Reading: Difference Between Industrial Computer (IPC) and Normal Computer (PC)
Inst Tools > Blog > PLC Tutorials > Difference Between Industrial Computer (IPC) and Normal Computer (PC)
In this post, we will understand the difference between an industrial computer (IPC) and a normal computer (PC).
Last updated: October 17, 2023 2:01 pm
Normal Computer (PC)Industrial Computer (IPC)Industrial Computer versus Normal Computer
Industrial Computer
PC has become a part and parcel of our life. In today’s world, it is difficult to do your work without a computer. Even in industrial world, a computer plays an important role in making job easier.
Earlier, a PLC was connected to an HMI for the graphical interface. HMI is used even now too. But then, SCADA developed. SCADA runs on a computer and integrates the overall system in a more efficient and larger way as compared to HMI.
Nowadays, due to the large requirement of data storage and record on daily basis, SCADA is mostly used everywhere as compared to HMI; though it is costlier than HMI.
In a control room area or office area, the PC is installed; where the SCADA software runs to communicate with the overall system.
But, with a normal PC, comes a computer desk, keyboard, mouse, stabilizer, CPU, and monitor. This increases the area required for installing a PC.
Also, you cannot set up a normal PC near the PLC control panel; as it increases the space consumption of the panel area.
Also, if a user wants to use the nearby area of the panel for some other purposes, then he will feel the area crunch due to the normal PC which is running there.
All this makes the use of an industrial PC more affordable and efficient as compared to a normal PC.
An industrial PC (IPC) is the same as an HMI; single standalone unit display, but with a CPU embedded in it.
You can mount it on the control panel in the same fashion as an HMI. So, you can imagine how much it reduces the cost of the system and also the area consumption.
The main difference which separates an industrial computer (also called IPC) from a normal PC is it’s design and construction.
IPC’s are rugged in nature and are more useful in an industrial environment, which protects them from dust, water, debris, fire, shock, or vibration.
Industrial PC can also withstand extreme temperature and humidity with ease. If you are using a normal PC instead of this, you will require another enclosure to cover the PC with additional safety elements. This will instead increment the size of the system more and make the area a very bulky one.
IPC’s also have added protection against electromagnetic interferences and high radio frequencies. This will not impact the system integrity for data transmission.
It is the same as a normal PC in terms of software functionalities. You can do all the tasks and install all the software stuff the same way as you perform in a normal PC. So, apart from this, you get more hardware reliability in an industrial environment, which will be lagged in a normal PC.
IPC’s have a higher level of IP rating, which offers protection against contaminants to IP65 as standard on all displays, for dust and water resistance.
If a normal PC runs into any hardware trouble, the cost of its repair and replacement would be more as compared to an industrial PC.
Also, as technology advances, if the need arises to expand the hardware, IPC’s would be more comfortable and easier to expand as compared to a normal PC.
This shows that an IPC is more useful for an industrial environment as compared to a normal PC.
  • Connect to the Siemens S7 PLC
  • PLC Multiple Choice Questions
  • Compact PLC versus Modular PLC
  • How to Upload Siemens PLC Programs?
  • Compare Online and Offline PLC Program
PLC Program for Automatic Bottle Rejection System
Create Ladder Diagram from Boolean Logic
How to Operate a Group of Induction Motors using PLC Logic?
Functions of SCADA
STL Programming – SET, RESET, ASSIGN
PLC vs PAC – Understanding the Key Differences and Similarities
Structured Text PLC Code for Sequential Process Data Storage
Problem on PLC, HMI, VFD, and Motor Circuit
Control Speed of Induction Motor using Analog Output of PLC
CX-Programmer Tutorial: 1 Button To Activate 4 Different Machines
Create an Application in HMI using Tia Portal
PLC Programming for Garden Sprinkler System
Schneider PLC Example: Control Lamps Sequences
Omron PLC programs
PROFIBUS is also a Master Slave protocol
SCL Language in Siemens Tia Portal
Motor ON OFF Logic in PLC
Two Tanks Filling using PLC
PLC Ladder Logic for Tanks Filling as per Priority
Sample Schematic Template for Systems Architecture Diagram
Midline output instruction
What is Midline Instruction in Siemens PLC?
How to troubleshoot the PLC Hardware faults
HART Communication Interview Questions
Induction Machines Multiple Choice Questions
Single Phase Semi-Converters Quiz
Control Valve Tubing
Instrument Tube Bending
Data Handling Instructions in PLC Programming
Identify which lamp in the following ladder-logic diagram
Identify High Flow Alarm and Low Flow Alarm?
Analog inputs in library
Design Process Graphics in Factory Talk View Studio with an Analog Input
Rotary UPS or Dynamic UPS
