Reading: What is Hot Standby in PLC?
Inst Tools > Blog > PLC Tutorials > What is Hot Standby in PLC?
In this post, we will learn the concept of hot standby in a PLC (programmable logic controller).
Last updated: September 28, 2022 4:12 pm
Earlier, single CPUs were used in a PLC configuration. This single CPU controlled the whole plant operation. But, there was the main problem in a single CPU configuration.
If the CPU failed due to some reason or its power supply went off, then the whole plant operation would stop and if it was a critical process, then the large downtime would hamper and affect the whole process in a large way.
To overcome this issue, a feature of hot standby was introduced. Hot standby means a redundant CPU is used in synchronization with the main CPU.
When the primary CPU fails, the standby CPU will automatically become the primary CPU and take over the control of the system in a very quick span of time. The time is so fast that you don’t even realize when the switchover happened.
The hot standby system is used to provide a high level of redundancy and decreased downtime. One CPU acts as primary where all the program runs and communicate with IO’s.
When the primary CPU fails, the standby CPU takes over as primary and resumes the logic operation and IO control from the last paused stage quickly.
Then, when this PLC fails, the earlier PLC again takes up the operation provided it is in a healthy condition. The two CPUs are interconnected with each other through a communication medium like Ethernet.
Hot Standby in PLC
Refer to the above image. The two CPUs are connected with each other through an Ethernet link called Hot Standby Link. The IO links are also connected in such a way that it works in a redundant system.
Before the switchover happens, the following things must be taken care of; otherwise, the switchover won’t happen –
  • proper Ethernet Hot Standby link
  • health of both the CPU’s
  • Identity of both the CPU’s must be different
  • Programs running in both the CPU’s must be same
  • Firmware versions of both the CPU’s must be same.
Before each cyclic task of a program, the primary CPU transfers data like status and IO data to the standby PLC with the proper date and time stamp.
In the event of a switchover, the standby PLC resumes the operation with the data received. The changeover time is very fast and it can vary from an average of 15ms to one cyclic scan time.
There are many system software codes available to the programmer to control some user-defined functions of the hot standby event.
One popular concept is that on every program modification, the same changes must be transferred automatically to the standby PLC.
Though PLC failure is very rare, a redundant system ensures reliable and safe operation for the plant.
The PLC can fail due to some of the following reasons –
  • PLC has entered a halt state
  • PLC has detected a hardware or system error and has gone into fault mode
  • if the programmer has put the primary PLC in stop mode through the software
  • primary PLC power supply is turned off.
It is important to note that the switchover event does not cause any effect on the IO’s.
In this way, hot standby PLCs are very useful in ensuring a seamless and redundant control plant operation.
  • Electrical Wiring Diagram
  • Commissioning of DCS System
  • Single Phase Preventer Relay
  • Simatic Prosave HMI Procedure
  • Validate Timers and Counters
Configuration of Siemens VFD Using TIA Portal Start drive
PLC Program for Counting Moving Objects on Conveyor
Types of PLC Memory
Positive and Negative Edges using Statement List Language
Ladder Logic for Flow Meter Totalizer
PLC Example with Switches
Inside the PLC Control Panel: How Much Do You Know?
Motor Control Circuits
Simulation of Studio 5000 and FactoryTalk View Studio
SCADA Multiple Choice Questions
SCADA Hardware and Software
PLC Program for Alarm Security System
Introduction to Functional Block Diagram in Studio 5000
PLC Water Project
Smart Spray System using Wecon PLC
PLC analog input scaling
PLC Analog Input Scaling
Sequencer Output in PLC
PLC Sequencer Instruction with Example
What is Profibus
All About Fieldbus Protocols
Programmable Logic Controller Practice Tests
SCADA Systems
SCADA Systems
Functional Block Diagram in PLC for Oil and Water Process
Star-Delta PLC programming with 1 button
How to Program a Star-Delta System using 1 Button in PLC?
PLC Ladder Logic for Demultiplexer
1 to 8 Demultiplexer PLC ladder diagram
Asynchronous Down Counter Objective Questions
Vortex Flow Meters
All About Vortex Flow Meters
Current Earth Leakage Circuit Breaker
Types of Earth Leakage Circuit Breaker
Schottky Diode Vs PN junction Diode
Difference between Schottky Diode and PN junction Diode
Thermowell Problems
Thermowell Problems
