Reading: Difference between Accuracy and Precision
Inst Tools > Blog > Calibration > Difference between Accuracy and Precision
Accuracy is how close a value to its True Value. Precision is how repeatable a measurement is. Learn the difference between them with examples.
Last updated: September 28, 2022 3:26 pm
Saurabh Vaidya
Calibration
3 Min Read
Imagine, if you are measuring Voltage using Voltmeter. The true value of Voltage is 230 Volt.
Definition of Accuracy and PrecisionComparison of Accuracy and Precision
You noted readings as follows: 230.22, 230.22, 230.21, 230.21, and 230.22 Volt.
These readings are very near to each other. This nearness (closeness) of successive readings is called precise readings.
You measure readings as 230.03, 230.09, 230.01, 230.05, 230.07 volt.
These readings are near to the True value of Voltage. I.e. Readings are accurate.
Accuracy and Precision Definition
The accuracy of instruments is defined by the manufacturer.
Precision is user-defined and also property of instrument.
Now let’s take an example of measuring 230 volts with an accuracy of 0.1 V. i.e. instrument is within accuracy if the voltage is in between 229.9 to 230.1 volt.
If you measured reading as 230.05, 230.03, 230.08, 229.98, 230.06 volt, readings are accurate but not precise
If you measured readings as 230.17, 230.18, 230.17, 230.19, 230.17 volt, readings are precise but not accurate.
If you measured readings as 230.01, 230.02, 230.01, 230.02, 230.02 volt, readings are Accurate and Precise.
If you measure reading as 229.19, 230.24, 230.19, 230.26, 229.28 volt, readings are neither Accurate nor Precise.
Now Imagine, real-life scenario
You are standing at railway platform and indicator shows train will be arriving at 1.04 pm. And train arrives accurately at 1.04 pm. i.e. train is accurate.
Now, indicator shows the train will be arriving at 1.04 pm, and the train arrives at 1.10 pm. This repeats daily for 5 days. I.e. train is precise but not accurate.
Now, the indicator shows the train will be arriving at 1.04 pm, and the train arrives at 1.10 pm, 1.15 pm, 1.00 pm, 1.13 pm, and 1.20 pm for 5 days. I.e. train is neither precise nor accurate.
  • History of Measurement
  • Selection of Master Instrument
  • Importance of Unit Measurement
  • Why Calibration is Important?
  • Calibration Lab Exercise
How to do calibration checks of vibration Probe, extension cable and vibration monitor
Ammonia Gas Detector Working Principle and Calibration
How to Create Calibration Records?
Stability and Uniformity of Temperature Bath
Calibration of Displacer Level Transmitter
Pressure Gauge Calibration Procedure
How to Test a Pressure Switch ?
Calibration of Gas Detectors
pH Analyzer Calibration and Troubleshooting
Instrument Calibration Lab Exercise
Sample Raw DataSheet for Pressure Calibration
Closed tank DP Level Transmitter with wet leg elevation zero remote mount Calibration
What is Sensor Trim and Output Trim in Smart Transmitter?
How to Calibrate pH Electrode?
Calibration of Pyrometers using Black Body
Multiphase Flow Meter Calibration Procedure
Pressure Gauge Functional Testing
Smart Transmitter Calibration Tutorial
Smart Transmitter Calibration Tutorial Part 1
Calibration of Temperature Sensor with Indicator
Closed-tank-DP-Level-Transmitter-with-cleaning-leg-Calibration
Instrument Turndown Ratio
Communication Protocols in PLC
Various Communication Protocols in PLC
PID-Controller-Simulator-graph
PID Controller Tunning Parameters Simulator
Programmable Logic Controller (PLC) Questions and Answers – 4
Gas flow rate Formulas
Gas Flow Formulas
NAMUR OPEN ARCHITECTURE
Humidity Calculator
Humidity calculator
capacitance probe
Capacitance Level Measurement Working Principle
