Reading: How to Export Data from WinCC Runtime Advanced into Excel using VB Script
Inst Tools > Blog > PLC Tutorials > How to Export Data from WinCC Runtime Advanced into Excel using VB Script
In this article, you will learn how to export data from Siemens WinCC Runtime advanced into Microsoft excel using VB script.
Last updated: September 28, 2022 2:18 pm
Greesh Maheshwari
2 Comments
Data reporting is a very crucial process in Industrial Automation. These data can be of any type such as Batch Data, Alarms log, Process Data, Utility Data, etc.
What is VB Script?Why do we need to use any scripting language in SCADA?Export Data from WinCC Runtime Advanced into Excel
This article will focus on the usage of VB Script to log data into an excel file.
What is VB Script?
  • VB Script is programming language developed by Microsoft.
  • It is very commonly found scripting language in various SCADA System such as Siemens, Schneider, Indusoft, AVEVA etc.
  • Many a Times when you want to develop sophisticated and perfect SCADA with many features then to enable that features you have to use scripting language.
  • For Scalability of project.
  • Unlimited possibilities.
First, make these tags in the tag table.
Here we have added three tags as an example Flow, Pressure, Temperature.
Tag named excel row is for use of VB Script counting.
WinCC RT Advanced
Add a new VB Script and copy the code from this article.
Excel Reporting in Siemens SCADA
This is the complete code.
WinCC Professional Excel Report
Download VB Script: Download Now
Path of the Excel file.
Write data to Microsoft Excel file by WinCC
Excel file Starting cell number of every tag. Change this if you change the Excel file format.
WinCC TIA VB Script data logging to excel
Change these tags if you want to add new tags and do not change any other part of the code if you don’t have any clear idea.
Siemens WinCC VBscript
Configure the SCADA Screen with the following items as shown in the image.
WinCC data logging
For sample reporting, I have configured this button to trigger the excel data. Whenever I press the button new data is inserted into the excel report.
data logging in Wincc advanced
Configure the Alarm window with the following setting, it will be helpful to find any error in the script and troubleshoot it, if the code does not work as expected.
Configure the Alarm window in WinCC Scada
This Excel file formatting. You can change any format you like. But keep in mind the cell number.
SIMATIC WinCC Logging
Now close the Excel file and Start WinCC Runtime in Simulation mode.
Start Simulation in WinCC SCADA
Enter any values in the IO- Field and after that press the “Insert New Data” Button.
data logging functions of the WinCC
Now you can check the new data is inserted into the excel file.
Keep in mind to close the excel window whenever new data is added, otherwise, the script won’t work and result in an error.
Wincc data logging in Excel
EndNote
VBScript has unlimited possibilities to make your SCADA work like charm. So, use this script for your practice and log any data in excel.
  • What is Alarm Shelving?
  • Why 24 Volts DC Power Supply?
  • Factory Acceptance Test of PLC
  • Control Two Motors in Sequence
  • Electromagnetic Noise Interference
FactoryTalk View Studio – Import and Export Tutorial
PLC Timers Program
PLC Counters Program
Programmable Logic Controller Questions and Answers
2 Comments
  • behzad says:
    September 13, 2023 at 12:52 pm
    I tested this code, it isn’t save data in columns. only save in rows.
  • Rolando says:
    February 5, 2024 at 5:01 pm
    Good morning everyone. Will anyone know where the database error problem lies, when executing scripts to access SQL server, from a Wincc RT Professional client in the TIA portal.
    The Client/Server interaction is carried out perfectly, all screens, menus, etc. are displayed. The problem occurs when an event is executed that needs to read from the SQL database through a script.
    I clarify this, this also happens for the configuration with the web navigator. The scripts works ok on server. Greetings
How to Simplify PLC Coding Using Karnaugh Maps?
Product Sticker Machine with Weighing PLC Program
Edge Detection in PLC Programming
DC Injection Braking in VFD
Making Multi Way Switches using PLC
Schneider PLC Example Program for Star-Delta System
Studio 5000 Tutorial: PLC Programming for Digital Alarms
PLC Timer Application in Security Camera Recording
PLC Program using Logic GATEs
PLC Logic GATE Program
MCQ on PLC (Programmable Logic Controller)
Codesys function block example
Create a User-Defined Function Block in Codesys
Siemens TIA Portal program blocks
Tia Portal – Optimized and Standard Data Block Access
Basics of PID Controllers
PID Controllers in Closed Loop Control Systems – PLC Basics
PLC Wiring
How to Check the Continuity of Protective Conductors
How to Check the Continuity of Protective Conductors?
The Control Valve Stroke Test Procedure
PLC program to control a water pump
PLC Program to Control a Water Pump
Series Air Fuel Combustion Control
Combustion Control – Series and Parallel Air-Fuel Ratio Control
Motor Losses and Efficiency Quiz
Hydraulic Load Cell Principle
SCADA Systems
SCADA Systems
Pneumatic Transmitter
Pneumatic Level Transmitter Calibration Table
