Reading: Difference between Fieldbus, Profibus and HART Protocols
Inst Tools > Blog > Control Systems > Difference between Fieldbus, Profibus and HART Protocols
Last updated: September 19, 2024 2:03 pm
R Jagan Mohan Rao
Control Systems
7 Comments
6 Min Read
The method of representing, encoding, and transmitting the data is called the protocol.
Fieldbus, Profibus and HART ProtocolsCommunications Subsystem DifferencesBasic Network DifferencesCompare Fieldbus ProtocolsSummary
At the field level, the dominant protocols for process instruments are HART, FOUNDATION Fieldbus H1 and PROFIBUS PA.
Foundation Fieldbus is an all-digital, serial, two-way communications system that serves as the base-level network in a plant or factory automation environment.
The FOUNDATION Fieldbus specification is uniquely different from other networking technologies. Foundation Fieldbus is not only a communications protocol but also a programming language for building control strategies.
In FF, one of the possibilities that a standard programming language and powerful communications features enable is the ability to perform control that is distributed into the field devices rather than a central controller
Distributed Control System Architecture for Foundation Fieldbus Field Instruments
For example, it is common for the Fieldbus valve positioner to act as a controller for the loop as it is part of. PID controller can implement in DCS system ( also called as Host or Remote systems). In fieldbus devices, PID controller function can also implement in fieldbus device configurations (also called as local system). So, for fieldbus devices we can implement the PID function either in DCS system or in fieldbus device or at both places.
In fieldbus, It executes the PID function block but only for its own loop, not for other loops. This new architecture based on field device capability is called Field Control System (FCS) and is an alternative to DCS.
Basics of FOUNDATION Fieldbus
Foundation Fieldbus was originally intended as a replacement for the 4-20 mA standard, and today it coexists alongside other technologies such as Modbus, Profibus, and Industrial Ethernet.
A typical fieldbus segment consists of the following components.
  • H1 card – fieldbus interface card (It is common practice to have redundant H1 cards, but ultimately this is application specific)
  • PS – Bulk power (Vdc) to Fieldbus Power Supply
  • FPS – Fieldbus Power Supply and Signal Conditioner (Integrated power supplies and conditioners have become the standard nowadays)
  • T – Terminators (Exactly 2 terminators are used per fieldbus segment. One at the FPS and one at the furthest point of a segment at the device coupler)
  • LD – Linking Device, alternatively used with HSE networks to terminate 4-8 H1 segments acting as a gateway to an HSE backbone network.
  • And fieldbus devices, (e.g. transmitters, transducers, etc.)
The HART protocol does allow several devices to be multi-dropped on a single pair of wires, but this is a capability infrequently explored because of the low update speed, typically half a second per device.
For a vast majority of installations HART devices are connected point to point, that is, one pair of wires for each device and a handheld connected temporarily from time to time for configuration and maintenance.
Both FOUNDATION Fieldbus H1 and PROFIBUS PA are completely digital and even use identical wiring, following the IEC 61158-2 standard.
Distributed Control System Architecture for 4-20mA Field Instruments
The communications interfaces required by a host are different for the pure digital communication in FOUNDATION Fieldbus and PROFIBUS on the one hand and for the hybrid of analog and digital for HART on the other.
For PROFIBUS and FOUNDATION Fieldbus a single integrated network architecture is used for I/O as well as for asset management.
The HART and PROFIBUS technologies do not have a control strategy programming language. FOUNDATION Fieldbus has a standard function block language and publisher/subscriber communication.
FOUNDATION Fieldbus has a number of useful communication features not offered by HART protocol. These include automatic device detection and address assignment for Plug-and-Play installation and time synchronization.
As HART communication speed is low it relies on the analog 4-20 mA signal for real-time process I/O and a HART device is therefore connected point to point.
In most systems, the 4-20 mA only connects to conventional I/O modules via individual wires, and any communication with the device is performed with a temporarily connected portable hand communicator. Field devices, and host, are integral parts of the system.
PROFIBUS has PROFIsafe for communication between instruments in safety- related systems, which FOUNDATION and HART do not offer
Distributed Control System Architecture for Profibus Field Instruments
It is technically possible to use FOUNDATION Fieldbus or PROFIBUS PA technology in any kind of system architecture. Systems based on conventional architecture can also benefit from the wire reduction made possible by field-level networks.
Compare Fieldbus, HART, Profibus
Summary
  • Fieldbus systems are complex, more training is needed, HART systems are easily understandable.
  • Field bus test devices are more complex.
  • Price of field bus devices are higher than HART enabled.
  • Fieldbus vs 4-20mA
  • What is HART Protocol ?
  • Foundation Fieldbus Logics
  • 7 OSI Layers of Communication
  • What is HART- IP ?
Commissioning Checklists for Industrial Automation Systems
Liquid Flow Control Loop Controller Action
Python in Industrial Automation and Control Systems
Troubleshooting with Loop Calibrator
Process Dynamics and PID Controller Tuning
Derivative (Rate) Control Theory
7 Comments
  • Faizal Raazy Z says:
    January 13, 2019 at 10:44 am
    Very good
  • Mathias udoudo says:
    February 21, 2020 at 11:04 pm
    I believe I learned a lot from this publication thanks
  • marita timothy says:
    February 24, 2020 at 3:41 am
    i have learn from the publication.
  • Gondai Mlambo says:
    February 25, 2020 at 7:05 pm
    This quite inspiring I have learnt a lot I need to purse Automation how best can I do it
    Thank you
    Regards
    Gondai Mlambo
  • Md. Rajon mahmud says:
    May 6, 2020 at 3:46 am
    I didn’t miss any articles that were published on this site. Briefing excellently maximum time. Thanks.
    Md. Rajon mahmud, Bangladesh.
  • Mohammad Ahmad says:
    June 20, 2023 at 10:56 am
    this article is very helpful to me
    Thanks a lot
  • Akuroseokika says:
    June 23, 2023 at 9:41 pm
    I really interested for the instrumentation and control processes and procedures on how to calibrate a device and control:thanks
What is a Signal Isolator? Principle, Advantages, Disadvantages
Identify Level Control Loop Tuning Problems
DCS Program to Maintain Draft in Furnace
Difference between Feedback, Feedforward, and Cascade Control?
Steps to Import PlantPAx Add-On Instructions in Studio 5000
Limit Controls : High Limit & Low Limit Functions
Alarms to Annunciator
Basics of Alarms and Trips
Split Range Control for Temperature Control Application
Open Loop and Closed Loop System Questions
Centralized vs Decentralized Automation Systems
Internet of Things (IOT)
History of Internet of Things (IOT)
Single Line Diagram of UPS System
How Engineers Effectively do Problem-solve and Troubleshoot
List of 100 Questions Related to Distributed Control Systems (DCS)
List of 100 Distributed Control Systems Questions (DCS)
light-emitting-diode-theory
Light Emitting Diode Operation
Current Limiting Resistor
Resistors Principle & Applications
Free WinCC SCADA Training Course
Free SCADA Training Course
HART Layers vs OSI Layers
HART Communication Tutorial Part 3
how-to-find-resistor-value
Limitations of Resistors
What is a Floating License - Automation Software Systems
What is a Floating License? – Automation Software Systems
Network Theorems Objective Questions and Answers
Electromagnetism Objective Questions and Answers
200+ Electromagnetism Objective Questions and Answers
