Reading: What is Anti Surge System?
Inst Tools > Blog > Control Systems > What is Anti Surge System?
Last updated: September 28, 2022 2:40 pm
R Jagan Mohan Rao
Control Systems
2 Comments
What is Anti Surge System? Purpose, Types, Advantages, and Disadvantages
Anti Surge systemPurpose of Anti-surge SystemBasics of Anti-surge Control SystemAdvanced dedicated Anti Surge Controller systemTypes of Anti Surge SystemAdvantages
In a centrifugal compressor, to maintain its speed at required, there is a certain capacity below which the operation is unstable. This breakdown point is called “Surge”.
Surge is a term associated with low flow.
It is the phenomena, resulting from the inability of the turbo compressor impeller to produce the amount of required energy that the process system requires.
Surge is an inherent phenomenon in centrifugal compressors, which can damage the machine. The intensity of surge varies from application to application and proportional to the density of the fluid.
Anti Surge system
Surge is a high-speed phenomenon, surge flow reversals can occur in less than 150 milliseconds. Pressure rapidly fluctuates, noise is generated. Temperature increases can be very rapid and mechanical damage can occur.
The anti-surge control system is designed to determine the surge condition in the compressor and to operate the anti-surge control valve in an efficient and speedy manner to protect the centrifugal compressor from the surge.
The quickest way to eliminate surge is to rapidly reduce the pressure buildup by opening a blow-off or recycle valve in the discharge system to maintain the required flow.
Blow off causes waste of expensive process fluid, therefore, recycle is preferred and mostly carried out by through 4-20 mA electronic operated control valve which is termed as “Anti-surge Control Valve”.
The anti-surge control controller (UIC) provides the compressor against the surge by opening the recycle valve.
Compressor Anti Surge Operation Range
Opening the recycle valve lowers the resistance felt by the compressor.
The anti-surge controller imaginary operation protection line is Surge Control LIne.The anti-surge system has to control the operating (OP) point on the right of SCL. If OP is moving leftward toward SCL, your algorithm shall open Anti-Surge Valve (ASV).
Anti Surge Controller Recycle Limit
In the advanced controller, the control action is split into two actions.
  1. PI action
  2. Recycle Trip Action.
PI action is dealt with small and steady-state disturbances while recycling trip action will cope with sudden and quick process disturbances as shown in the below figure. Two lines are introduced right to SLL for this control algorithm.
Surge control line (SCL) and surge trip line as shown in the below figure.
Surge Control Line (SCL) and Surge Trip Line
PI action will be initiated when the operating point touches the SCL line and RTL action will be initiated when the output line touches the RTL line. RTL generates a step opening response until output returns to the safe area.
Total Response = PI Control response and Recycle Trip response.
Please note that the derivative action is separate from the derivative action of the normal PID controller as this D action is only concerned with the opening of the control valve, whereas in PID controller derivative action takes part in both opening and closing the valve.
  1. Dedicated controller System ( CCC, woodward, Triconex V)
  2. Programmable Logic Controller (Siemens, Allen Bradley)
Also Read: Types of Anti Surge Control based on Process
Advantages
  1. Maximize the compressor and total train efficiency through the utilization of control parameters.
  2. Reduce process upsets.
  3. Surge can be prevented from virtually any disturbance.
  4. The compressor has more turn down before recycle.
  5. Assist the compressor process control strategy.
  • Importance of Anti Surge Control
  • What is PID Controller?
  • Control Valve Characteristics
  • PID Controller Loop Tuning
  • What is Split Range Control?
What is Alarm Prioritization? – Types of Alarms
What is PID Controller Bumpless Transfer ?
How to Create a Project in LabVIEW?
2 Comments
  • Vignesh says:
    March 23, 2020 at 1:40 pm
    Actually what is the reasons for surge what is the use of scrubber
    • manoj kumar says:
      September 30, 2023 at 6:58 pm
      1. To protect the compressor we recycle the part of discharge flow to suction to maintain the minimum suction requirement. It avoid the tripping of compressor and mechanical damage also.
      2. The use of scrubber is to avoid the fluctuations in the fluid flow to the suction to compressor.
What is PV Tracking ?
Basics of Trips, Interlocks, Permissives & Sequences
Tuning a Temperature Process Control Loop
Basics of Loop Powered Devices
Boiler Three Element Controller Philosophy
Instrumentation During the Detail Design Phase
What is a Feedback Control System
What is a Feedback Control System? Types & Advantages
HMI
Level Control Loop Principle
Integrating Processes – Liquid Level Control
main controller fails
How does a Redundant Controller comes in line when the Main Controller fails?
Opposite Acting Valves
What is Split Range Control Loop ?
PID Controller Loop Tuning Questions and Answers
PID Controller Loop Tuning Questions and Answers – Part 2
Remote User Authentication
Security of Industrial Automation Systems
Unmanaged Switch
Managed Switch vs Unmanaged Switch
Top 3 Online Bachelor’s Programs in Electronics Engineering
PLC Logic for Stairway Lighting
Smart Automation Solutions: PLC Logic for Stairway Lighting
custom metal fabrication
Custom Metal Fabrication Techniques for Quality Machined Parts
How to Choose a PLC
How to Choose a PLC for New Project? – Criteria for Selection of PLC
PWM Inverters Multiple Choice Questions
DCS Quiz
DCS Quiz
