Reading: Types of CPU Communication Ports in Siemens PLC
Inst Tools > Blog > PLC Tutorials > Types of CPU Communication Ports in Siemens PLC
In the Siemens PLC, we have several types of CPU communication ports available to communicate with other devices like MPI, DP, PTP, ProfiNet, and EtherNet.
Last updated: March 4, 2021 11:14 am
3 Comments
In this article, we will learn about the types of CPU communication port available on the Siemens PLC.
CPU Communication PortsMPI (Multi-Point Interface)DP (Decentralized Peripheral)PTP (Precision Time Protocol)ProfiNet/EtherNet
Communication is an essential part of any control system. Without communication field devices, network switches, HMI, PLC can’t talk to each other.
In the Siemens PLC, we have several types of ports are available to communicate with other devices.
Let’s dig deeper to understand each type of communication port.
  1. MPI (Multi-Point Interface)
MPI port is used RS-485 communication protocol.
We use the MPI port when we have to transfer an existing program to the PLC. We can achieve it by connecting it with a PC adapter.
You can connect CPU with an HMI; this way data can easily transfer to the HMI.
You can also connect with another automation facility.
  1. DP (Decentralized Peripheral)
Another communication port looks the same as MPI as this also used RS-485 communication protocol.
DP port provides an even higher data transfer rate than an MPI port.
You can connect another automation facility like VFD, Interface module, etc.
Using the DP network one can transmit data remotely. For example, a distance from the field to the control room is far then instead of pulling wires all the way the field to control room, you can transfer all the I/Os to the field and can pull a single PROFIBUS-DP cable to communicate with the I/Os.
You can connect up to 128 devices on a single network.
  1. PTP (Precision Time Protocol)
This port is used in the Modbus network.
If this port is available on CPU of PC then we can connect it with printer and barcode reader.
It is used to synchronize clocks throughout the network.
The accuracy of the clock in the microsecond range has made them suitable for the measurement and control systems.
  1. ProfiNet/EtherNet
It uses RJ45 (Register Jack) network interface to communicate with other facilities.
It uses the IEEE 802.3 standard to communicate.
Provide a faster data transfer rate than the PROFIBUS-DP network.
You can connect it with an HMI from Laptop to transfer the data.
ProfiNet is used where data needs to transfer at a very higher rate like in motion control application.
Ethernet can be used in the normal application except for motion control.
I hope you may have a clear idea about ports are available on the CPU of Siemens PLC.
Still, doubts in mind? Then put your questions in the comment section.
Author: Suhel Patel
  • Electrical Signal Types
  • What is PLC Redundancy?
  • Flexible Input Output Modules
  • What is the DDE Protocol?
  • What is a Watchdog Timer in PLC?
What is NOR Flash Memory in PLC?
What is Sequential Function Chart (SFC?)
Single-acting Pneumatic Cylinder Operation with Limit Switch
PLC Project Examples for EcoStruxure Machine Expert
Overview of SIEMENS PLC – S7-1500, S7-1200, S7-400, S7-300
3 Comments
  • Siddhartha Verma says:
    October 16, 2020 at 12:25 pm
    How to configure MPI ,DP and Profinet to communicate with other devices
  • Ajay Kumar says:
    November 1, 2020 at 6:22 am
    Can u tell me about communication cables for S7 200 SMART & S7 300 PLCs for uploading & downloading programs
  • Yevhen Chumak says:
    May 12, 2024 at 3:45 pm
    Since when PTP call Precision Time Protocol???
    It is Point-to-Point~!
Down Counter PLC Program
Basics of Loop Checks
PLC Program for Automatic Parameter Initialization When Power UP
#5 PLC Best Practices – Cryptographic and Checksum Integrity Checks
What is a Data Block? Global Data Blocks in PLC
Conveyor Sorting Machine PLC Program with Calculation Function
PLC Programming Videos
Cyclic Interrupts TIA Portal
Configuring and Usage of Cyclic Interrupts TIA Portal (OB 30+)
VFD Commissioning and Testing Procedure
Industrial Automation Cold and Hot Standby
High-Speed and Fast Counters in PLC
What are High-Speed Counters and Fast Counters in PLC?
Modbus in Industrial Networks
Distributed Control System Interview Questions
Concept of Interlocking in PLC
Simatic Hardware Configuration
Configuration of Profibus Network in Siemens PLC
PLC Program for Analog Input Sampling
PLC Analog Input Sampling Ladder Logic
belt conveyors principle
Conveyor : Belt, Screw, Pneumatic, Hydraulic, Roller, Chain, Bucket, Vibratory
logic-gates-questions-and-answers
Logic Gates Questions and Answers
heated instrument enclosures
What is Instrument Heated Enclosure or Protection Box?
de-energized-to-safe-mode
ProfiBus Questions and Answers
Latest ProfiBus Questions and Answers
Components of CCTV System
Free Download CCTV Book
How to troubleshoot the PLC Hardware faults
