Reading: Compressor Anti-Surge Control near-miss incident
Inst Tools > Blog > Root Cause Analysis (RCA) > Compressor Anti-Surge Control near-miss incident
The author root cause analyzed the near miss incident of compressor anti-surge control to resume production and surge prevention.
Last updated: September 28, 2022 3:20 pm
S Raghava Chari
Root Cause Analysis (RCA) Process
3 Min Read
Root Cause Analysis (RCA): There is a near-miss incident reported on a compressor anti-surge control.
Compressor Anti-Surge Control near-miss incidentAuthor RCA solutionAuthor ConclusionsImmediate SolutionPermanent SolutionPermanent solution Benefits
Article Type:Root Cause Analysis (RCA)
Category:Mechanical
Equipment Type:High Speed, Hi KW Major Rotating Machines
Author:S. Raghava Chari
Note: This root cause analysis (RCA) is from real-time scenarios that happened in industries during the tenure of one or two decades ago. These articles will help you to improve your troubleshooting skills and knowledge.
Compressor (K-601) HP case anti-surge control 3” 1500 # RTJ flanged ball valve (V1) passed excessively and leaked heavily at the stem after 2 service years.
The all welded up V1 permits no dissemble; hence no repair either. The plant engineer found the same company made 3”x1500 # butt weld end valve (V2).
On his request, the workshop welded flanges to V2. V2 went online. On start, K‑601 surged heavily; an alert operator tripping the turbine averted K‑601 wreck.
The author root cause analyzed the near-miss incident to resume production ASAP and surge prevention.
Author RCA solution
The author got V2 taken out, compared V1.and V2 placed side by side.
His observations are:
#Observations  V1
V2
1Upstream & Downstream 8×3” pipe reducer small-bore dia measured in the field6060
2Ball Bore dia8080
3Valve inlet and outlet nozzle bore dia8060
Author Conclusions
  1. V2 60 mm nozzle bore dia reduces the system already marginal flow capacity even below requirement; hence the surge and near miss compressor wreck
  2. Catalog shown V2’s 70% V1 flow capacity confirms the author’ deduction
Immediate Solution
He checked and found even after nozzles bore increase to 80 mm, V2 wall thickness adequate for 1500 # rating. With nozzles bored to 80 mm dia V2 the compressor did not surge.
Permanent Solution
The 3” valve on 8” line is a potential pipeline strength reducer. Hence, he selected a 6” globe design CV for the service.
Permanent solution benefits are:
  1. The one size lower than pipeline 6” CV meets the pipeline code.
  2. It was problem free during for over 6 years, when author left the plant; maybe it was problem free forever
  3. Just bonnet dissemble and few inexpensive elastomer changes would restore the new valve leak-tightness, unlike the former ball valve.
Author: S. Raghava Chari
  • Process Air Compressor Overhauls
  • Heat Exchanger Root Cause Analysis
  • Malfunctioning Inlet Check Valves
  • Refrigeration Compressor Turbine RCA
  • Erratic Stroking Control Valves RCA
Bucket Steam Trap
143 Process Control Terms and Glossary – Questions Answers
What is Heat Pump Water Heater?
Boiler Feed Water Heater Shell Flange Leaks
Compressor Cracked Shaft Spacers
RCA Related to Trip Throttle Valve (TTV)
Too often done riskily repaired Roof Hot Spots eliminated forever
High-pressure Service Level Transmitters Misunderstood Zero Drifts
Repeat Failures of Letdown Valves
Problem with Choked Control Valve with Whisper Trim Cage
Wrong Operation Internals Destroyed Demineralization Mixed Bed Vessel
Control Valves Leak Tightness Restoration Pose Difficulties
Poor Bagging Scale Availability Threatened Production Cuts
What is a Circulating Pump?
Target Flow Transmitter Problem
Unreliable Ammonia Flow Transmitter Reading and Problems
Level Flow Cascade Control Pumping Station
Introduction to Wastewater Treatment Works and Pumping Station
Hazards of Compressed Air
Tilting Pad Bearing
Flash Vessel All Level Instruments Stopped Working
Ammonia Flash Vessel All Level Instruments Stopped Working
Erratic Stroking Control Valves Delaying the Shutdown Plant Restart
Single-Bed Demineralizer
Demineralizers
Reformer Fan Bearing Change Times cut by 90%
Thyristor Firing Circuits Multiple Choice Questions
Four Wire HART Transmitters
4-wire Passive versus Active Transmitters
Forward Bias
Rectifiers, Forward Bias and Reverse Bias
Basic Control Systems Questions
14 Basic Control Systems Questions for Interview Preparation
PLC Program for Water Level Control
PLC Program for Water Level Control Logic
Custom CNC Machining Complete Guide
Custom CNC Machining – A Complete Guide You Cannot Miss
Top 100 Zigbee Projects for Engineering Students
Electromagnetic Field Test Questions
