Reading: Types of PLC
Inst Tools > Blog > PLC Tutorials > Types of PLC
Types of PLC
The types of PLC are classified based on size, Hardware setup, Power Supply.
Last updated: October 17, 2023 2:12 pm
3 Min Read
PLC Types Based on SizePLC Types Based on Hardware SetupCompact PLCModular PLCPLC Types Based on Power SupplyVideo Lesson
  1. Size
  2. Hardware setup
  3. Power Supply
Types of PLC Animation
The PLCs are further classified depends on the number of inputs and outputs a PLC can handle.
The PLCs are classified based on size are as follows
  • Nano PLC
  • Micro PLC
  • Medium
  • Large
  • Very Large
The memory capacity of these PLCs are also varies based on their I/O capacity.
The PLCs are also classified based on the architecture of a PLC.
Compact PLC
The PLC processor and I/O modules are integrated into one simple electronic module or also called as compact type PLC.
What is Compact PLC
In compact type PLC, we can use expansion modules to add more number of inputs and outputs to the existing compact PLC as these have a limited number of I/O’s by default.
Modular PLC
In modular type PLC, each component or module has independent cards, these may be CPU card, Analog input card, Digital output card, a communication card, etc.
Types of PLC
These cards can be easily inserted or removed from the running system. These are like plug and play modules. We have to give a software download after inserting the new card as per the requirement.
Sometimes we use redundant cards for CPU, I/O modules, communication modules, etc.
Some PLC manufacturers have an inbuilt option to auto copy the software from the main card to the redundant cards in case of replacing the redundant cards due to any failure.
In modular PLC, we have two types of installations available.
  1. Rack
  2. Chassis
PLCs are available with or without SMPS.
  1. PLC with SMPS (230 VAC)
  2. PLC without SMPS (24 VDC)
Some PLCs can be connected to a 230 VAC power supply directly to it. This means these have inbuilt SMPS which converts the supplied 230 VAC into the standard 24 VDC.
Some PLCs needs a 24 V DC which doesn’t have the inbuilt SMPS. In this case, we need an external switched-mode power supply (SMPS) for the conversion of 230 VAC into 24 VDC.
Video Lesson
PLC Training 4 - Classification of PLC based on Size, Hardware, and Power Supply
  • PLC Questions and Answers
  • How to Select the PLC SPares?
  • Pause the PLC Timer Logic Example
  • PLC Logic Force and Modify
  • History of Programmable Logic Controller
What is Recipe Management in SCADA?
Top PLC Manufacturers
#4 PLC Best Practices – Use PLC Flags as Integrity Checks
PLC Programming for Loss in Weight Liquid Systems
Features of Scada Which are Must in an IoT System
PLC Program Example on Multiple LEDs using Set Coil
Real-time PLC Projects – Industrial Automation
If Else Statement in SCL Language
SCADA Hardware and Software
PLC Program to Simulate Gate Array Logic
How to Convert an Electrical Diagram into PLC Program?
Programmable Logic Controller Practice Tests
PLC Automatic Control of Two Outputs with one Input
factorytalk view studio hmi
How to Create Templates in FactoryTalk View Studio?
Master Control Reset (MCR) ladder logic
How to use Master Control Reset (MCR) Instruction in PLC
PLC Cabinet
PLC Programming Videos
Structured Text Automatic Gate Logic
Structured Text PLC Programming for Automatic Gate Control
GSD File installation in Simatic Manager
How to Install GSD File in Step 7 PLC using Simatic Manager?
Ladder Diagram Example using Memory Bits and Set Coils
Flexible Input Output Modules
Cathode Ray Tube Deflection System
Equivalent Circuit of Transformer
Belt Sway Switch Principle
Belt Sway Switch Working Principle
Use of Temperature Transmitters instead of Direct Wiring
3-way-2-position-solenoid-valve-spring-return
Pneumatic Directional Control Valves
Difference Between LAN and WAN Networks
Steam Pressure Taps Primary Block Valves Glands and Bonnets Leaks
Instrument Steam Pressure Taps Primary Block Valves Glands and Bonnets Leaks
