Reading: What is a Watchdog Timer in PLC?
Inst Tools > Blog > PLC Tutorials > What is a Watchdog Timer in PLC?
Watchdog timer helps to reset the CPU errors which occur during scan time so that the PLC starts working again without any manual reset.
Last updated: March 4, 2021 11:14 am
3 Min Read
In this article, we will learn about a watchdog timer in the Siemens PLC.
As we know that in the PLC when CPU process the logic it takes a certain amount of the time.
The amount of time the CPU takes to process the logic depends on the size of the program.
So, scanning from the first network to the end of the program is called one scan cycle.
For one scan cycle, time must not exceed defined cycle time and amount of time it takes to process the logic.
To check a cycle time open TIA portal.
In the programming environment go to the main CPU. Do a right-click and click on online and diagnostics.
The following new window will open up. Choose the cycle time option from it.
One thing to note is that to see cycle time you must have to stay in the online mode. In the offline mode, you won’t see anything.
In the above window, you can see a cycle time. In the cycle time measured tab, you can see a cycle time of the current program.
In the cycle time set option, the maximum time limit Is set to 6000ms means 6 seconds. This is a scan time for one cycle.
So, while execution if cycle time exceeds 6000ms then it generates an error.
Here, it comes to the watchdog timer concept. Based on a scan time when the CPU executes the logic this electronic timer starts to calculate time in the background.
If cycle time exceeds more than defined time, this electronic timer produced an error.
So for this to work, the timer starts timing from the first network and reset its timing at the end of the network.
Due to programming error or any hardware error if the CPU fails to reset the timer then it produces a time-out error.
Watchdog timer helps to reset the CPU when these types of errors occur so that the PLC starts working again without any manual reset. If the errors occur repeatedly then the watchdog timer may not helpful, human intervention is required to troubleshoot the problem.
The scan time varies from cycle to cycle because sometime FCs and FBs are not executed, or due to the manual mode of the PID loops.
This is how watchdog timer works in the background while the execution of the program.
Author: Suhel Patel
  • What is PLC Scan Time?
  • S7 1500 PLC Simulator
  • Siemens Peripheral IOs
  • Basics of DDE Protocol
  • Trends in SCADA System
Vijeo Designer software – Import and Export
Define the Order of Execution in Functional Block Diagram of Studio 5000
Factory I/O PLC Automation Training Course (Free)
Compare Two Offline PLC Projects
Communication between InTouch Scada and Allen Bradley PLC
How to Use the Shift and Rotate Instructions in PLC?
How to Control VFD with PLC using Ladder Logic
Applications of PLC Programming in Bottle Filling Process
Advanced PLC Conveyor Control: Forward and Reverse Rotation
Micro 870 Rockwell PLC
Rockwell Automation Allen Bradley PLC for Smaller and Medium Projects
ON DELAY TIMER AS OFF DELAY TIMER
Top 100 PLC Projects List
Ccomparator in PLC Programming
Comparator in PLC Programming
Preventive Maintenance of Variable Frequency Drive
Gas Turbine Temperature Control using Siemens Tia Portal
PLC Ladder Logic Questions and Answers
Split Range in Foundation Fieldbus
Foundation Fieldbus Split Range Valves
What are Pressure Sensing Lines
What are Pressure Sensing Lines? – Causes of Errors in Measurement
Full Wave Rectifier
Full Wave Rectifier
4-20mA to Process Variable conversion
Formula to Calculate Process Variable from 4-20mA
Types of Sensors used in the Dairy Industry
Analog Instruments
Types of Digital Outputs in PLC
Half Wave Diode Rectifier Quiz
