Reading: PLC Simulator using Excel
Inst Tools > Blog > Excel Tools > PLC Simulator using Excel
Now you can do the programmable logic controller ladder logic simulations using excel. Free download the PLC simulator now.
Last updated: September 8, 2022 1:12 pm
Excel Tools PLC Tutorials Software
3 Min Read
PLC SimulatorHow to do the PLC Simulation using Excel?
Simulate your basic PLC programs using an excel file on your computer. This tool is very useful for beginners to learn and practice the programmable logic controllers ladder logic functions.
PLC Simulator
The above animation shows the simple latching circuit simulation using the ladder logic programming using an excel file.
You have to download the PLC excel simulator file.
Open the excel file. A sample program in excel shown below
Free Download PLC Simulator using Excel
Now enable the macros in the excel file. Follow the below animation.
How to Use PLC Simulator using Excel App
Now your excel file is ready to write your own PLC program.
On the left side, you can find the empty rails and rungs.
Click on each cell where you want to add your PLC instruction.
A drop-down menu will appear, select the required PLC instruction from the menu. See the below sample PLC program.
Ladder Logic in Excel
You have to select a blank line if you don’t use the specific cell in the excel file.
Write your PLC program. Note this excel file supports only limited functions.
In the middle, you can see the IO table where you can see the details of tags, type of input, description, and the status of the inputs & outputs.
See the left-side table in the below image.
PLC Programming in Excel File
Now a small operation panel available for the users to operate some of the inputs during the running of the PLC program. See the Tag & Operate table on the top right side in the above image.
You can change the timer instruction settings from the timer table, available on the right side of the above image.
Once you are done with your PLC program editing then you have to run the PLC.
Here this PLC has two modes. One is idle and the second is running.
Click on the “Download to PLC & Run” button to start your PLC simulation.
Please note, this PLC simulator is useful for beginners who want to do some practice with the PLC ladder logic programming without the need for large software applications.
We always recommend practicing your PLC programs using any of the popular PLC software like Tia portal, Simatic manager, RS Logix 500, etc.
Source:
This simple PLC simulation software was designed by “Nitin Mehta”. Visit the engineers-excel website for more details.
Read Next
  • Allen Bradley PLC Course
  • InTouch SCADA Course
  • Wincc SCADA Course
  • PLC Introduction Course
Heating and Mixing of Products using PLC Example Tutorial
Advanced Skills Required for a PLC Programmer to Get a Job
PLC Ladder Logic for Sensor Scaling with Offset
3 to 8 Line Decoder PLC Ladder Diagram
Types of Digital Outputs in PLC
Instrumentation Earthing
Micro PLC Hardware Configuration
Advanced PLC Programming for Defective Parts Sorting
Functional Block Diagram in PLC for Oil and Water Process
CX-Programmer Tutorial: 1 Button To Activate 4 Different Machines
How Could FB and FC Make Me Professional PLC Programmer?
PLC engineering software
How to Download GX Works? Mitsubishi PLC Software
ON DELAY TIMER AS OFF DELAY TIMER
How to export in Vijeo Designer
Vijeo Designer software – Import and Export
Difference between Signal Cables and Control Cables
Analog Instruments
PLC Programming for Tank Farm Management
HMI
HMI Simulation for PID Controller
PID Controller Output Types – PID_PWM and PID_Output
Thermodynamic cycle
Thermodynamic Cycles in Power Plant
Industrial Automation Systems
Remote Functions in Industrial Control Systems (ICS)
What is Partial Stroke Test
What is Partial Stroke Test?
Introduction to SCADA
Elevator PLC Ladder Logic
gate-valve-principle-animation
Basics of Gate Valves
Elevated Span and Suppressed Span
DP Level Transmitter Elevation and Suppression Corrections
Electrostatics Objective Questions and Answers
225+ Electrostatics Objective Questions and Answers
