  • Ask
  • Videos
  • Q & A
      • Practical Questions
    • MCQ
      • Instrumentation MCQ
      • Electrical MCQ
      • Electronics MCQ
      • Control Systems MCQ
      • Power Electronics MCQ
      • Multiple Choice Questions
  • EE
      • Electronics Q & A
      • Electronic Basics
      • Electronics Animation
      • Electrical Q & A
      • Electrical Machines
      • Electrical Animation
      • Power Systems
      • Switchgear & Protection
      • Transmission & Distribution
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Process Fundamentals
    • Videos
Reading: Flow Standards
  • PLC Tutorials
  • Control Systems
  • Ask
  • Videos
  • Q & A
    • MCQ
  • EE
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Videos
Inst Tools > Blog > Flow Measurement > Flow Standards
Flow Standards
Continuous flow measurement are inferential, that is, we measure flow indirectly by measuring some other variable (such as pressure, time) directly.
Last updated: November 2, 2023 9:37 am
Flow Measurement
Most forms of continuous flow measurement are inferential; that is, we measure flow indirectly by measuring some other variable (such as pressure, voltage, or frequency) directly. With this in mind, we may usually achieve reasonable calibration accuracy simply by calibrating the primary sensor and replacing the flow element (if inspection proves necessary).
Flow Standards
In the case of an orifice plate used to measure fluid flow rate, this would mean calibrating the differential pressure transmitter to measure pressure accurately and replacing the orifice plate if it shows signs of wear.
In some cases, though, direct validation of flow measurement accuracy is needed. Most techniques of flow rate validation take the form of measuring accumulated fluid volume over time. This may prove to be complicated, especially if the fluids in question are hazardous in any way, and/or the flow rates are large, and/or the fluid is a gas or vapor.
For simple validation of liquid flow rates, the flow may be diverted from its normal path in the process and into a container where either accumulated volume or accumulated weight may be measured over time. If the rate of flow into this container is constant, the accumulated volume (or weight) should increase linearly over time.
The actual flow rate may then be calculated by dividing the change in volume (ΔV ) by the time period over which the change in volume was measured (Δt). The resulting quotient is the average flow rate between those two points in time, which is an approximation of instantaneous flow rate:
liquid flow rates
If a suitable vessel exists in the process with level-measuring capability (e.g. a liquid storage vessel equipped with a level transmitter), you may apply the same mathematical technique: use that vessel as an accumulator for the flow in question, tracking the accumulated (or lost) volume over time and then calculating ΔV/Δt .
The accuracy of this technique rests on some additional factors, though:
  • The accuracy of the level transmitter (as a volume measuring instrument!)
  • The ability to ensure only one flow path in or out of that vessel
The first condition listed here places significant limitations on the flow calibration accuracy one can achieve with this method. In essence, you are using the level instrument as the “test gauge” for the flow instrument, so it needs to be high-accuracy in order to achieve even reasonable accuracy for the flowmeter being calibrated.
A more sophisticated approach for direct flow validation is the use of a device called a flow prover. A “flow prover” is a precision piston-and-cylinder mechanism used to precisely measure a quantity of liquid over time.
Process flow is diverted through the prover, moving the piston over time. Sensors on the prover mechanism detect when the piston has reached certain positions, and time measurements taken at those different positions enable the calculation of average flow (ΔV/Δt ).
  • What is an Orifice Flow Meter?
  • Flow meter Turndown Ratio
  • V Cone Flow Meter Principle
  • Oval Gear Flow Meters
  • Intrusive & Non-intrusive
Magnetic Flowmeter vs. Turbine Flowmeter – Comparison
What is a Thermal Flow Meter?
Configure the Instruments in Flow Control Loop
Basics of Restriction Orifice (RO) – Types, Applications, Standards
Difference between Transit time and Doppler Ultrasonic Flow Meter
  • Iqbal Raza Khan says:
    December 11, 2023 at 10:17 am
    Excellent Knowledge
208kSubscribersSubscribe
Recent Comments
Related Articles
Coriolis Mass Flow Meter Working Animation
Coriolis Meter Explained with Animation
Orifice Taps
Orifice Plate Tapping – Orifice Plate Taps
Metal tube Variable Area Flowmeters Principle
Metal Tube Variable Area Flow Meters Principle
Differential Pressure and Pressure Loss
What is Differential Pressure and Pressure Loss?
microwave flow detector applications
Microwave Flow Sensor – Working Principle and Applications
Why Turndown Ratio is important when Selecting a Flow Meter?
Sick Flow meters
Flare Ultrasonic Flow Meter – SOPAS Engineering Tool
Mass Flow Calculations of flow measurement
More Articles
Automation in Logistics Industry
Automatic Motor Forward and Reverse Control using Timer
Unspecified CPU in Tia Portal
How to Add Unspecified CPU in Tia Portal?
Yokogawa DCS CPU
System Cabinet Health Checks – PLC and DCS Industrial Automation
What is FAT and SAT?
Working Principle of Water Chillers
HVAC Water Chillers Principle
Combination Electrode Questions & Answers
MicroElectronics and Integrated Circuits Objective Questions and Answers
