Reading: How to Configure PID Controller in Various Schneider PLCs?
Inst Tools > Blog > PLC Tutorials > How to Configure PID Controller in Various Schneider PLCs?
In this post, we will see how to configure PID controller in various Schneider PLCs (programmable logic controller)
Last updated: September 28, 2022 4:13 pm
Schneider PLC PID ControllerMachine Expert BasicMachine ExpertUnity Pro
PID configuration differs in various PLCs. In this post, we will see its configuration in Schneider PLC’s.
Basically, we will cover three types of PLC software in Schneider
  • Machine Expert Basic
  • Machine Expert, and
  • Control Expert
Let us have a detailed look at this three software.
Refer to the below images by step. We will configure a simple PID here and not go into advanced types.
In the first image, as shown, click the PID tab in the Tools tab. A dialog window will open at the bottom.
Click the square symbol in the configuration menu as shown.
PID Controller in Machine Expert Basic
In the second image, as shown, after clicking the square symbol, a popup window will appear as shown. In the window, there are five tabs – General, Input, PID, AT, and Output.
In the General tab, select the type of action. In the Input tab, enter a memory address in the Measure tab. This is nothing but the process variable which is to be controlled.
In the PID tab, enter the memory addresses for set-point, Kp (P), Ti (I), Td (D), and Ts (Sampling Period). Also, select the corrector type.
In the Output tab, enter the memory address for analog output. This is the output of PID.
Also, select the action type, select whether you need to enable or disable the output limits and select whether you need to enable or disable manual mode.
PID Assistant
In the third image, as shown, write a rung as shown. This needs to be written to enable the PID logic. If this rung is not written, then that particular PID will not be enabled.
how to configure PID in various Schneider PLC
The memory addresses that you defined in the PID block must be configured in an external HMI also. This is required for allowing the operator to set the required parameters directly from HMI.
Once you have configured the PID, you can check it by downloading it in PLC. Remember that it does not work in simulation mode. You need to physically connect a PLC.
Depending on the set parameters and the process variable, you will directly get the PID output in the memory address that you had defined in the analog output tab.
Machine Expert
In this software, it is relatively easier to configure PID. You need to take a PID block from the library in the section you are writing. Then, assign addresses to the input pins as shown in the figure.
PID block from the PLC library
It would be better if you assign Kp (P) and Tn (I) as real type variables. The more accurate you set in decimals, the more accurate will be the output.
The remaining variables can be assigned as integer-type variables. If you require manual mode, then you just need to enable it by assigning a variable in manual input and assigning a manual set-point in Y_MANUAL input.
You can reset the PID if you need it by assigning a variable as shown. The PID function will be reset and the output will be given in a fresh way.
Unity Pro
Then, assign addresses to the input pins as shown in the figure. Here, there are two inputs that are different as referred to what we saw earlier – Mode and Para.
Schneider PLC PID
Basically, they both are structure variables. You have to assign values to each element of the structure as shown in the above figure.
In this way, we got to know how to configure PIDs in all three different types of software.
  • DCS Troubleshooting
  • Commissioning of DCS System
  • DCS Control System Spares
  • Yokogawa DCS Architecture
  • DCS System Layout
PLC Program for Water Level Control Logic
What is RS Linx? Types of Software in Rockwell Automation
Siemens PLC Tia Portal – OB100 Start-up Organization Block
#6 PLC Best Practices – Validate Timers and Counters
What is Interface Module in Siemens PLC?
What is Complementary Split Range Control (CSRC)?
Web-based SCADA HMI Software
How to Convert an Electrical Diagram into PLC Program?
Control Algorithms in PLC Programming
PLC Light Sequence Control using Bit Shift Registers
Motor Feedback Fail Logic in PLC
PLC Multiple Outputs Configuration
PLC Programming Example on Bottle Line Control
Global Data Blocks in PLC
What is a Data Block? Global Data Blocks in PLC
Omron PLC Example
Design a Water Pump PLC Program using CX-Programmer
PLC Ladder Logic Chemical Mixing Process
Chemical Mixing Process using PLC
PLC Ladder Logic Questions and Answers
Grounding Electronic Equipment
Importance of Grounding Electronic Equipment
PLC Program Backup in Siemens Tia Portal
How to Take Program Backup from Physical PLC? – Siemens PLC
Function Block Program Simulation
Vibration Sensor
Vibration Probes Questions and Answers
Simplified Induction Motor - Cross Section
Siemens Standard Drives Application Handbook (PDF)
Process Shutdown
Difference between Process shutdown and Emergency Shutdown
What Effect on Hydrostatic Level Transmitter if Liquid Density Changes?
hipps
What is High Integrity Pressure Protection System?
Density-Measurement-using-DP-Transmitter-for-open-tank
Density Measurement for Open Tank with Constant Level Application
limit-switch-works
How Limit Switch Works ?
Reliability Techniques for Analyzing Fault Tolerance in Industries
