Reading: Convert current (4-20mA) to Percentage (0-100%)
Inst Tools > Blog > Instrumentation Tools > Convert current (4-20mA) to Percentage (0-100%)
Last updated: November 12, 2019 5:09 pm
3 Comments
1 Min Read
This is used to convert the standard current signal in the range of 4-20 ma to the percentage value 0 – 100 %..
This calculation tool used to find out the equivalent percentage value from the current signal.
Current to Percentage Conversion:
Note:
1.The above calculation tool designed for a standard 4-20 ma signal conversion.
2.You can convert out of range signal also with the above tool.
(Example: you can calculate for .3.8ma also and 20.5ma as well)
Instrumentation Calculator
Level Measurement with Wet leg and Installed Below Tapping Point
Interface Level Measurement using DP Transmitter
DP Level Transmitter Calibration for Diaphragm Seal with Capillary
RTD Calculator : Calculate Resistance from Temperature
Convert Percentage (0-100%) to current (4-20mA)
3 Comments
  • joseph wellington says:
    April 25, 2017 at 9:37 pm
    what is the formula for this conversion?
    • S Bharadwaj Reddy says:
      April 26, 2017 at 3:57 am
      Hi, Please check Formula Category, Its already available. Click Here
    • azetou says:
      April 26, 2017 at 11:50 am
      x[%] = ((I-4)/16)x100, it is linear.
Level Measurement with Dry leg and Installed Below Tapping Point
Convert Linear mA to Square root mA
DP Flow Transmitter Re-Ranging Calculation
RTD Calculator : Calculate Temperature from Resistance
Transmitter Current Conversion Tool
Convert Process Variable to Percentage
Density Measurement for Open Tank with Constant Level Application
Closed tank Density Measurement using DP Transmitter with dry leg & constant level application
Boiler-Drum-Level-transmitter-calibration
Boiler Drum Level Transmitter Calibration
Convert Linear Percentage to Square root Percentage
Convert-Transmitter-Output-in-Percentage-to-Process-Variable
Conversion of Transmitter Output in Percentage to Process Variable
DP-Level-Measurement-Calculation-Below-Tapping-Point-Open-Tank
Differential Pressure (DP) Level transmitter Installed Below Tapping Point
DP-Level-Measurement-Calculation-Above-Tapping-Point-Open-Tank
Differential Pressure (DP) Level transmitter Installed Above Tapping Point
Density-Measurement-using-DP-Transmitter-for-Closed-Tank-Wet-leg
Density Measurement using DP Transmitter for closed tank with wet leg
Calculate-current-4-20ma-from-process-varibale-pv
Calculate Current (4-20ma) from Process variable PV
Loop Current Step Response (LCSR) Test for RTD
Response Time Test of RTD and Thermocouple
Counter Count Down Bit
Down Counter PLC Program
Electrical and Instrumentation Maintenance Test
Electrical and Instrumentation Test
Ammonia Analyzer Working
Ammonia Analyzer Principle
Dew Point Meter Principle
Process Variable Damping Graph
Process Variable Damping of Transmitter
Convert-Process-Variable-to-Percentage
Power Systems MCQ Series 4
