type: | Miscellaneous Rotating Machine Problems |
Root Cause Analysis
Author RCA queries, answers are
Q- Why compressors’ < 40% only availabilities even after eliminating drive problems
A-Too poor-quality valves of listed below defects:
- General poor overall finish and parts’ poor fits
- Parts are of not proper dimension tolerances – a very essential requirement for long service lives.
- Mostly used coarse threaded fasteners secured parts tear apart in few hours of service
- Poorly hinged opening and closing reeds
Q- How to improve?
A- Compressor valves manufacturing Hi-tech task is best left to specialist firms. Hence, the author selected from a well-known Austrian OEM Vendor catalog suitable suction and discharge valves.
Final RCA solution
Though the vendor offers a custom valve at 20% extra cost, the author selected their standard valve because compressors valve ports bore increases to fit the just 1 mm more body dia Austrian valves is just a one-time negligible cost task.
Cost Savings from boosting Compressor availabilities
Below are the savings
| Compressor ownership costs neglecting the negligible depreciation costs | 10668698 |
| Painting Contractor air cost bill | 31914894 |
| Yearly Savings | 21246196 |
| Additional expenses – compressor fitted 2 Nos. + 2 reconditioning rotatable Austrian Valves | 70000 |
| Payback days | 1.20 |
Summary
Hence benefits summary is:
- Drive improvements and Austrian valves fitting boosted compressor availabilities increased to 100%
- Uninterrupted compressed air supply smoothened many plant operations
- Enough air availabilities stopped wasteful ‘No air availability’ painting contractors’ payments and enabled meeting the “keep the plant young” corporate goal at negligible costs – see table above
- The savings paid for the new Austrian valve costs in say two days
Author: S. Raghava Chari
- Turbo-Compressor Problem
- Compressor Anti-Surge Control
- Process Air Compressor Overhauls
- NH3 Plant Turbo-compressor Problem
- Shaft and Coupling Bore Tapers Repair
