Reading: How to Connect PLC with SCADA System via OPC UA?
Inst Tools > Blog > PLC Tutorials > How to Connect PLC with SCADA System via OPC UA?
In this article, we are configuring a connection between Siemens PLC S7-1500 and Indusoft SCADA System via OPC-UA.
Last updated: September 28, 2022 2:23 pm
Hussien Ghareb
IntroductionWhat makes the OPC Protocol Special?The key features of OPC UASteps to set the connection between PLC and SCADA
Introduction
One of the most important protocols all over the Automation Industry is OPC protocol that is developed by OPC Foundation.
Here we are going to know how to establish an interface between a SIEMENS PLC and a SCADA system (Indusoft Web Studio V7.1) using the OPC-UA infrastructure.
The communication protocols are many and each vendor in the Automation field has made a special protocol for himself, as an example, we can see that SIEMENS products are using the PROFIBUS & PROFINET protocols to communicate with each other.
But on the other hand, we can find that Allen Bradley PLCs are using Ethernet/IP protocol to communicate with each other, and that is the situation for all vendors.
That is why we have invented the OPC (Open Platform Communication) protocol that can create data transfer standards for multi-vendor, multi-platform, secure, and reliable interoperability in industrial automation.
  • OPC UA does not depend on a specific operating system platform. OPC UA can, for example, be used with Windows, Linux, Mac OS X, a real-time operating system or a mobile operating system (such as Android).
  • OPC UA is implemented in various different programming languages.
  • Independence of a specific transport layer.
  • The information from the OPC UA server (for example the PLC tags) is modeled as nodes connected over references. This makes it possible to navigate from node to node with an OPC UA client and find out what content can be read, monitored or written.
First of all, we need to launch the OPC UA server from the S7-1500 PLC.
Step 1:
Open new project with TIA Portal and select your PLC
Note make sure that your device has a firmware version higher than 2.0 that contains the OPC UA.
OPC UA server from S7-1500 PLC
Step 2:
From device properties, activate the OPC UA server because by default it is deactivated, and you can copy the server address and save it as we will need it later.
Activate OPC UA Server
Step 3:
From here you can select the server license that you have installed on your PC.
OPC UA Runtime License
Step 4:
Now you can save your project and download it using PLCSIM Advanced.
S7 PLC SIM Advanced Control Panel
Note if you want to simulate the OPC server on your PC you have to use PLCSIM-Advanced, as PLCSIM will not help you.
Step 5:
Now we will go to the Indusoft SCADA software to launch an OPC client from the software. Here we will insert a new OPC-UA connection.
Open Indusoft SCADA software
Step 6:
Now you will need to copy your server TCP/IP address as shown from TIA.
copy your server TCP IP address from TIA Portal
Step 7:
Now you can paste the server address in the SCADA system and check if the connection is healthy or not.
Simulating OPC
Step 8:
Now you can add a new page to connect some tags with OPC nodes.
Connect tags with OPC nodes
Step 9:
After creating this page now, you can select the OPC connection and write your system tags.
Indusoft OPC SCADA
Step 10:
Here you can browse for your PLC nodes (tags) to attach them and to connect them with the SCADA tags.
So, that it.
  • OPC Communication
  • PLC to PLC Communication
  • Servo Motor and Stepper Motor
  • PLC and SCADA Softwares
  • Motor Stop Interlock in PLC
Automatic Coffee Vending Machine – PLC Logic Programming
Siemens S7 300 and STEP 7 PLC program using SIMATIC Software
Conveyor Speed Logic using Structured Text in PLC
Mitsubishi PLC Timers with Ladder Diagram
Control Speed of Induction Motor using Analog Output of PLC
Types of Interlocks
Elevator PLC Ladder Logic
What are Faceplates? How to Create a Faceplate? HMI Visualization
Advanced Ladder Logic PLC Example
Automatic Sanitizer – Complex Ladder Logic PLC Examples
Types of Scan Time in a PLC
Programmable Logic Controller (PLC) Scan Time – Types, Theory
Basic Arithmetic Programming in Mitsubishi PLC
Use of Regions in SCL Language
Allen Bradley PLC Emulator
How to Work with Allen Bradley RsLogix Emulator?
PLC Programming Basics for a Packing Machine Control System
PLC Packing Machine Control System Program in XG5000
Learn PLC in Hindi
Learn PLC in Hindi
PLC Ladder Logic for Demultiplexer
1 to 8 Demultiplexer PLC ladder diagram
Steam Pressure Control
Pressure to Current Converter
Pressure to Current (P/I) Converter Principle
Shift Bit Register in PLC
Advances in Control System
Fuzzy Logic Control
DCS Commissioning Steps
Relay Wiring
Introduction to PLC
#9 PLC Best Practices – Validate indirections
