Reading: 11 kV, 3.3 kV, and 400 V systems insulation resistance (IR) Problems
Inst Tools > Blog > Root Cause Analysis (RCA) > 11 kV, 3.3 kV, and 400 V systems insulation resistance (IR) Problems
Electrical engineering root cause analysis (RCA) related to 11 kV, 3.3 kV, and 400 V systems insulation resistance (IR) values made infinity forever.
Last updated: September 28, 2022 3:08 pm
S Raghava Chari
11 kV, 3.3 kV, and 400 V Systems InsulatorsSC efficacy Demonstrated
Article Type:Root Cause Analysis (RCA)
Category:Electrical
Equipment Type:Bus ducts, Switchgear, Transformers,
Author:S. Raghava Chari
After SC coatings 6-months success, the author proposed extending it to the 11 kV, 3.3 kV, and 400 V systems’ insulators.
The reluctant electrical engineers opposed saying these systems’ paperboard insulators would absorb the Silicone Compound (SC), become soggy and become zero strength material and shatter into pieces during making and breaking currents.
No discussions could convince them. Hence, the author resorted to a practical demonstration: the author found ea. of the 6 Nos. 50x50x10 mm paperboard insulators crushed at around 10 T hydraulic loads in the plant’s hydraulic press.
Their shop insulation 5000 V mega ohm tester insulation resistance (IR) between two terminals at 35 mm centers ranged 2-4 megaohms. He suspended these near the chain mill pulverizers – the plant’s worst pollution area.
Uncoated boards IR was zero within an hour; the other four boards’ infinity even after 6-months. The SC coated test pieces’ crush strength was nearly the same as before, but the uncoated piece was crushed at < 1-ton load.
Perhaps the corrosive environment decayed that whereas SC prevented the others’ corrosion decay besides preserving IR!
Even with the above data, the electrical engineers reluctantly agreed to try SC on a non-critical Load Center bus and switchgears.
No flashover for over six months there and other LCs flashing over in 15 days or even sooner convinced them finally. They enthusiastically suggested SC coating all electrical systems insulators during the turnaround (TA) two months hence.
An electrical engineer raised a point, “the TA intense activities across the entire plant and at the workshop will not allow us doing this task.”
The author told them a way out, “We will SC coat the workshop area on a night shift – the workshop not working time – 10 days before TA started.
In addition, we will hire 10 Nos. diesel engines have driven portable welding machines 10 Nos. diesel engine driven generators pole illumination systems for no interruption TA”
SC application on all electrical system insulators all over the plant during the TA eliminated 11, 3.3 kV, and 400 V electrical systems IR loss and flashover problems also totally.
The nearly 7-year long electrical flashover problems disappeared totally. Crew clean and re-apply SC after 5 years on seeing sparks onset on 110 KV outdoor installations.
Indoor electrical equipment and even outdoor 400 V enclosed but not gas and water tight bus ducts required no compound renewal for over 10 years when the author left the company for another job.
Author: S. Raghava Chari
  • Burst Transformers & Input Breakers
  • Failing Weigh Feeders and Drives
  • Transformers Coolers Problems
  • Motors Rampant Winding Burnouts
  • Compressor Leaks due to Broken Instrument
Urea Reactor Top Bolted Plug developed Leaks
Solving Control Valve Hunting: Instrument Troubleshooting
Root Cause Analysis for Tank Overflow due to Valve Problem
Pitot-tube Replaced with Innovative Segment Orifice Plate
Cooling Water Circulating Pump Low throughput Resolved
Amine Pump Trip – Root Cause Analysis
Instrumentation Engineering Problems Solved – Root Cause Analysis
Compressor Anti-Surge Control near-miss incident
Frequent Feeder-A Lightning Arrester (LA) Bursts – Root Cause Analysis
High-pressure Service Level Transmitters Misunderstood Zero Drifts
11 KV Bus A to Bus B Phase Check Problem
Fired Boiler Induced Draft Fan (IDF) Failures Upset all Plants Operations
Alternate 110 KV Connection to Feeder A
repairs of welding cast refractory lined box over the hot spots
Primary Reformer RFG main Hot Spots threaten Indefinite Outage
Less than 40% available Plant Air Compressors made available 100%
Less than 40% available Plant Air Compressors made available 100% for Operations
Target Flow Transmitter Problem
Unreliable Ammonia Flow Transmitter Reading and Problems
Inability to Test Repaired HT Motors
Inability to Test Repaired HT Motors in Workshop Posed Problems
Mechanical Temperature Indicators (MTI) Problem
Card Failures in Automation Panels
Automation Panel Electronic Cards Failure investigation
Inlet Pigtail
Primary Reformer – Each Turnaround done expensive Tubes Repairs
Simple Three Digital Electronic Project Ideas
Synchronous Machines Distributed Winding Quiz
PLC Interlock Example
PLC Interlock Logic with First Input Priority
Boiler Intelligent Control Cabinet
IoT based Smart Boiler Control System with Cloud PLC and SCADA
Flow Meter Calibration Procedure
Abbreviations of Pressure, Temperature & Flow
Switch High level alarm occurs
Basics of Switches & its applications
Thyristors Quiz
