  • Videos
  • Q & A
      • Practical Questions
    • MCQ
      • Instrumentation MCQ
      • Electrical MCQ
      • Electronics MCQ
      • Control Systems MCQ
      • Power Electronics MCQ
      • Multiple Choice Questions
  • EE
      • Electronics Q & A
      • Electronic Basics
      • Electronics Animation
      • Electrical Q & A
      • Electrical Machines
      • Electrical Animation
      • Power Systems
      • Switchgear & Protection
      • Transmission & Distribution
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Process Fundamentals
    • Videos
Reading: Will PLCs become obsolete?
  • PLC Tutorials
  • Control Systems
  • Videos
  • Q & A
    • MCQ
  • EE
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Videos
Inst Tools > Blog > PLC Tutorials > Will PLCs become obsolete?
Last updated: March 4, 2021 12:06 pm
4 Comments
3 Min Read
Will PLCs become obsolete, or phase out few years down the line?
Recently you must be hearing a lot about Industry 4.0. The use of technologies such as Artificial Intelligence, Machine learning, IoT, etc. is massively trending these days.
Some engineers in the Industrial automation field say or predict that the above-mentioned technologies might replace PLCs in the near future. Therefore I want to share my take on this with you folks.
I will explain my opinion with a simple example. Suppose I want to turn on any motor. To make motor ON, I need some physical switch so that I can energize the control coil of contactor which will ultimately make motor ON. And here PLC comes into the picture. It acts as a switch (in simple terms) and passes power to the control coil of contactor whenever we want.
In a broader sense PLC is a collection of multiple switches (memory switches, or physical switches in the form of digital outputs) and it has a number of additional features such as computing, sensing and generating digital and analog signals, etc.
The PLC is also a computer, but it is of a different kind as compared to a normal PC or laptop. The hardware of PLC is designed taking into account the requirements of industrial process control applications.
The AI, ML, and IoT technologies may take care of computation and decision making part of process control. But for actual physical execution, a particular kind of hardware is required. And this special kind of hardware requirement is very well taken care of by PLC like controllers.
Without this very kind of hardware, the execution of process control applications is not possible. AI, ML, and IoT like technologies are just advancing the way things used to work, making them more smart, efficient, reliable, and ultimately easy to use. But they cannot completely replace the old PLC like technologies.
Therefore, in my opinion, PLCs are not going to become obsolete in the future.
Author: Pratap Shinde
Share your thoughts on this topic through the below comments section.
  • PLC Tutorials and Guide
  • Quiz Questions for Instrumentation
  • Tips for Instrument Engineers
  • Open Platform Communication
  • OPC in Old PLC Systems
Recommended Articles
Instrumentation Earthing
What is Hot Standby in PLC?
PLC Analog I/O and Network I/O
PLC Programming Example with Pushbutton and Motor
Increment & Decrement Instructions in CX-Programmer (OMRON)
Difference between Power Cables and Signal Cables
4 Comments
  • RR says:
    May 25, 2020 at 12:48 am
    Dear Pratap Shinde
    This is very nice learning your’s brilliant explanation of PLC.
    The Client’s Field process has to be made User Friendly using all the Cascaded Connections & Designs i.e., from Client’s Field to Vendor’s PLC, DCS, RTU to SCADA to HMI,MMI to IoT, Neural Networks etcs.
    So its about making the whole Factory Unit in a Software in Server & Standby
    The technologies will Integrate.
    Regards
  • Sandeep says:
    May 25, 2020 at 8:41 am
    What about softcontroller PLCs…wherein the CPU is our computer cpu which acts as a PLC which will trigger digital outputs from the PC…So, then..PLC have no requirements there.
  • vivian (Vance) Newman says:
    May 26, 2020 at 4:18 am
    You are on the correct track Sandeep. That is the future. Some suppliers are already employing this.
  • Pradeep says:
    May 26, 2020 at 8:20 am
    PLCs will be there until industrial automation exists. Small PLC cost is very low compare to a PC. And also PC can work in s shop floor area as they are rugged. This AI, machine learning, Iot will be integrated as part of PLC but they cant wotk standalone.
208kSubscribersSubscribe
Recent Comments
Related Articles
Types of Allen Bradley PLC
What is Process Control ?
What is Process Control?
Liquid management using PLC programming
PLC Programming for Loss in Weight Liquid Systems
On Delay Timer using PLC
ON Delay Timer using PLC
How to set password in Siemens HMI
How to Password Protect HMI in Siemens TIA Portal?
Advanced Ladder Logic PLC Example
Automatic Sanitizer – Complex Ladder Logic PLC Examples
Open User Communication in Siemens Tia Portal - PLC to PLC
Open User Communication in Siemens Tia Portal – PLC to PLC
PLC Programmer Salary and Future Career Scope
More Articles
Control Valve Actuator Parts
Reversing Control Valve Actuator Fail Safe Mode
Convert-Linear-%-to-Square-root-%
Formula for Linear % to Square root % conversion
Pneumatic Level Control Valve
Piping and Instrumentation Drawing (P&ID) Tutorials – Part 3
Safety Instrumented System SIS Component Selection
SIS Component Selection – Safety Instrumented System
Single-Phase Induction Motors Multiple Choice Questions (MCQ)
125+ Single-Phase Induction Motors Multiple Choice Questions (MCQ)
Induction Motors Operating Characteristics Questions
Measurement of Carbon Dioxide in Flue Gas
Time Response Analysis
State Variable Analysis – Part I
