Reading: How to Test TRIAC with Multimeter
Inst Tools > Blog > Power Electronics > How to Test TRIAC with Multimeter
Last updated: September 19, 2016 4:10 am
Power Electronics
7 Comments
2 Min Read
How to test TRIAC with Digital Multimeter OR using Ohmmeter?
In this short post we will discuss about how to test the Triac.
triac
Introduction about Triac:
  1. TRIAC = TRIode for Alternating Current.
  2. The TRIAC is 5 layer, 3 terminal Power semiconductor device.
  3. It has a pair of phase controlled SCRs connected in inverse parallel manner on the same chip.
  4. It is a bidirectional device, means it can conduct current in both the directions.
Procedure to test the TRIAC
Step by step Procedure to test the triac:
  1. Keep the digital multimeter into Ohmmeter mode.
  2. Using a junction diode determine which ohmmeter lead is positive and which is negative. The ohmmeter will indicate continuity only when the positive lead is connected to the anode and the negative lead is connected to the cathode.
  3. Connect the positive lead of Ohmmeter to MT2 and the negative lead to MT1. The ohmmeter should indicate no continuity through the triac.
  4. Using a jumper lead connect the Gate of the Triac to MT2. The multimeter should indicate a forward diode junction.
  5. Reconnect the Triac so that MT1 is connected to the positive lead of ohmmeter and MT2 is connected to the negative lead. The multimeter should indicate no continuity through a Triac.
  6. Using a jumper lead, again connect the gate to MT2. The ohmmeter should indicate a forward diode junction.
Turning Off SCR – Commutation
What is Power Electronics? Evolution, Block Diagram, Advantages
Thyristor Commutation Techniques – Types, Working Principles
Power Electronic Devices Specification and Classification
MCT (MOS Controlled Thyristor) – Symbol, Working, Characteristics, Advantages
Introduction to Thyristor – History, Types, Principle, Advantages
7 Comments
  • Jesse says:
    March 9, 2020 at 10:26 pm
    I am currently testing a triac, I’m getting readings in megaohms across M1 and M2 , is that close enough to no reading or open?
    • Andres says:
      June 30, 2021 at 3:55 am
      I am getting readings around 50 ohm with floating gate pin. Mine obviously is damaged.
      You should test it with the diode option not the ohms.
      • Joe says:
        August 11, 2021 at 8:03 am
        hai andres.. What is the actual reading (ohm) for the triac after test. If still inbgood condition. Tq
  • Himynameis says:
    October 11, 2022 at 1:10 am
    I observed that one of the pins should conduct with the tab. If none conducts, you have a broken triac.
  • André Giguère says:
    April 15, 2023 at 4:49 am
    Very interesting article on how to test a TRIAC
  • S. X. says:
    September 19, 2023 at 4:51 am
    I have some new Triacs. Pin1, 2, 3 are A1,A2,G.
    50 Ohm is between A1 and G.
  • jose protacio says:
    May 9, 2024 at 8:02 am
    hi S.X.
    mine reads about 60 ohms forward and reverse A1 to G and its good
Phase Controlled Rectifier – Half Controlled Rectifier with R Load
Crowbar fault protection circuit
R R-C Firing Circuits Disadvantages
Types of IGBT
Top 100 Power Electronics Projects for Engineering Students
Power Transistor – Structure, Biasing, Characteristics, Advantages
Power Diode – Characteristics, Construction, Working, Advantages
Phase Controlled Half Wave Rectifier RL Load
Power Electronics – Phase Controlled Half Wave Rectifier RL Load
RC Triggering
SCR Triggering Methods
Basics of Thyristor
Basics of Thyristor
Full-Controlled Rectifier Working Principle
Single-Phase Mid-Point Converter – Bridge Rectifier with Center Tap
Power MOSFET Symbols
Power MOSFET – Symbol, Types, Working, Characteristics, Advantages
How to test SCR using Multimeter
Resistance firing of an SCR in a half-wave circuit
Thyristor Triggering Circuits – Types, Explanation, Waveforms (SCR)
pn-junction-energy-diagrams
Energy Diagrams of PN Junction & Depletion Region
PLC Motor Control Circuit
Motor Trip Logic using PLC Programming
How do AC drives work
How do AC Drives Work? – Variable Frequency Drive (VFD)
Problem in Water Level Control System
PLC based Automatic Bell System
PLC based Automatic Bell System for a School
Argonite Fire Suppression System Animation
Argonite Fire Suppression System Working Principle
Questions on Level Switches
