Reading: Impact of Flow Meter Accuracy
Inst Tools > Blog > Flow Measurement > Impact of Flow Meter Accuracy
In flow meter, a number of terms are important to consider, which include Repeatability, Uncertainty, Accuracy, and Turndown.
Last updated: November 1, 2023 7:35 am
Flow Measurement
3 Comments
When discussing about flow metering, a number of terms are important to consider, which include Repeatability, Uncertainty, Accuracy, and Turndown, which are commonly used.
Repeatability of Flow MeterUncertainty of Flow MeterAccuracy of Flow MeterPercentage of measured value or actual readingPercentage of full-scale deflection (FSD)Comparison of Flow Meter Accuracy
This describes the ability of a flow meter to indicate the same value for an identical flow rate on more than one occasion.
It should not be confused with accuracy i.e. its repeatability may be excellent in that it shows the same value for an identical flow rate on several occasions, but the reading might be consistently wrong (or inaccurate).
Good repeatability is important. However, this does not dilute the importance of accuracy under any circumstances.
The term ‘uncertainty’ is now becoming more commonly referred to than accuracy.
This is because accuracy cannot be established, as the true value can never be exactly known.
However ‘uncertainty’ can be estimated and an ISO standard exists offering guidance on this matter (EN ISO/IEC 17025).
It is important to recognize that it is a statistical concept and not a guarantee.
For example, it may be shown that with a large population of flow meters, 95% would be at least as good as the uncertainty calculated. Most would be much better, but a few, 5% could be worse.
This is a measure of a flow meter’s performance when indicating a correct flow rate value against a ‘true’ value obtained by extensive calibration procedures. The subject of accuracy is dealt with in ISO 5725.
The following two methods used to express accuracy have very different meanings:
For example, a flow meter’s accuracy is given as ±3% of the actual flow.
At an indicated flow rate of 1000 kg/h, the ‘uncertainty’ of actual flow is between:
1000 – 3% = 970 kg/h
And
1000 + 3% = 1 030 kg/h
Similarly, at an indicated flow rate of 500 kg/h, the error is still ±3%, and the ‘uncertainty’ is between:
500 kg/h – 3% = 485 kg/h
And
500 kg/h + 3% = 515 kg/h
A flow meter’s accuracy may also be given as a percentage of full-scale deflection FSD, which means that the measurement error is expressed as a percentage of the maximum flow that the flow meter can handle.
The error stated in percentage FSD tends to be smaller than the error as a percentage of actual reading.
For this example, a value of ±0.3% FSD will be used.
As in the previous case, the maximum flow = 1000 kg/h.
1000 kg/h – 0.3% = 997 kg/h
And
1000 kg/h + 0.3% = 1003 kg/h
At an indicated flow rate of 50 kg/h, the error is still ±3 kg/h, and the actual flow is between:
50 kg/h – 3 kg/h = 47 kg/h an error of – 6%
And
50 kg/h + 3 kg/h = 53 kg/h an error of +6%
As the flow rate is reduced, the percentage error increases.
flow meter accuracy calculation
A comparison of these measurement terms is shown graphically in the above figure.
  • Advantages of Flow Meter
  • Magnetic Flow Meter Corrosion
  • What is an Orifice Flange?
  • Displacement Flowmeters
  • What is a Dall Tube Flowmeter?
Pitot Tube Working Principle
Coriolis Mass Flow Sensor Theory
Types of Flow Meters MCQ – Instrumentation and Control
Flare Ultrasonic Flow Meter – SOPAS Engineering Tool
Target Flow Meter – Working Principle, Advantages, Disadvantages
3 Comments
  • AYON BHOWMIK says:
    October 26, 2016 at 5:55 am
    Dear sir,
    How can i save the page in pdf format. In the earlier version of the website there was option to download the page but now it is not available.
    Thanks and regards
    Ayon Bhowmik
  • Dan M says:
    August 21, 2018 at 3:52 pm
    At an indicated flowrate of 50 kg/h, the error is still ±3 kg/h, and the actual flow is between:
    50 kg/h – 3 kg/h = 47 kg/h an error of – 6% —- It is error 0.6 % or 6%?
    And
    50 kg/h + 3 kg/h = 53 kg/h an error of +6% —- It is error 0.6 % or 6%?
    Please clarify.
    Best Regards
  • Sandeep Zurao says:
    January 5, 2022 at 10:48 pm
    My instrument range is 0 – 74 ln/min and Accuracy is (0.5% Rd +0.1 % FS) so tell me what is acceptable accuracy in that case?
Basics of Orifice Plates
Flow Meter K-factor and Calculations
Rotameter Working Principle and Animation
All About Variable Area Flow Meters
Why Viscosity is Not Included in the Orifice Equation?
Facts About Orifice Flow Meters
Importance of Flow Meter Turndown Ratio
Turbine Flowmeter Parts
What is a Turbine Flow Meter?
Comparison of Venturi and Orifice flow meterComparison of Venturi and Orifice flow meter
Integral Orifice Parts
What is Integral Flow Orifice Assembly?
DP type Flow Transmitter Calibration
DP type Flow Transmitter Preventive Maintenance and Calibration
Square root extractor Parts
What is a Square Root Extractor? – DP Flow Measurement
Thermal Mass Flowmeter Principle
Thermal Mass Flow Meter – Principle, Advantages, Applications
Laminar Flow Meter Working Principle
Venturi Flow Meter Theory
Basics of Venturi Flow Meter
Location of Measurement Displays
electric motor actuator principle
What is a Electric Motor Actuator ?
Analog Electronics Objective Questions – Set 4
Phosphate Dozing System
Phosphate Dozing System Problems
toroidal conductivity probe principle
Electrodeless Conductivity Probes Principle
What is Instrument Air Manifold
What is Instrument Air Manifold ?
Needle Valve Schematic
How Needle Valve Works ?
H2 S and Total Sulfur Using Lead Acetate Principle
H2S Measurement Using Lead Acetate Principle
