Reading: Vortex Flow meter Animation
Inst Tools > Blog > Animation > Vortex Flow meter Animation
A vortex flow meter comprises a flow sensor to sense pressure variations due to vortex-shedding of a fluid in a passage and measure flow rate.
Last updated: October 31, 2023 12:17 pm
Animation Flow Measurement How It Works
2 Min Read
A vortex flow meter comprising a flow sensor operable to sense pressure variations due to vortex shedding of a fluid in a passage and to convert the pressure variations to a flow sensor signal, in the form of an electrical signal.
Vortex Flow MeterApplications of Vortex Flow Meters
A signal processor is operable to receive the flow sensor signal and to generate an output signal corresponding to the pressure variations due to the vortex-shedding of the fluid in the passage.
Vortex Flow Meter
Vortex Flow Meters Animation
When the medium flows through the Bluff body at a certain speed, an alternately arranged vortex belt is generated behind the sides of the Bluff body, called the “von Kármán vortex”.
Since both sides of the vortex generator alternately generate the vortex, the pressure pulsation is generated on both sides of the generator, which makes the detector produce alternating stress.
The piezoelectric element encapsulated in the detection probe body generates an alternating charge signal with the same frequency as the vortex, under the action of alternating stress.
The frequency of these pulses is directly proportional to the flow rate. The signal is sent to the intelligent flow totalizer to be processed after being amplified by the pre-amplifier.
f = St×V/d
Wherein,
f is the releasing frequency of the Carmen vortex,
St is the Strouhal number,
V is velocity, and
d is the width of the triangular cylinder.
The vortex flow meter is relatively economical because of its simple flow measurement system and ease of maintenance.
Vortex Flow Meters are widely used in heavy industrial applications, power facilities, and energy industries, particularly in steam processes
  • Basics of SIL Verification
  • Instrumentation Earthing
  • Impulse Piping for Field Instruments
  • Pressure Transmitters Purge Lines
  • Principle of Vortex Flow Meter
Open Tank Level Measurement using DP Transmitters Animation
What is Differential Pressure Flow Meter?
How a 4-20mA Transmitter Works?
Types of Pneumatic Actuators Animation
Differential Pressure (DP) Flow Meters Range Calculation Methods
Laminar Flow Meter Working Principle
What is a Condensate Pot? How to Install it?
Fire Water Sprinklers Working Principle
Magnetic Level Gauge Working Principle Animation
What is a Variable Area Flow Meter?
Swirl Flow Meters Working Principle
Turbine Flow Meter Coefficient and Scaling Factor
What is an Averaging Pitot Tube? – Principle, Advantages
Coriolis Mass Flow Meter as a Multi-Variable Transmitter
Comparison of Venturi and Orifice flow meterComparison of Venturi and Orifice flow meter
Applications of Tilting Level Switch
How Tilt Level Switch Works ?
Orifice Specifications
Turbine Flow Meters Working Animation
Turbine Flow Meters Animation
Float Level Switch Principle
Float Level Switch Working Principle Animation
Electro Magnetic Flow Meter Animation
Bernoulli's Principle
Bernoulli’s Principle and Equation – Flow Measurement
Orifice Taps
Orifice Plate Tapping – Orifice Plate Taps
Simple Conveyor Control PLC Program
XG5000 Example of Simple Conveyor Control PLC Program
Inverse Transducers Objective Questions
Installation & Commissioning Tips for Wireless HART Devices
Installation & Commissioning Tips for HART Devices
Ultrasonic Flow Meters Working Principle
Library of PlantPAx Process Objects
Static and Dynamic Characteristics of an Instrument
instrumentation-calculator
Instrumentation Calculator
Flow Control Valves Interview Questions
