Reading: Timers in Codesys – Timer ON, Timer OFF, Pulse Timer
Inst Tools > Blog > PLC Tutorials > Timers in Codesys – Timer ON, Timer OFF, Pulse Timer
Codesys is a widely used platform in industrial automation systems. Learn the timers in Codesys which are Timer ON, Timer OFF, Pulse Timer.
Last updated: July 12, 2024 2:03 pm
Codesys is a widely used platform in industrial automation systems. Codesys is an open platform framework that has it’s own set of design screens, function blocks, symbols, syntax, and other formats.
Timers in CodesysTypes of Timers in CodesysTON (Timer On)TOF (Timer Off)TP (Pulse Timer)
Many popular automation vendors like Schneider Electric and Mitsubishi Electric implement this platform in their range of PLCs. One of the most used instructions in any programming language is a timer.
Timers in Codesys
Any timer that is used in the Codesys platform has the following types of inputs and outputs – IN, PT, Q, and ET. IN and PT are the input pins and Q and ET are the output pins. IN is the input where the timer condition is linked to turn it on or off.
PT is the setpoint of the timer (means how much time the timer should run). Q is the output bit of the timer which turns on when the timer action is completed. ET is the elapsed value of the timer (means the current time running in the timer). These 4 pins are the ones you will find common in any of the timers used in Codesys.
One thing to note is that the setpoint and elapsed time here are in time format, not real or double integer formats as used in other PLC platforms. Time format means the timer values work in milliseconds. So, if you want to run the timer for 1 second, then the input format will be t#1s or t#1000ms.
In this way, you get to define the exact time with accuracy as per your requirements. If you want to write the setpoint from HMI or SCADA, where time format is not supported, you will have to use an integer or a double integer in graphics and use an integer-to-time conversion block in PLC. If you have to show the timer’s current value in graphics, you have to use the time to integer conversion block in PLC.
The main timer instructions used in CodeSys are TON, TOF, and TP.
TON (Timer On)
The Timer-On type is an on-delay timer. It means that when the input is received, the output turns on after the set time elapses. In between, if the input goes false, then the timer’s current value too becomes zero.
TON Timer in CodeSys
As long as the input condition is true, the timer will work. If the input is true and the set time elapses, then the output remains true as long as the input is true.
TOF (Timer Off)
The Timer-Off type is an off-delay timer. It means that when the input is received, the output turns on. When the input goes off, then the timer starts and after the set time elapses, the output goes off.
TOF Timer in CodeSys
In between if the input goes true, then the timer’s current value too becomes zero and the output remains on. As long as the input condition is false after the true condition, the timer will work. If the input is false and the set time elapses, then the output goes false.
TP (Pulse Timer)
The TP timer type is a pulse delay timer. It means that when the input is received as a positive pulse or negative pulse, the output turns on for the set time. After the set time elapses, then the output goes false.
TP Timer in CodeSys
In between, whatever be the condition of the input, the timer will remain on till the set timer elapses and during that time, the output too will remain on. That means it is a latch-type instruction.
  • Algorithms in PLC Programming
  • Industrial Automation Mobile App
  • Principle of Single-Phase Preventer Relay
  • Omron PLC Programming Course in HINDI
  • Which Language is Best for PLC Programming?
PLC Memory Organization – Data Files and Program Files
Top Free PLC Software
PLC Program to Separate Different Size Objects
Your First Steps Through STL Language
FactoryTalk Studio and SQL Server for Data Logging
Delta PLC Counter with Comparison
Difference Between PNP and NPN Sensors
Step by Step Guidelines for Downloading Free PLC software
PLC 1 Push Button to Turn ON or OFF 1 Output
How to Install GSD File in Step 7 PLC using Simatic Manager?
Control Speed of an Induction Motor using Analog Output of PLC
Control Speed of Induction Motor using Analog Output of PLC
PID with Practical Example
Water Treatment Plant SCADA
Typical HMI Screen Design for Water Treatment Plant
PLC analog output card
PLC Analog I/O and Network I/O
PLC Programming for Train Detection and Gate Operation
PLC Program for Valves
PLC Pump Permissive Interlocks
PLC Program Paint Spraying
PLC Program for Paint Spraying
While Do Statement in Structured Text PLC Program
Drum water level control
Closed Loop Control System : Boiler Water Level Control System
Digital Electronics MCQ
Quine McCluskey Logic Functions Objective Questions
capacitance probe
Capacitance Level Measurement Working Principle
Elevator PLC Ladder Logic
Choke Valve Hydro Test Setup
Choke Valve Hydro Testing Procedure
Level Gauge Working Animation
Sight Glass Level Measurement Principle
Bourdon Tube Gauge Spiral Spring
What is the Purpose of Bourdon Tube Gauge Spiral Spring?
energy-diagrams-for-insulator-semiconductor-and-conductor
Band Gap for Semiconductor Materials
