Reading: Difference Between CompactLogix and ControlLogix
Inst Tools > Blog > PLC Tutorials > Difference Between CompactLogix and ControlLogix
Learn the difference between CompactLogix and ControlLogix PLCs with more I/O's from the Rockwell Automation brand.
Last updated: March 23, 2024 2:24 pm
Rockwell is one of the top used b PLC brands in industrial automation. Rockwell Automation has a wide range of products from small PLCs to large IoT modules. The Rockwell brand is preferred for its robust hardware architecture and easy programming software. The popular PLCs with large I/O capability are CompactLogix and ControlLogix. In this post, we will see the difference between CompactLogix and ControlLogix PLC brands.
ControlLogix vs CompactLogixPLC model numbersMemory CapacityNumber Of Embedded Ethernet portsRedundancyDisplay SystemCommunication Protocols SupportedSercos Motion SupportI/O Points SupportIntegrated DisplayportConclusion
The CompactLogix is defined under Rockwell as a small control system and the ControlLogix is defined as a large control system. This means that the IO handling, memory, and other software features of ControlLogix are far more developed for large control systems than CompactLogix PLC.
CompactLogix
CompactLogix PLC
PLC model numbers
A] CompactLogix 5370 – starts with the 1769 series
B] CompactLogix 5380 – starts with the 5069 series
C] CompactLogix 5480 – starts with the 5069 series
D] ControlLogix 5570 – starts with the 1756 series
E] ControlLogix 5580 – starts with the 1756 series
Memory Capacity
ControlLogix has a maximum memory capacity of 40MB. CompactLogix has a maximum memory capacity of 20MB.
ControlLogix has a maximum of two embedded Ethernet ports. CompactLogix has a maximum of three embedded Ethernet ports.
Redundancy
ControlLogix has redundancy capabilities in them, which are not present in CompactLogix PLC. So, if any system requires redundancy in it, then it must use ControlLogix PLC.
Display System
ControlLogix has a display system that provides data regarding diagnostics and troubleshooting. If you are using CompactLogix PLC, you can only troubleshoot via LED’s on it. So, the diagnostic viewing capability of ControlLogix is very good and enhanced.
ControlLogix supports Ethernet/IP, ControlNet, DeviceNet, Remote I/O, SyncLink, and USB; whereas CompactLogix supports EthernetI/P, USB, and DeviceNet.
ControlLogix
ControlLogix PLC
ControlLogix PLC supports the Sercos motion communication standard, which is widely used in machine automation projects. This feature is not supported in CompactLogix PLC.
I/O Points Support
ControlLogix PLC supports a maximum of 128000 digital and 4000 analog IOs, which is far ahead of CompactLogix PLC.
CompactLogix PLC has an integrated display port that can connect to industrial monitors with high definition. This feature is not available in ControlLogix PLC.
Conclusion
There is not much of a difference between both the PLCs. As ControlLogix PLC is a large-system PLC, it obviously has more advantages than CompactLogix in terms of capacity. But, both the PLCs also have many similar features which makes both these products very suitable for harsh, critical, and big industrial environments.
  • PLC-to-PLC Communication Project
  • PlantPAx Library in Factory Talk Studio
  • What is a Data Block? Global Data Blocks in PLC
  • How to Save a PLC Project to a Memory Card?
  • Analog Input Devices in Studio 5000 Tutorials
Program Flow Control Instructions in PLC Programming
Normally-Closed Contacts for Stop Buttons
How PLC Reads the Data from Field Transmitters
PLC SCADA Engineers Interview Questions and Answers
Automatic Packing of Bottles Programming
Mitsubishi Electric GOC Controllers
Everything You Need to Know About PLC Battery
PLC 1 Push Button to Turn ON or OFF 1 Output
Drilling Process using PLC Program
What is RS Linx? Types of Software in Rockwell Automation
Applications of SCADA
Control Algorithms in PLC Programming
Omron PLC paper cutting machine automation
Automatic Paper Cutting Machine Using CX-Programmer
Siemens Tia Portal PLC Training Course
PLC Star-Delta starter with interlock
Schneider PLC Example Program for Star-Delta System
Types of PLC Memory
Types of PLC Memory
Types of PLC
Types of PLC
RSLogix5000 PLC Program Backup procedure
How PLC controls a ON-OFF Valve
PLC Valve Control Ladder Logic Programming
Basic Concepts of the Safety Relay
Solenoid-controlled Valve Problem
Viscosity Measurement Objective Questions
process conditions, Find out the Circuit Components Status
As per Process Conditions, Find out the Circuit Components Status ?
Generator Action in a Motor
Ultrasonic Sludge Blanket Level Meter Animation
Industrial Instrumentation Quiz
Magnetic Float Level Switch Principle
Magnetic Float Level Switch Installation Techniques
Bubbler Level Measurement Animation
