Root Cause Analysis (RCA) related to the eleven numbers of Cooling Tower Fan frequently failing drives.
| Category: | Mechanical |
| Equipment Type: | Miscellaneous Rotating Machine Problems |
Cooling Tower Fans Frequently Failing RCA
The author after detailed study considered the two below given alternatives to solve his 3 predecessors gave up 10‑yearlong problem:
Shift the motor inside the CT shell and couple the motor to the Gearbox (GB) to eliminate the 3-m long tubular shaft (LTS) – the problems’ Root cause. The management already besieged with pain in the neck electrical problems instantly rejected it.
Replace LTS with universal joint shaft (UJS, below figure) – the problem vexed management approved instantly trial at two fans.
Eliminated Constraints
The author decided replacing the poor life LTSs with universal joint shafts (UJS) because, being a well-engineered, strictly quality controlled for material quality, dimensional tolerances, assembly fit ups and special-painted to withstand the dusty and wet environs the automobiles face.
The faced constraints (C) and remedies (R) follow:
C1-The torque capable longest available UJS was not long enough to couple the motor to the JB!
R1- The author got the motor pushed towards the fan; cutting a hole in the wooden door. 1/3 motor length penetrating into the fan chamber enabled coupling to the GB input shaft
C2-1500 RPM rotation centrifugal force threw the grease out of the UJS; the lubricant starved UJS would fail within weeks; in addition, the falling grease would contaminate the water and pose housekeeping problems.
R-2; Covered the UJS with UJS vendor sold low cost ‘boot,’ benzene washed the old grease, recharged new grease during the two-yearly TAs and covered the joint with new boot. Hence, the UJS lasts forever
Modifications’ Benefits
Below given are the benefits from UJS:
- Thanks to UJS cells availabilities rose to 100% and offered the below given benefits
- Thanks to always near design TCW. Hence, the former frequent NH3 and urea plants load adjustments to suit varying TCW vanished; and the total plant shutdown risks from likely operator errors during load changes too
- Hence, NH3 and Urea production rose 10%. In addition, equipment and personnelnstrains due to load changes also vanished and helped in achieving the corporate goal “keep the plant young”.
- Gone are the 4-6 hours skilled technicians’ time taking motor to gearbox LTS anyway unsatisfactory alignments – the CT cells poor availability root cause
- UJS just fits; it requires no alignment
- Wasteful shop making and balancing with poor results during missed vendor LTS deliveries gone
- The UJS are of top quality as explained before; on the CT vendor offered tubular rigid joint lacked all these.
- Thanks to smoothest vibrations free and durable UJS drives the motors’ and gearboxes’ bearings’ lives exceed the 50,000 hours (nearly 6 years) L10, lives. Associated benefits are bonus.
- Readily available UJS eliminated large inventory holding costs and eliminated the former delayed deliveries anxieties and need for in-house LTS making
Author: S. Raghava Chari
- Turbo-Compressor Problem
- Compressor Anti-Surge Control
- Plant Air Compressors Problems
- Plant Turbo-compressor Problem
- Failing Plant Air Compressor Drives
