Reading: Communication between Factory IO and Siemens Tia Portal
Inst Tools > Blog > PLC Tutorials > Communication between Factory IO and Siemens Tia Portal
Last updated: March 4, 2021 12:06 pm
This article is about communication between Siemens TIA PORTAL and Factory IO. You can use actual PLC to check your logic. You can also create an animation as per your actual layout and test the logic.
Here, I don’t have actual PLC so, I will use Siemens simulator to test the logic.
I will explain communication with a simple example that contains START, STOP switches as inputs, and conveyor as OUTPUT which is to be controlled from inputs. I will also light the lamp to indicate the START and STOP status of the conveyor, lamps are OUTPUTs here.
So, I will use two INPUTs and three OUTPUTs in my example. Let’s begin with communication.
Step 1:
First, open the TIA portal. Enter into the Programming environment.
First, I will create a symbol table to define Input and Output tags as shown in the below window.
Communication with Factory IO
Step 2:
Now write the PLC program shown below to turn ON the conveyor motor.
PLC program to turn on the conveyor
Step 3:
Now, load this program in a simulator and put it in to run mode.
PLC Program in Run Mode
Step 4:
Now, open Factory I/O software.
You can create a new scene or can use a scene that is already created in the factory I/O.
Factory IO
Step 5:
Here, as I want to turn ON conveyor, I have to create a new scene as shown in the below figure.
As I aim to show you communication my animation is too simple.
I have added START, STOP pushbutton, and conveyor as per Input and Output, which are used in my PLC programming.
Factory IO PLC programming
Step 6:
Now, Go to the file menu and select the driver to configure the simulator.
Step 7:
Open the drop-down menu and select “Siemens S7 PLCSIM”. Click on it to add the I/O module.
Siemens S7-PLCSIM
Step 8:
The following module will be added. Now, click on “configuration” to configure module which we have used in our PLC program.
Configuration of Factory IO Software
Step 9:
In the configuration window, select the checkmark to automatically connect PLC.
In “I/O points” choose the starting address of your PLC Input and output. “Offset” represent the starting address which is in our case start from “0 (zero)” for Input and “4” for Output.
“Count” represents the number of Inputs and outputs available in the PLC module.
Automatically connect PLC
Step 10:
After configuration, go back to the driver window. Now drag and drop Inputs and Outputs which we have used in our programming.
Simply drag Inputs or outputs from the Sensor and Actuator tab and put them into the module as shown in the below window.
Factory IO Sensor and Actuator
Step 11:
Click on the “connect” icon to connect it with the simulator.
Connect Factory IO with Simulator
Step 12:
On successful communication, the right checkmark will appear next to the driver option.
Factory IO communication
Step 13:
Now test the logic. As I have used pushbutton, if I press it and release it, due to latching in the program, it won’t stop, light and motor both will energize continuously.
Test the logic in Factory IO
Step 14:
As soon as I press the stop button, it stops the motor and the stop lamp will turn ON.
Author: Suhel Patel
  • Extended Timer Logic in PLC
  • Pulse Generation Timer
  • Allen Bradley RSLogix
  • FIFO Instruction in PLC
  • Motor Ladder Logic in PLC
PLC Mixing Process with Adjustable Timer and Valve Control
Which Language is Best for PLC Programming?
Omron PLC for Product Painting with Integrated Weighing System
PLC Programming Best Practices and Tips
  • Moshi says:
    September 22, 2023 at 11:03 am
    I tried to connect it says
    “It seems that S7-PLCSIM V13/V14 is not running. Please start it and try again.”
PLC Program – Controls Conveyors ON and OFF Sequence
Getting to Know the LED Indications on GE Make PLC
Write a PLC Program for Selector Machine using Structured Text
Factory I/O PLC Automation Training Course (Free)
PLC Program for Controlling a Water Pump with 3 Power Sources
Machine Tool and Coolant Control: PLC Ladder Logic Design
Laws of Boolean Algebra using Ladder Logic
OB10 Time of Day Interrupt
Tia Portal – OB10 Time of Day Interrupt Organization Block
PLC automation timers and counters
Auto Sugar Bag Filling Station
Pumping System in Industrial Automation
Basic Pumping System Application Used in Industrial Automation
What is Loop Checking
What is Loop Checking?
PLC Data comparison instructions
PLC Data Comparison Instructions
Relay Symbols
Relay circuits
Off load Tap Changer Principle
Transformer Tap Changing Working Principle
Classification of Transmission Lines
Transformers Coolers Weld Joints Oil
Transformers Coolers Weld Joints Oil Oozes Were Eye Sores
Instrument Junction Box Specification
Advantages & Disadvantages of Oil Circuit Breakers
