Reading: Commissioning Checklists for Industrial Automation Systems
Inst Tools > Blog > Control Systems > Commissioning Checklists for Industrial Automation Systems
In this article, we will discuss basic general guidelines and commissioning checklists for industrial automation systems.
Last updated: January 24, 2023 11:46 am
Control Systems PLC Tutorials
6 Min Read
In this post, we will see the checklist for commissioning an industrial automation system.
Industrial Automation SystemsCommissioning Checklists
Commissioning is the process performed by an engineer to test, validate, run and then hand over the system to the end customer. It is a tricky cycle and requires proper communication skills, technical skills, site condition understanding, process knowledge, and tuning with the customer to hand over a system.
The question is not just to hand over, but it builds up a trust with the customer that the system purchased is performing according to their specifications and fulfilling their demand.
Once the PLC electrical panel has been dispatched from a manufacturer’s factory, it is then ready for installation at the industrial site.
Commissioning Checklist for Industrial Automation System
At the actual plant (site), the electrical panel is just not enough for the client to accept the machine. The overall working of the machine with actual process parameters will be considered for full acceptance.
The electrical panel is just a part of the system delivered; the whole machine is checked for proper performance. It is the job of the manufacturer to perform commissioning with the client and handover to them.
In this post, we will have a look at some of the basic general guidelines and checklists that must be considered for performing commissioning.
  • Make sure you have installed all the remote IO devices properly at their designated position. Because PLC is all about inputs and outputs, any missing device or instrument or its improper placement in the plant layout will disrupt the performance of the system.
  • Check whether all the cables are properly laid from a device to the panel.
  • Perform Megger test of the motors and verify the earthing of the instruments and electrical panel.
  • Checking the continuity of the wires is a must. The electrical part is a critical parameter and you need to ensure that there are no broken wires or any external damage to it.
  • The civil structure (GA drawing) of the components is an important criterion to check.
  • The fabrication and placement of each component must be checked properly so that it does not cause an accident.
  • Availability of utility is a very important parameter to check. Without important utilities like water, steam, air, etc. it will not be possible to run the system and so; it is to be ensured that all these are ready and in place to start a system.
  • Check the incoming voltage that will be given to the electrical panel.
  • Also, note that the voltage between earth to neutral must be typically less than 0.5 V. This must be achieved to eliminate any possibilities of noise in the system.
  • Check communication cable layout between PLC and HMI / SCADA / DCS.
  • Ready all the necessary documents that are required for performing the commissioning steps. It includes electrical drawings, mechanical drawings, P&ID layout, BOM (Bill of Materials), control loops, power and signal cables, and other documents related to your system.
  • Every industrial automation system has a test procedure developed to check the system stepwise. Make sure it is ready before starting the plant; as it covers all the conditions from start to end. This will make it easy for the engineer to run the system.
  • Your team is working all over the plant to start and hand over the system properly. They will be located at different sites and areas of the plant according to the work assigned to them. So, the best coordination will be required between all of them and this requires a good communication network of cell phones and radios with the best available network. Distortion in communication will hamper the process a lot.
  • Make sure to continuously involve the operators of the customer side with your team during the commissioning phase. Their availability and continuous support will make easy your task when you start the system. This is because, once they are familiar with the system before running, they will automatically adapt to the process when it is running and this will make your workload easier.
  • Ensure that you have informed your vendor about your commissioning activity pre-planned; and not on short notice. Every person is working and is not free every time to sit for you and receive your call instantly. So, vendor readiness is a must criterion; as it will help them prepare for support and availability with prior notice.
In this way, we saw some general checklist criteria and guidelines for performing commissioning for a PLC automation system.
  • PLC Wiring Diagrams
  • Electrical Wiring Diagram
  • 4-20 mA Transmitter Wiring
  • Why 24 Volts DC Power Supply?
  • Interposing Relay Panel Wiring
What is Open Systems Interconnection?
What is Open Telemetry? – Principles and Benefits
Pulse Timer Instruction in PLC Programming
Structured Text vs. Instruction List for PLC Programming
Boiler Drum Level Control Systems
Definitions of Electrical Grounding
Parallel Tanks Level Control using PLC Ladder Diagram Tutorial
Data Types in PLC – Bit, Byte, Integer, Real, String
Which Connection is Best for PLC? – Sinking or Sourcing
How-to Create Instrument Loop Diagram (ILD)?
PID Controller Loop Tuning Questions and Answers – Part 2
List of 100 Questions Related to Distributed Control Systems (DCS)
List of 100 Distributed Control Systems Questions (DCS)
WHILE DO Statement in SCL Language
HMI screen for operator
Auto Tiffin Box Filling Station
PLC Fault Diagnosis - PLC Training Documents
PLC Fault Diagnosis – PLC Training Documents
Types of Switches
Electrical Switches Principle & Types
Typical process control loop
How Process Control Loop Works
Control Panels Material Take-Off (MTO)
Control Panels Material Take-Off (MTO) – Engineering Project
Ladder Diagram Example using Memory Bits and Set Coils
PLC Sequence Programming Ladder Logic
Transmission Lines Protection Questions Answers
Instrumentation Engineering Root Cause Analysis
Instrumentation Engineering Problems Solved – Root Cause Analysis
IGBT Objective Questions
Siemens PLC Project Automatic Parking with Vehicle Counter
Siemens PLC Project: Automatic Parking with Vehicle Counter
Industrial Instrumentation Quiz
Instrument Zero and Span Calibration
De-energized Electrical Circuits
De-energized Electrical Circuits, Networks, and Equipment
