Reading: Ladder Logic Example of Two Motors Interlinked with another Motor
Inst Tools > Blog > PLC Tutorials > Ladder Logic Example of Two Motors Interlinked with another Motor
In this article, we will learn a ladder logic example of two motors interlinked with another motor in PLC programming.
Last updated: September 28, 2022 4:09 pm
3 Min Read
In this article, we will learn a ladder logic example of two motors interlinked with another motor.
Ladder Logic Example of Two MotorsFirst RungSecond RungThird Rung
In this post, we will study a case of ladder logic. There are two motors – motor A & motor B. And third motor – C is interlinked with both these motors.
There will be a selection for running the two motors of A & B either simultaneously or individually.
If either the motors (A/B) or a single motor is running depending upon the selection, then the third motor will run.
If any single motor is off, then the third motor too will remain off.
Let us have a look at the ladder logic for the same accordingly.
Refer to the below image for the logic written. Let us understand each rung one by one.
First Rung
The first rung is used to turn on or off the first motor – A. If both the motors are selected to be running, then this motor will run.
If only a single motor is selected to be running, then depending upon the motor selection, this motor will operate.
In this case, the selection input must be off for turning on the output.
Second Rung
The second rung is used to turn on or off the second motor – B. If both the motors are selected to be running, then this motor will run.
In this case, the selection input must be on for turning on the output.
Third Rung
The third rung is used to turn on or off the third motor – C. If both the motors are selected to be running, then this motor will run only when both the previous motors are running.
If only a single motor is selected to be running, then this motor will run if either of the output is running.
In this way, we had a case study of the following example in ladder logic.
  • Ladder Logic Example
  • WinCC Runtime Advanced
  • Why 24 Volts DC Power Supply?
  • Communication in S7-1200 PLC
  • Factory Acceptance Test of PLC
Working Principle of Single Phase Preventer Relay
PLC Programming for Weight-Based Packaging
Example of Flip-Flop PLC Program for Lamps Application
PID Controller Output Types – PID_PWM and PID_Output
PLC Temperature Control using Pulse Width Modulation (PWM)
ControlLogix Architecture – Rockwell Automation
Forcing and Modifying PLC Logic
Motor Feedback Fail Logic in PLC
Automatic Highway Lights Program using RTC in Omron PLC
Elevator PLC Ladder Logic
How to Configure IP Address in Rockwell PLC?
How to Read the PLC Datasheet? – Important Notes About PLC
PLC Program for Temperature Control using Thermostat
Relay Motor Logic Circuit
Motor Control Circuits
FIFO in STL Language in Siemens PLC
How to Code a FIFO Queue in STL Language in Siemens PLC?
Types of PLC
Types of PLC
PLC Program for Alarm Indication in Process
Structured Text PLC Program for Sequential Process Data Storage
Structured Text PLC Code for Sequential Process Data Storage
Difference between Compact PLC and Modular PLC
Sources of Static Grounding and Methods to Control
double-pumps unit unloading valves
What is an Unloading Valve? – Types, Principle
5 Most Common Mistakes When Specifying Valves
Pressure Gauge Accessories
30% Feed Control Valve
Purpose of 100% and 30% Feed Control Valves in a Power Plant
Electrical Machines MCQ Series 22
What is a Voltage Reference
What is a Voltage Reference? – Electronic Components
What is a Laser Sensor
What is a Laser Sensor? Principle
