Reading: All About Vortex Flow Meters
Inst Tools > Blog > Flow Measurement > All About Vortex Flow Meters
Vortex flow meters measure fluid velocity using a principle of operation referred to as the von Kármán effect to calculate the flow rate.
Last updated: November 2, 2023 1:23 pm
Flow Measurement Instrumentation Design
In this article, we shall learn about Vortex Flow Meters.
Vortex Flow MetersApplications of Vortex Flow MetersCharacteristics of Vortex Flow MetersLimitations of Vortex Flow MetersInstallationVortex Meters Operating Conditions
A vortex train is generated when a bluff body is placed in a pipe stream containing liquid or gas. This train consists of high and low-pressure areas which can be measured by a specially manufactured sensor.
Vortex flow meters measure fluid velocity using a principle of operation referred to as the von Kármán effect, which states that when flow passes by a bluff body, a repeating pattern of swirling vortices is generated.
Vortex Flow Meters
Vortex Flow Meters
In a Vortex flow meter, an obstruction in the flow path, often referred to as a shedder bar, serves as the bluff body.
The shedder bar causes process fluid to separate and form areas of alternating differential pressure known as vortices around the backside of the shedder bar.
The number of formations of these vortices depends on the flow rate, if we measure these vortices we can get the equivalent volumetric flow rate.
Also Read: Types of Vortex Sensors
Vortex meters are commonly used in the following services:
  • Cooling water.
  • Process water.
  • Light hydrocarbons where large turndown is required.
  • Gas flow where large turndown is required.
Vortex meters have the following characteristics:
  • Wide rangeability (for Reynolds numbers above 10,000).
  • An accuracy of 1 percent of the rate.
  • A wide range of sizes.
  • Linear output.
  • Availability of pulse and analog outputs.
Vortex meters have the following limitations:
  • A limited range of construction materials is available.
  • Vortex meters are generally not suitable for slurries or high-viscosity liquids.
  • Users cannot check calibration.
  • Turbulent flow is required.
  • Vortex meters have over range limitations.
  • Strainers may be required.
  • Vortex meters are affected by pulsating flow.
Installation
Vortex meters are installed directly in the process piping and are normally supported by the piping. They may be installed in any orientation. A vortex meter should be installed so that the meter body is not subjected to piping strain.
In liquid applications, the piping should be arranged so that the meter is kept full. Block and bypass valves should be provided when operating conditions do not permit shutdown.
Vortex meters are sometimes damaged during the start-up of new installations as a result of debris in the line. The line should be flushed and hydrostatically tested before the meter is installed.
Since the velocity profile is critical, it is imperative that gaskets not protrude into the flow stream when flanged meters are installed. Field calibration of vortex meters is limited to electrically spanning the converter or, on a pulse-output type, adjusting the scaling factor.
Vortex flow meters offer many advantages for flow measurement including easy installation without impulse lines, no moving parts to maintain or repair, less leak potential, and a wide flow turndown range. Vortex meters also offer very low power consumption, allowing for use in remote areas.
Additionally, Vortex meters are unique in that they can accommodate liquids, gasses, steam, and corrosive applications. Vortex flowmeters are also able to withstand high process pressures and temperatures.
Here we shall see which type of vortex meter to use in different operating conditions and services.
Vortex Flow Meters Operating Conditions
Interest to add any further points? Share with us through below comments section below.
Author: Kalpit Patel
  • Wiring of Solenoid and PLC
  • Orifice Plate Design Rules
  • Level Instruments Specification
  • Variable Area Flow Meter
  • All About Turbine Meter
Temperature Gauges and Elements : Detailed Specifications
Difference between DCS & PLC Systems
What is Marshalling Cabinet?
Floating Vs. Grounded Voltage
Testing of Pneumatic Systems
Field Instruments Selection Aid
Differential Pressure (DP) Flow Meters Range Calculation Methods
Interactions With Process Control Systems Philosophy
Pneumatic Valves and Cylinders Sizing – Part 2
Flow Meter K-factor and Calculations
Flow Instruments – Selection, Principle & Application
What is a Segmental Wedge Flow Meter?
Pressure Temperature Compensation Flow Measurement
Solenoid Valves Selection Guidelines
Electrical and Instrument Engineers Job Profile
Instrumentation and Electrical Teams Interactions (Detail Design Engineering)
Relay Permissive and interlock circuits
Gas Detectors Location Installation
Gas Detectors Installation Techniques
sinking-and-sourcing-digital-output-modules
PLC Digital Signals Wiring Techniques
Instrument Air Compressor Control Philosophy
plc-analog-signals-wiring-techniques
PLC Analog Signals Wiring Techniques
Instrumentation Design Details
Temperature-gauge-calibration
Temperature Sensor calibration procedure
Three Phase AC Generators
Metal Foil Strain Gauge Principle
Foundation Fieldbus Interview Questions and Answers
Instrumentation Standards
Electronic Equipment Purging Principles & Standards
Transformer Protection using fire water spray system
Fire Water Spray Systems Principle
Industrial IoT Job Roles and Responsibilities
IoT Engineer Job Roles and Responsibilities
PLC Examples for calling functions in SCL
