Reading: Design a Water Pump PLC Program using CX-Programmer
Inst Tools > Blog > PLC Tutorials > Design a Water Pump PLC Program using CX-Programmer
Learn to design a water pump PLC program using CX-Programmer with dual modes: RTC activation and sensor-based control.
Last updated: June 25, 2024 12:45 pm
8 Min Read
Water Pump PLC ProgramAddressing Memory RTC in CX-ProgrammerHow The PLC Program Works?I/O ListPLC Programming
This PLC article discusses creating an automatic water pump PLC program that has 2 modes. In the first mode, the water pump will be ON every day at a certain time to fill the water tank using the RTC (Real Time Clock) function.
In the second mode, the system does not use the RTC function but uses 2 sensors (Low and High). When the tank is empty then the water pump will be ON and the pump will be OFF when the tank is full.
In the CX-Programmer, RTC data processing is allocated to Word Memory addresses A351-A354, each Word Memory address contains two RTC time units which are divided into 8-bits each in the form of BCD (Binary Code Decimal) Data Type and displayed in Hexadecimal units. RTC can calculate time units from seconds to years.
The table below contains the distribution of RTC Word Memory data.
Word Memory AreaBit AreaFunctionRange TimeData Type
A351A351.00 – A351.07Seconds00 – 59BCD
A351.08 – A351.15Minutes00 – 59BCD
A352A352.00 – A352.07Hours00 – 23BCD
A352.08 – A351.15Date0 – 31BCD
A353A353.00 – A353.07Month01 – 12BCD
A353.08 – A353.15Year00 – 99BCD
A354A354.00 – A354.07Day of the Week00 – 06 (Sunday  Saturday)BCD
Not used
Water Pump Program
This PLC Program uses 3 main buttons, the START(0.00) button is used to turn ON the system, the STOP (0.01) button is used to turn OFF the system, and the Mode (0.02) button is used for system mode selection.
By default, when the Mode (0.02) switch is in the OFF state then the system will use Mode 1, and when the Mode (0.02) is in the ON state then the system will use Mode 2.  We can only use either Mode 1 or Mode 2 at a time.
In the first Mode, when the Mode (0.02) switch is in OFF state, the time parameter needs to be set to the Word memory allocation SET_ON_DAILY_TIME (D0-D1) and SET_OFF_DAILY_TIME (D5-D6).
Memory allocation Word SET_ON_DAILY_TIME (D0-D1) is used to Set the Active Time of the water pump. Memory allocation Word SET_OFF_DAILY_TIME (D5-D6) is sued to Set the OFF time of the water pump. In this Mode, when the instruction condition is met then the Output WATER_PUMP (100.00) will be Active.
In the second Mode, when the mode (0.02) switch is in ON state and when the water tank is empty, the SENS_LOW contact (0.03) will be Active and turns ON the WATER_PUMP Output (100.00). Output WATER_PUMP (100.00) will be OFF when SENS_HIGH (0.04) is ON. Output WATER_PUMP (100.00) will only be ON when the water tank is empty.
I/O List
Addressing Input, Output, TIM, Bit Memory, and Word Memory details as follows.
CommentInput (I)Output(Q)Word MemoryMemory Bits
START0.00
STOP0.01
Mode0.02
SENS_LOW0.03
SENS_HIGH0.04
SYSTEM_ON   W0.00
Mode_1   W0.01
Mode_2   W0.02
WATER PUMP 100.00
RTC_HOUR_MINUTE_SECOND  A351
SET_ON_DAILY_TIME  D0 – D1
SET_OFF_DAILY_TIME  D5 – D6
PLC Programming
Automatic Water Pump PLC Program Using CX-Programmer
The image above shows the conditions when the system has been Activated. After the START button (0.00) is pressed (for a moment), the SYSTEM_ON Bit memory output (W0.00) will be Active. Because of the latching function, the SYSTEM_ON Bit memory output (W0.00) remains Active even though the START contact (0.00) has been Disabled.
