Reading: How to Commission WirelessHART Transmitter With Gateway
Inst Tools > Blog > Calibration > How to Commission WirelessHART Transmitter With Gateway
Last updated: June 21, 2019 3:12 pm
Calibration
This guide is intended to give an idea on how to use 375/475 Field Communicator to configure Rosemount wireless device to be connected to wireless gateway
  • A Field Communicator is used to configure HART devices.   WirelessHART devices are preconfigured using the same tools and methods used on wired HART devices. However, WirelessHART devices require the additional configuration of the Join Key and Network ID to join the correct wireless network.
  • A device uses the Network ID to determine which wireless network to join in a large installation spanning multiple process areas.  Once the device has heard one or more neighbors, it uses the Join Key to encrypt the join messages exchanged with the network manager.
  • The network manager, in turn, authenticates the device and incorporates the device into the network.
  • The  Field Communicator connects to wireless devices through the devices’ FSK (frequency-shift keying) communication terminals.
  • The Field Communicator connects directly to the communication terminals on a wireless device.
  • Once connected, the field communicator automatically polls for connected devices using the selected polling options.
Follow below steps :
STEP 1 : Plug the Connector set into HART terminal at 375/475
STEP 2 : Clip the other end of Connector to the COMM terminal.
Wireless HART Transmitter
STEP 3 : Insert the Battery module into the dedicated slot
Wireless HART Transmitter Battery
STEP 4 : Power Up the 375/475. Select the “HART” icon and press “Enter” keypad to communicate with the Transmitter
Wireless HART Transmitter Configuration - 1
STEP 5 : Please wait until 475 fully load the device DD. Then go to “Configure”
Wireless HART Transmitter Configuration - 2
STEP 6 : Go to “Manual Setup”
Wireless HART Transmitter Configuration - 3
STEP 7 : Go To “Wireless”
Wireless HART Transmitter Configuration - 4
STEP 8 : Go to “Join Device To Network”
Wireless HART Transmitter Configuration - 5
STEP 9 : Key in the Network ID. Then press “Enter”. The ID should be the same as configured in Wireless Gateway.
Wireless HART Transmitter Configuration - 6
STEP 10 : Key in the 4 parts of the Join Key. Press “Enter” to proceed. The Join Key should be the same as configured in Wireless Gateway.
Wireless HART Transmitter Configuration - 7
STEP 11 : Press “Enter” to Accept new join key. The device will attempt to connect with the Wireless Gateway. This may take few minutes.
Wireless HART Transmitter Configuration - 8
Note: Depend on the device, the steps may vary. Set to the device lowest burst rate and enable gateway for “Active advertising” to speed up the connection process. The guide is for Rosemount devices
Configuration of Remaining process parameters will be as same as wired HART Transmitters.
Overview :
In this post, a new wireless device is added to the control system and the measurement it provides is added to a control module.  It is assumed that the wireless gateway has been added to the control system LAN and assigned to the controller.
Step 1: Configure a new wireless device using a field communicator. Enable the burst mode to publish data. Power it on and let it join the wireless network.
Step 2: In the control system explorer view of field devices, open the Reconcile I/O dialog box, find the new device and, drag and drop it to an unused channel.
Step 3: Create a new control module and, assign it to the controller. Add an AI function block and assign its IO_IN to the tag of the channel assigned to the new device.
Step 4: Download the controller.
Step 5: Open the control module online and observe that the value of the AI block periodically updates. The updates come from the burst data of the new device.
Credits : MKR MN
Calibration of Temperature Sensor with Indicator
Practical Calibration Standards
Differential Pressure Sensors Calibration Procedure
Calibration of Measuring Instruments – Significance, Costs & Risks
Impulse Line Pressure Testing Procedure
How to Calibrate the Eddy Current Conductivity Meter?
Pressure Switch Calibration Procedure
Calibration Procedure of Weighing Balance and Common Mistakes
How are HART instruments Calibrated?
Calibration : Up-tests and Down-tests
Calibration MCQ – Terminology and Glossary Questions
Selection of Weighing Balance and Weight for Calibration
Hydrogen Sulfide Gas Detector Calibration Procedure
How to Calibrate Load Cells
Capacitance Level measurement principle
Capacitance Level Sensor Principle, Limitations, Installation & Calibration
dissolved-oxygen-probe-calibration-procedure
Dissolved oxygen probe calibration procedure
DP Transmitter Capillary arrangement
Flow Meter Calibration Procedure
Solenoid Valve Functional Testing
Fieldbus Flow Transmitter Calibration
How do AC drives work
How do AC Drives Work? – Variable Frequency Drive (VFD)
Augmented Reality and Virtual Reality in Industrial Automation
How CPU Execute Program in Siemens PLC?
Vacuum Circuit Breaker Principle
What is Vacuum Circuit Breaker?
Flame Emission Photometers Questions & Answers
electric motor actuator principle
What is a Electric Motor Actuator ?
Power Tool Maintenance
Power Tool Maintenance – When And How To Replace Carbon Brushes
