Electrical engineering root cause analysis (RCA) related to the inability to test repaired HT motors in the workshop posed problems.
| Category: | Electrical |
| Equipment Type: | Motors |
Inability to Test Repaired HT Motors Problem
Providing a workshop 3.3 KV power supply is prohibitively expensive. Hence, the crew could not shop run test repaired 3.3 KV motors.
Solution
As a visiting rewinding shop engineer advised 3.3 KV Antifriction Bearing Motors self-start and sleeve bearings motors nudge start on 400 V supply. Both run at 10% lower than rated RPM, and.
Benefits Derived
Benefits Derived are as under:
- Low voltage shop testing dries the windings well and prevents flashes in the fleld
- Enables correcting defects e.g. vibrations, poorly fitted bearings etc. and correcting
- The above prevent the hassles: shop to field and return wasteful transport, work permits, HT connections making and breaking etc.
Author: S. Raghava Chari
- Problems with Switchgears
- Transformer Problem Solved
- Aluminum Cable Terminations
- What is a Magnetic Contactor?
- Arc Fault Breaker Problem Solved