In Rung-1, it can be seen that the system has been running because of the contact NC (Normally Close) Mode (0.02). Because the time Parameter in Word memory allocation SET_ON_DAILY_TIME (D0-D1) and SET_OFF_DAILY_TIME (D5-D6) has not been Set, the memory Output Bit Mode_1 (W0.01) cannot be Active.
Omron PLC Water Pump Program
The figure above shows the condition when the memory Output Bit Mode_1 (W0.01) has been Active. In the pop-up window, time parameters have been set to Active at “14.52” seconds “00” and will be Disabled when the clock “14.56” seconds “00” in the PLC memory.
Because the time of the RTC has been in accordance with the instruction parameters, the memory Output bit Mode_1 (W0.01) is Active.
Omron PLC Example
In Rung-3, it can be seen that the Output WATER PUMP (100.00) is ON because the Contact NO (Normally Open) Mode_1 (W0.01) is ON.
Water Pump Control with PLC
The figure above shows the condition when the RTC time has passed “14.56” hours, the memory output Bit Mode-1 (W0.01) and the WATER PUMP Output (100.00) become OFF.
The picture above shows the system has been changed to the second mode because the Mode (0.02) switch is in the ON state. Because the water tank is empty, the NC (Normally Close) contact SENS_LOW (0.03) Activates the KEEP instruction which has bit memory address Mode_2 (W0.02).
In Rung-3, it can be seen contact NO (Normally Open) of Memory Address bit Mode_2 (W0.02) is in ON state so that the Output WATER PUMP (100.00) is ON.
Water Level in the PLC Ladder Logic Program
Because the water tank is full, the NC (Normally Close) SENS_LOW (0.03) contact changes to the OFF state. The KEEP instruction becomes Disabled because the Contact NO (Normally Open) of SENS_HIGH (0.04) has been Enabled. In Rung-3, it can be seen that the Output WATER PUMP (100.00) turns OFF.
  • Timer in Studio 5000 – TON, TOF, RTO
  • PLC Control Spray Nozzle, Fans, and Puncher
  • Daily Alarm PLC Program using Real-Time Clock
  • CX-Programmer Products Sorting & Counting
  • Wood Sawing and Blower System PLC Design
PLC Program to Read Temperature in PLC
Configuring and Usage of Cyclic Interrupts TIA Portal (OB 30+)
Door Lock with Delay PLC Exercise Problems
SFC Language in PLC Programming
Basic PLC Exercise on Heater and Cooler for Students
How to Create Project in Wonderware Intouch?
Ladder Diagram Example using Memory Bits and Set Coils
PLC Programming for Baking with Auto and Manual Modes
Peripheral Inputs and Outputs in Siemens PLC
Studio 5000 Tutorial: PLC Programming for Digital Alarms
#11 PLC Best Practices – Instrument for Plausibility Checks
Types of Digital Outputs in PLC
How PLC controls a ON-OFF Valve
PLC Valve Control Ladder Logic Programming
Static and Temp Variables in PLC
CODESYS HMI Interface
Downloading Free PLC software
Step by Step Guidelines for Downloading Free PLC software
PLC-based mail box automation
PLC Program for Mailbox with Letter Counting & Light Indicators
AI AO DI DO Questions
Codesys function block example
Create a User-Defined Function Block in Codesys
Siemens PLC Organization Blocks used For Troubleshooting
Tia Portal – OB121 Programming Errors Interrupt Organization Block
Fieldbus coupling devices
Fieldbus Coupling Devices
DC Generators Objective Questions and Answers
Simple Pressure Transmitter Circuit
Pressure Transmitter using Potentiometer and Diaphragm
Advantages of HVDC transmission
Two Hand Press PLC
Two Hand Press Safety Control Circuit
Industrial motor control using PLC instruction list programming
PLC Instruction List for Motor Reverse and Forward Direction
PLC Programmer Tools
Overview of Resistor
The Information About Resistor Color Code You Should Know
