Reading: Introduction to Wastewater Treatment Works and Pumping Station
Inst Tools > Blog > Common > Introduction to Wastewater Treatment Works and Pumping Station
In this post, we discuss the instrumentation and automation role in the wastewater treatment works and pumping station.
Last updated: May 7, 2021 4:12 pm
Common Process
7 Min Read
The process of removing contaminants suspended solids and improving the quality of water in terms of oxygen content is known as water treatment.
Pumping StationProcess DiagramLevel based Control of Pumping StationLevel Flow Cascade Control Pumping StationConclusion
There are majorly two types;
  1. Water Treatment Works (WTW)
  2. Wastewater Treatment Works (WwTW).
As its name implies the wastewater treatment treats the wastewaters from Industry, Agricultural, etc.
Broadly there are following types of Wastewater Treatment Works
  • Sewage Treatment
  • Industrial Wastewater Treatment
  • Agricultural Wastewater Treatment
The water industry is going to be the most crucial in upcoming days seeing the scarcity of human usable water on earth.
Hence, it is going to be a key area for Instrumentation Engineers to automate the conventional, manually operated water treatment industry.
The environmental agencies provide chemical standards to industries based on which the quality of discharge water into water bodies like river, lakes etc. is maintained.
There are basically five stages in the wastewater treatment cycle.
  • Preliminary Treatment
  • Primary Treatment
  • Secondary Treatment
  • Tertiary Treatment
  • Sludge Treatment
Among all the above treatment stages, there is ‘n’ number of processes that are automated and operated without human intervention.
The Instrumentation Engineers play a key role in automating these processes using various components like PLC, DCS, SCADA, and HMI’s.
Hence, understanding the processes in the wastewater treatment industry is prime important to run the plant without any human interventions and also by abiding by the rules and regulations provided by environmental agencies.
One of the key processes in Wastewater Treatment is Pumping Station. We shall now look into this process in detail from an Instrumentation Engineer perspective.
Pumping Station
In wastewater treatment plant, pumping stations are used to distribute, divert, stop or stabilize the water flow.
The typical pumping station consists of a tank, pumps (fixed speed drives or variable speed drives), level instruments, switches, and flow instruments.
The pumping station can be designed and implemented in any of the five treatment stages mentioned above.
Example 1:
In Preliminary Treatment, Pumping Station acts as a Storm Tank.
Storm Tank accumulates the water into the tank during the flood situation and releases it back to the main process treatment stream when the flood situation recovers.
Example 2:
In Sludge Treatment, Pumping Station acts as Sludge Holding Tank.
Sludge Holding Tank accumulate the Sludge for treatment. The treatment includes processes like removing excess water or chemical treatment etc.
Once the treatment is finished the accumulated sludge is pumped back to the discharge area for compost and other purposes.
Process Diagram
Typical Pumping Station
As stated above the Pumping Station consists of a tank (size is site-specific), pumps (drive types, number of drives is process specific), and level flow instrumentation (level or flow control is process specific).
We shall now study a typical pumping station consisting of a tank, 2 fixed-speed drives, level instrument, level switches, and flow instrument.
The level instrument measures the level in the storage tank. Pump 1 & Pump 2 are fixed speed drives operating in Duty / Standby mode i.e. whenever the duty pump fails the standby pump shall be operational.
The flow instrument measures the outlet flow from the duty pump.
Level Based Control Pumping Station
Storage Tank Auto Operation
  1. When the level in the storage tank goes above Start Level Setpoint (SP1), the Duty Pump shall start running.
  2. The pump shall run at a fixed speed to pump the process fluid out of the pumping station.
  3. If the level in the storage tank goes below Stop Level Setpoint (SP2), the Duty Pump shall stop until the level again reaches the Start Level Setpoint (SP1).
  4. The pumps are process interlocked with a Low-Level Switch.
  5. The operator can visualize the Outlet flow & Storage Tank level using process values displayed on HMI / SCADA.
The above scenario is typical Level based control of Pumping Station.
There are ‘n’ number of scenarios that can be designed using a typical pumping station as per process requirement.
Now we will look into another scenario.
The level instrument measures the level in storage tank. The Pump 1 & Pump 2 are variable speed drives operating in Duty / Standby mode i.e. whenever duty pump fails the standby pump shall be operational.
The flow instrument measures the outlet flow from the duty pump and controls the speed of the pump using a Proportional Controller (P).
  2. The speed of the pump shall vary proportionally to the Flow Setpoint (SP3) entered by the operator at HMI / SCADA.
  4. The pumps are process interlocked with Low-Level Switch & Low Flow measured by Flow Instrument.
Conclusion
We understood the basic operation of a typical pumping station along with two scenarios. It’s up to Design Engineer to design the process as per site requirement.
The Automation Engineer then automates the proposed process using PLC, DCS, SCADA, and HMI’s to operate the Plant with minimal human intervention.
Author: NMG
  • Safety Instrumented System Example
  • Basic Concepts of the Safety Relay
  • What are Positive Displacement Pumps?
  • Accuracy, Tolerance, Uncertainty, and Error
  • Difference between Analog and Digital Signals
Desuperheater Design
Strainers
4-wire Transmitters Current Loops
Various Types of Engineering Courses
Properties of Liquefied Petroleum Gas (LPG)
Capping Machine – 5 Aspects of Control Systems and Automation
What is PDCA? – Industrial Maintenance
What is a Fotonic Sensor? – Working Principle, Advantages, Disadvantages
Comparison of Humidity Sensors – Industrial Instruments
Control of Pneumatic Cylinder and Motor
Hazards of Compressed Air
Next-Generation Security Surveillance Systems – AI Technology
How is Electricity Generated From Wind Energy?
Heat Exchanger Root Cause Analysis (RCA)
How Does Starlink Work
How Does Starlink Work?
Product Packaging Automation
Why Does Product Packaging Matter in Retailing?
Custom CNC Machining Complete Guide
Custom CNC Machining – A Complete Guide You Cannot Miss
List of 100 Sensors and Transducers Questions
Instrument Skid
What is an Instrument Skid? – Example of Metering Skid
Pumps Quiz
Pumps Quiz
Polyvinyl Alcohol in Oil Field
Roller Conveyor
Difference Between Belt Conveyor and Roller Conveyor
Control Valve Split Range Example - 2
Non-variable reducing valves
What is Reducing Valve ?
Weigh feeders Principle
What is a Weigh Feeder?
CODESYS HMI Interface
Butterfly Valve
Butterfly Valves Construction, Types, Stem & Bonnet Assembly
Introduction to MEMS (Microelectromechanical Systems)
Series Air Fuel Combustion Control
Combustion Control – Series and Parallel Air-Fuel Ratio Control
Conductivity Meter
How to Select a Conductivity Meter
