Reading: Introduction to Control System
Inst Tools > Blog > Control Systems > Introduction to Control System
We will discuss the Introduction to Control System and the open loop and closed loop control systems in detail with examples.
Last updated: September 26, 2023 3:22 pm
K Mugunthan
Control Systems
8 Min Read
In real-time for doing some work we require machines, tools, and equipment. For example, a hair dryer to dry the wet hair, an air conditioner to give the cool air, a washing machine to wash clothes, etc. In each of these, we have many components and parts. Each of the parts interacts with each other and gives us the desired results.
SystemInputOutputControlControl SystemClassification of Control SystemOpen Loop Control SystemExamples of Open Loop Control SystemsAdvantages of Open Loop Control SystemDisadvantages of Open Loop Control SystemClosed Loop Control SystemExamples of Closed Loop Control SystemsAdvantages of Closed Loop Control SystemDisadvantages of Closed Loop Control System
System
A system is a collection of many parts or subsystems that are integrated highly for producing an essential output. Every system takes some inputs, then manipulate, transforms, or processes them to give the desired output.
In short, a system is an arrangement or a combination of different physical components connected or related in such a manner as to form an entire unit to attain a certain objective.
Input
Input is the process or function of something put into a system or expended in its operation to achieve output or a result. The excitation applied to a control system from an external source in order to produce the output is known as input. Electricity and switches are inputs for a light, Petrol and Steering controls are inputs for car.
Output
The response obtained on the system is called output. The output depends on the input and the activity performed on the inputs by the system. For example, Glowing light and Motion of car are the outputs of the system.
Control
Control is the process of regulating the function or input for getting the desired results what we required. The process of regulating the inputs or directing the system so that desired objective is attained is called control. For example, adjustment of amplifier for getting the clear sound, regulating the fan speed for comfortable air.
Control System
For getting a specific output, the different physical elements are arranged and connected in such a manner to as to regulate, direct or command itself. The Control System is represented by a single block. Since the output is controlled by varying input, it is called as the control system. We will vary this input with some mechanism.
The major difference between system and control system is, in system we can get the normal output but in control system we can get the desired output by controlling the various parameters of the system.
Control systems are classified into two major categories.
They are:
  • Open Loop Control System
  • Closed Loop Control system
Control Sytem Open Loop and Closed Loop
In an open loop control system, the output is not connected as feedback to the input. In this control system, the action is mainly independent of the desired output. A system in which the control action is totally independent of the output of the system is called as open-loop control system.
Here are some examples of Open Loop Control Systems:
  • Electric Hand Drier:
Hot output air comes out as long as you keep your hand under the machine irrespective of how much your hand is dried.
  • Automatic Washing Machine:
This washing machine runs for the pre-set time irrespective of whether the washing process is complete or not
  • Bread Toaster:
This toasting machine runs as per the defined time irrespective of whether toasting is completed or not
  • Simple in construction and Time
  • Less expensive
  • Easy maintenance
  • Stable operation
  • Convenient to use
  • Output may be inaccurate and it may change due to external and internal disturbances.
  • Outputs are unreliable. The output is inconsistent over time.
  • Any changes in output are not corrected automatically.
To achieve accurate results on the process, the output of the process needs to be monitored. If there is an error or an exact result is not obtained then the output is again fed back to the process for correcting the response through some parameters for getting the desired process.
The quantity of the output fed back to the system is called a “feedback signal” and the type of control system which uses feedback signals are called Closed Loop Control System.  Feedback means that some portion of the output is returned back to the process to form a part of the system.
Closed loop systems are designed to automatically achieve and maintain the exact output condition by comparing it with the actual condition. This is done by the error signal, which creates the difference between the output and the reference input. It is a fully automatic control system in which its control action is dependent on the output.
Block Diagram:
open vs closed loop
Here are some examples of closed-loop in real life.
  • Automatic Electric Iron:
Heating elements are controlled by the output temperature of the iron. The sensor reads the output temperature and compares it with the desired temperature. The error signal is generated with the help of desired temperature and output temperature. Then the error signal is given to the timer of the control system. This timer module will make the system on-off time of the heating element.
  • Water Level Controller:
Input water is controlled by the water level in the tank. A sensor is used to measure the level of water in the tank. The sensor gives the output in the form of voltage level which is proportional to the water level. Depending on the signal the solenoid valve will get open or close and does the required process in the system.
  • An Air Conditioner:
An air conditioner functions depending on the temperature of the room. The sensor in the conditioner checks the temperature of the room and generates an error signal by comparing it with the reference temperature. The error signal is read by the controller to switch on/off the air conditioner accordingly.
  • It is more accurate even in the presence of non-linearity.
  • Highly accurate as any error arising is corrected due to the presence of feedback signal
  • It facilitates automation.
  • The closed-loop control system is less affected by noise.
  • Very less response time and quick decision-making.
  • They are costlier.
  • Complicated Design.
  • Required more maintenance
  • More care is needed to design a stable closed-loop system.
  • Induction Motor using PLC Logic
  • Offline and Online UPS Systems
  • Modbus Driver for SCADA System
  • Comparison of PNP and NPN Sensors
  • Allen Bradley ControlLogix Architecture
What is DeviceNet?
Flowmeter Control Strategy
Why 4-20 mA Current Signal is used instead of Voltage Signal?
Types of Wireless Technologies in Industrial Automation
How-to do Security of SCADA Systems?
Difference between Process shutdown and Emergency Shutdown
PID Tuning Recommendations based on Process Dynamics
Types of Surge Control for Parallel Gas Compressors
Steady-State Process Gain
Network Operating System
How-to Create Instrument Loop Diagram (ILD)?
Network Cabling
Control Loops
Find the Fault in the Temperature Loop
System architecture
Types of System Architecture used in Industrial Automation
PROFIBUS is also a Master Slave protocol
Alarm and Trip Documentation
DeltaV System to Excel
How to Export Data from DeltaV System to Excel
Why 24 Volts DC Power Supply
Why 24 Volts DC Power Supply is used? – Industrial Automation Systems
Motor Controls
Design and Implement Motor Control – Electrical Engineering
Electronic Amplifiers Objective Questions
Counters and Timers Projects Using Analog Electronic Devices
Top 100 Counters and Timers Projects Using Analog Electronic Devices
Best Instrumentation Engineering Books to Purchase
Distributed Control System & Motor Control Center Interface Philosophy
How to Connect HART Communicator with DP Transmitter
15 HART Communicator Questions
Chocked flow
Control Valve Cavitation and Flashing
Critical Factors to Consider for Engineering Students to Ensure a Smooth Path
