Reading: V Cone Flow Meter – Principle, Advantages, Disadvantages
Inst Tools > Blog > Flow Measurement > V Cone Flow Meter – Principle, Advantages, Disadvantages
V Cone flow meter is a differential pressure (DP) meter. These flow meters all work according to the same principle of DP flow sensors or devices.
Last updated: November 1, 2023 5:40 am
Flow Measurement
The V-Cone flow meter like several other popular meters is a differential pressure (or “DP”) meter. These meters all work according to the same principle of DP flow devices.
V Cone Flow MeterPrinciple of OperationAdvantages of V Cone Flow MeterDisadvantages of V Cone Flow Meter
That is an obstruction in the pipe (i.e., a reduction in the cross-sectional area available to the flow) causes an increase in flow velocity and a corresponding reduction in pressure.
V Cone Flow Meter
Hence by measuring the upstream pressure, the temperature, and the difference in the static pressure between the upstream and the minimum cross-sectional areas, the flow rate can be determined as long as the fluid properties are known. The flow rate determination is done by applying the laws of conservation of mass and energy.
However, there are important differences between the V-Cone meter design and other DP meter types. These differences give the V-Cone meter important performance advantages.
These advantages include the ability of the V-Cone meter to operate with very short upstream and downstream straight pipe lengths, to create a low total pressure (or “head loss”), to create a very stable DP, to give a large turndown, to create relatively low signal noise and to cope well with liquid and particulates in the gas stream.
Cone meters (e.g. V-cones) are proprietary meters and are essentially an inverted Venturi tube. Instead of a contraction in the pipe, the fluid flows around a central cone as shown in the following diagram.
V Cone Flow Meter Working Principle
Cone meters have proved popular as it is claimed they require very little upstream straight pipework before the meter to provide accurate measurements. This benefit is due to the fluid flowing around the cone which is described as “conditioning” the flow.
One of the downsides of cone meters is the lack of standards governing this type of meter, as they have been a proprietary device, and there has been a lack of independent data available to provide confidence in claimed performance.
Unlike Venturi tubes, orifice plates, and nozzles, which are manufactured to tolerances specified in ISO 5167, cone meters are not manufactured to a specified tolerance and must be individually calibrated before use.
The V-Cone flow meter is a differential pressure type flow meter. Basic theories behind differential pressure-type flow meters have existed for over a century.
The principal theory among these is Bernoulli’s theorem for the conservation of energy in a closed pipe. This states that for a constant flow, the pressure in a pipe is inversely proportional to the square of the velocity in the pipe.
Simply, the pressure decreases as the velocity increases. For instance, as the fluid approaches the V-Cone flow meter, it will have a pressure of P1.
V Cone Flow Meter Principle
As the fluid velocity increases at the constricted area of the V-Cone, the pressure drops to P2, as shown in Figure 1. Both P1 and P2 are measured at the V-Cone flow meter’s taps using a variety of differential pressure transducers.
The DP created by a V-Cone flow meter will increase and decrease exponentially with the flow velocity. As the constriction takes up more of the pipe’s cross-sectional area, more differential pressure will be created at the same flow rates.
The beta ratio equals the flow area at the largest cross-section of the cone (converted to an equivalent diameter) divided by the meter’s inside diameter
  • Lower sensitivity than orifice plates and Venturi tubes to installation effects
  • Shorter installation lengths
  • Less pressure loss than orifice plates
  • Wafer (between flange) versions
  • Effective for wet gas flow measurement applications
  • Lack of standards
  • Not as much data available as “ISO 5167” meters
  • Pressure loss higher than Venturi tubes
  • Types of Flow Meters
  • Turndown Ratio of Flow Meter
  • Capacitive Pressure Sensor
  • Two-Liquid Manometer Principle
  • Interface Level Measurement
Orifice Plate Questions and Answers
Reasons to Calibrate Different Types of Flow Meters
Read Gas Composition from Gas Metering System using RS485 Protocol
Microwave Flow Sensor – Working Principle and Applications
All About Variable Area Flow Meters
  • zankat sandipsinh says:
    June 15, 2016 at 11:05 am
    thank u sir
What are the Orifice Plate Flow Requirements?
Types of Vortex Flow Meter Sensors
Difference between Orifice & Restriction Orifice
What is an Insertion Flow Meter? – Types, Principle, Advantages
Orifice Plate Tapping – Orifice Plate Taps
Turbine Flow Meter Coefficient and Scaling Factor
What is a Torbar? – Averaging Pitot Tubes
Phase Watcher Multiphase Flow Meter (MPFM) Procedure
Velocity-based Flowmeter
What is a Velocity-based Flow Meter?
Sick Flow meters
Flare Ultrasonic Flow Meter – SOPAS Engineering Tool
Open Channel Flow Measurement Animation
Open Channel Flow Measurement Principle
Venturi Flow Meter Theory
Basics of Venturi Flow Meter
DP type Flow Transmitter Calibration
DP type Flow Transmitter Preventive Maintenance and Calibration
Flow Element Symbol
What is a Flow Element? – Types, Comparison of Flow Elements
Instrumentation Impulse Lines
All About Instrumentation Impulse Lines
Servo Operated Electro Magnetic Flowmeter Objective Questions
Siemens PLC Block Diagram
Programmable Logic Controller (PLC) Questions and Answers – 14
Full Wave Rectifiers Objective Questions and Answers
Packaging Machinery
Poor Bagging Scale Availability Threatened Production Cuts
DTS sensors
Distributed Temperature Sensors (DTS) in Power Lines
Best Online Courses to Learn Electrical Engineering
Viscosity Measurement Objective Questions
quadruple block valve
What is Safety Instrumented Functions ?
Count the Number of Bottles
Count the Number of Bottles in Packaging Carton PLC Logic
