Reading: Leaky Boiler Drum Level Switch Stops NH3 Plant Commissioning
Inst Tools > Blog > Root Cause Analysis (RCA) > Leaky Boiler Drum Level Switch Stops NH3 Plant Commissioning
Instrumentation engineering root cause analysis of Leaky Boiler Drum Level Switch Stops NH3 Plant Commissioning.
Last updated: September 28, 2022 2:51 pm
S Raghava Chari
2 Min Read
Leaky Boiler Drum Level SwitchAuthor SolutionBenefits Realized
Article Type:Root Cause Analysis (RCA)
Category:Instrumentation
Equipment Type:Instruments
Author:S. Raghava Chari
Problem: 40-bars 250o C waste heat boiler Steam Drum Level Switch electrode packing leaks delayed an ammonia plant commissioning.
The workshop found it impossible to turn-out the flexible material-shaped packing.
The drawing has shown flexible material was unfamiliar and not available.
Author Solution
The author got the packing done thus:
  1. Hold the electrode in the hole and wedge at the bottom with two diametrically opposite tiny wooden chips.
  2. Fill loose high temperature graphite packing around the electrode; tighten the packing nut 3 turns after filling.
  3. Insert the top ceramic sleeve to prevent electrode contacting the packing nut.
  4. Tighten the packing nut if leaks seen at full drum pressure and temperature.
Benefits Realized
The level switch electrode never leaked; thus, a very important boiler safety alarm function reliably ever.
Author: S. Raghava Chari
  • Pressure Switch Screwed Cover
  • Too Low-Temperature Readings
  • Thermowell Shank to Flange Leaks
  • Magnetic Flow Meter Liner Damaged
Industrial Light Fittings and Street Light Poles Corrosion Problems
30 Electrical Engineering Problems – Root Cause Analysis
Junction Box Internal Corrosion Problems and Solutions
Discharge Head 3‑monthly leaks of Steam Turbine Driven Centrifugal Compressors
Turbine Flow Meter (TFM) Field Calibration Uncommon Request
Cooling Water Circulating Pump Low throughput Resolved
Instrument Steam Pressure Taps Primary Block Valves Glands and Bonnets Leaks
Butterfly Valve Failure Caused Serious vicinity Heavy Fire
Condensate Pump Frequent Wrecks Threatens Long Plant Outages
CO2 Stripper Collapsed Internals Revamp
Control Valve Passing Problem after Overhauling Job
Multistage Flash Drums Erratic Level Readings
Doubtful Temperature Readings threatens Soaking Pit Wrecks
Incident Investigation: Motor Operated Valve Lesson
Thermowell Shank to Flange Repeat Weld Leaks
Reactor Top lid lapped
Urea Reactor Top Bolted Plug developed Leaks
Transformers Coolers Weld Joints Oil
Transformers Coolers Weld Joints Oil Oozes Were Eye Sores
Solenoid Valve Failure in Plant Start-Up
Questions and Answers on Motors and Generators
HT Motor Problem appears after Disassembly and Reassembly
Magnetic Flow Meter Liner Damaged and Winding Burnt
Thermocouple Extension Lead Problem
Types of Capacitors
Types of Capacitors
How to Connect HART Communicator with DP Transmitter
15 HART Communicator Questions
List of 100 Sensors and Transducers Questions
Liquid Tank Filling and Emptying PLC System
Auto and Manual Liquid Tank System: PLC Program Example
7 OSI Layers of Communications
Remote Diaphragm Seal Transmitter for Vacuum Application
WinCC data logging
How to Export Data from WinCC Runtime Advanced into Excel using VB Script
