Reading: Laminar Flow Meter Working Principle
Inst Tools > Blog > Flow Measurement > Laminar Flow Meter Working Principle
A unique form of differential pressure-based flow measurement deserves its own section in this flow measurement chapter, and that is laminar flow meter.
Last updated: November 2, 2023 7:26 am
Flow Measurement
A unique form of differential pressure-based flow measurement deserves its own section in this flow measurement chapter, and that is the laminar flow meter.
Laminar FlowLaminar Flow MeterAdvantages of Laminar Flow MeterDisadvantages of Laminar Flow MeterApplications of Laminar Flow Meter
Laminar Flow
Laminar flow is a condition of fluid motion where viscous (internal fluid friction) forces greatly overshadow inertial (kinetic) forces. A flow stream in a state of laminar flow exhibits no turbulence, with each fluid molecule traveling in its own path, with limited mixing and collisions with adjacent molecules.
The dominant mechanism for resistance to fluid motion in a laminar flow regime is friction with the pipe or tube walls. Laminar flow is qualitatively predicted by low values of Reynolds number.
This pressure drop created by fluid friction in a laminar flow stream is quantifiable, and is expressed in the Hagen-Poiseuille equation:
Laminar flow meter equation
Where,
Q = Flow rate
ΔP = Pressure dropped across a length of pipe
D = Pipe diameter
μ = Fluid viscosity
L = Pipe length
k = Coefficient accounting for units of measurement
Laminar flow meter elements generally consist of one or more tubes whose length greatly exceeds the inside diameter, arranged in such a way as to produce a slow-moving flow velocity.
Laminar Flow Meter
An example is shown here:
The expanded diameter of the flow element ensures a lower fluid velocity than in the pipes entering and exiting the element. This decreases the Reynolds number to the point where the flow regime exhibits laminar behavior.
The large number of small-diameter tubes packed in the wide area of the element provide adequate wall surface area for the fluid’s viscosity to act upon, creating an overall pressure drop from inlet to outlet which is measured by the differential pressure transmitter.
This pressure drop is permanent (no recovery of pressure downstream) because the mechanism of pressure drop is friction: total dissipation (loss) of energy in the form of heat.
Another common form of laminar flow element is simply a coiled capillary tube: a long tube with a very small inside diameter. The small inside diameter of such a tube makes wall-boundary effects dominant, such that the flow regime will remain laminar over a wide range of flow rates.
The extremely restrictive nature of a capillary tube, of course, limits the use of such flow elements to very low flow rates such as those encountered in the sampling networks of certain analytical instruments.
A unique advantage of the laminar flowmeter is its linear relationship between flow rate and developed pressure drop.
It is the only pressure-based flow measurement device for filled pipes that exhibits a linear pressure/flow relationship.
This means no “square-root” characterization is necessary to obtain linear flow measurements with a laminar flowmeter.
The big disadvantage of this meter type is its dependence on fluid viscosity, which in turn is strongly influenced by fluid temperature.
Thus, all laminar flowmeters require temperature compensation in order to derive accurate measurements, and some even use temperature control systems to force the fluid’s temperature to be constant as it moves through the element.
Laminar flow elements find their widest application inside pneumatic instruments, where a linear pressure/flow relationship is highly advantageous (behaving like a “resistor” for instrument air flow) and the viscosity of the fluid (instrument air) is relatively constant.
Pneumatic controllers, for instance, use laminar restrictors as part of the derivative and integral calculation modules, the combination of “resistance” from the restrictor and “capacitance” from volume chambers forming a sort of pneumatic time-constant (τ ) network.
  • Flow Measurement Technologies
  • What is a Vortex flow meter?
  • PLC Program for Flow Totalizer
  • What is an Insertion flow meter?
  • Turbine Flow meter Coefficient
Impulse Line – Purpose & Tapping Point Location
Types of Flow Meters
Spring Loaded Variable Area Flow Meter Working Principle
Basics of Restriction Orifice (RO) – Types, Applications, Standards
Orifice Plate Questions and Answers
Read Gas Composition from Gas Metering System using RS485 Protocol
Optical Flow Meter Principle
Flow Instruments – Selection, Principle & Application
Coriolis Mass Flow Meter as a Multi-Variable Transmitter
Oscillating Piston Flow Meters Working Principle
Open Channel Flow Measurement Principle
What is the Purpose of Orifice Plate Drain Hole and Vent Hole?
Orifice Flange Rating
Why Orifice Flow Meter Flange is Not Recommended 150# Rating?
Turbine Flowmeter Parts
What is a Turbine Flow Meter?
Gas and Liquid Measurement
Gas and Liquid Measurement: Processes and Solutions for the Industrial Sector
Magnetic Flow Meters
Troubleshooting Ultrasonic Flow Meter Common Problems
Turbine Flow Meter Animation
Turbine Flow Meter – Principle, Advantages, Disadvantages
Troubleshooting Magnetic Flow Meters Common Problems
Pressure Temperature Compensation Flow Measurement
Basics of Loop Checks
PLC Program with 2 Toggle Switches and 4 Motors
Thyristor Protection Objective Questions and Answers
RTD and Thermocouple Testing
Temperature Transmitter Preventive Maintenance
Diaphragm valves
Basics of Valves
Open Circuit without Freewheeling diode
Freewheeling Diode Working Principle
Shift Registers and Counters Objective Questions
Pressure Transmitter Calibration Procedure
