Reading: DC Circuit Analysis Loop Equations
Inst Tools > Blog > Electrical Theory > DC Circuit Analysis Loop Equations
Last updated: July 24, 2018 11:31 pm
Electrical Theory
6 Min Read
All of the rules governing DC circuits that have been discussed so far can now be applied to analyze complex DC circuits. To apply these rules effectively, loop equations, node equations, and equivalent resistances must be used.
Loop Equations
As we have already learned, Kirchhoff’s Laws provide a practical means to solve for unknowns in a circuit. Kirchhoff’s current law states that at any junction point in a circuit, the current arriving is equal to the current leaving. In a series circuit the current is the same at all points in that circuit. In parallel circuits, the total current is equal to the sum of the currents in each branch. Kirchhoff’s voltage law states that the sum of all potential differences in a closed loop equals zero.
Using Kirchhoff’s laws, it is possible to take a circuit with two loops and several power sources (Figure 37) and determine loop equations, solve loop currents, and solve individual element currents.
Circuit for Loop Equations
Figure 37 Example Circuit for Loop Equations
The first step is to draw an assumed direction of current flow (Figure 38). It does not matter whether the direction is correct. If it is wrong, the resulting value for current will be negative.
Assumed Direction of Current Flow
Figure 38 Assumed Direction of Current Flow
Second, mark the polarity of voltage across each component (Figure 39). It is necessary to choose a direction for current through the center leg, but it is not necessary to put in a new variable. It is simply I2 – I1
Marking Polarity
Figure 39 Marking Polarity
Third, apply Kirchhoff’s voltage law to loops one and two by picking a point in each loop and writing a loop equation of the voltage drops around the loop; then set the equation equal to zero.
Applying Voltage Law to Loop
Figure 40 Applying Voltage Law to Loop 1
Figure 40 shows Loop one. From Point A to Point B, there is an increase in voltage of 8 volts. From Point C to Point D, there is an increase in voltage of 200 (I2 -I1). From Point D to Point E, there is a decrease in voltage of 10 volts. From Point E to Point A, there is a voltage decrease of 50I1 volts. The result in equation form is illustrated in below equation 1.
8 + 200 (I2 – I1) – 50I1 – 10 = 0
Using the same procedure for Loop 2 of Figure 39, the resulting equation is shown in below equation 2
10 – 200 (I2 – I1) + 40 – 100I1 = 0
Fourth, solve equations (1) and (2) simultaneously. First, rearrange and combine like terms in the equation for Loop 1.
-50 I1 + 200 I2 – 200 I1 = 10 – 8
-250 I1 + 200 I2 =2
Divide both sides by two.
-125 I1 + 100 I2 = 1
Rearrange and combine like terms in the Loop 2 equation.
-200 I2 + 200 I1 – 100 I2 = -10 -40
200 I1 – 300 I2 = -50
Multiplying the Loop 1 equation by 3,
3 (-125 I1 + 100 I2 = 1 )
and add it to the Loop 2 equation.
-375 I1 + 300 I2 = 3
– 175 I1 + 0 = – 47
Solving for I1 :
– 175 I1 = – 47
I1 = – 47 / -175 = 0.2686 amp = 286.3 mA
Solving for I2 using the Loop 1 equation:
– 125 (0.2686) + 100 I2 = 1
100 I2 = 1 + 33.58
I2 = 0.3458 amp = 345.8 mA
The current flow through R1 (50Ω) is I1 . The current flow through R2 (100Ω) is I2 , and through R3 (200Ω) is I2 -I1
I3 = I2 – I1
I3 = 345.8 mA – 286.3 mA = 77.2 mA
Fifth, apply Ohm’s Law to obtain the voltage drops across Resistors R1, R2 , and R3 :
V1 = I1R1 = (0.2686 amps)(50Ω) = 13.43 Volts
V2 = I2R2 = (0.3458 amps)(l00Ω) = 34.58 Volts
V3 = (I2 – I1) R3 = (0.0772 amps)(200Ω) = 15.44 Volts
Sixth, check the calculations by applying Kirchhoff’s Laws:
Check 1: Apply Kirchhoff’s voltage law to the larger outer loop (Figure 41).
Applying Voltage Laws to Outer Loop
Figure 41 Applying Voltage Laws to Outer Loop
The sum of the voltage drops around the loop is essentially zero. (Not exactly zero due to rounding off.)
8 – 13.43 – 34.58 + 40 = 0
0.01 ≅ 0
Therefore, the solution checks.
Check 2: Use Kirchhoff’s current law at one of the junctions (Figure 42).
Applying Current Law to Junction
Figure 42 Applying Current Law to Junction
The sum of the currents out of the junction is:
0.2686 + 0.0772 = 0.3458 A = 345.8 mA
The current into the junction is 345.8 mA
The current into the junction is equal to the current out of the junction. Therefore, the solution checks.
Units of Electrical Measurement
Wattmeter
Reading Electrical Schematics
AC Induction Motor Slip
Inductive Time Constant
Simplified Formulas for Parallel Circuit Resistance Calculations
Half-Wave Rectifier Circuit
Capacitive Time Constant
Impedance in RC Circuits
Impedance
Conductor, Insulator, Resistor and Current Flow
Series – Parallel Circuit Analysis
Series-Wound DC Generators
DC Generator
Calculate Power in Series RL Circuit
Transformer Efficiency
Ohm Meter Circuit
Ohm Meter
AC Generator Operation
Losses in AC Generator
Split Phase Motor
Single Phase AC Induction Motors
Thermocouples
Thermocouples
Batteries Connected in Parallel
Battery Operation : Series and Parallel
Voltage Polarities
Voltage Polarity and Current Direction
What is a Process Alarm
What is a Process Alarm? Types of Alarms
0 to 10 mA Current Loop
What is Live Zero in 4-20 mA Current Loop?
100 Instrumentation Questions
100 Instrumentation Basics Questions
Electrical Machines MCQ Series 15
Electronic Devices & Circuits Quiz – Set 7
Thermocouple Calibration
Instrument Heat Trace
Electrical Heat Tracing
300 Power Electronics Projects - Top Electrical Major Project Titles
300 Power Electronics Projects – Top Electrical Major Project Titles
