Reading: Surface Grinding Process using PLC Program
Inst Tools > Blog > PLC Tutorials > Surface Grinding Process using PLC Program
Last updated: March 4, 2021 3:48 pm
3 Min Read
Implement PLC ladder logic for automatic surface grinding process. Grinding process is an example PLC Program using RSLOGIX 500 software.
PLC based Grinding ProcessStep Conditions:List of Inputs and OutputsPLC ProgramLogic Description
Step Conditions:
  1. Start PB is to start the process.
  2. At initial, Job in sensor should be in ON condition and job out sensor should be in OFF condition.
  3. When job in sensor detects object for surface grinding should turn on conveyor motor to move the object.
  4. When rough sensor detects object, conveyor motor should turn OFF and Rough grinding motor should turn ON for 20s. After the process, Conveyor motor should turn ON automatically.
  5. When fine sensor detects object, conveyor motor should turn OFF and Fine grinding motor should turn ON for 20s. After the process, Conveyor motor should turn ON automatically till job out sensor turn ON.
  6. Packing sensor should turn ON, when job out sensor ON.
PLC based grinding system inputs and outputs
PLC Program
PLC Grinding Logic
PLC based automatic grinding system
Logic Description
RUNG000
Latching rung to operate the system through Master Start and Stop PB.
RUNG001
To save the status of Job in sensor and Job Out sensor, Memory coil is used.
RUNG 0002
Conveyor Motor turned ON when All the sensors are in Home condition.
Rung 0003
Jump Instruction is used to skip the rough grinding  process in any case.
Rung 0004 and RUNG 0005
When Rough sensor detects object, Conveyor motor should turn OFF and  Rough grinding motor will turn ON for 20 sec. After 20 sec, Conveyor motor should turn on automatically.
Rung 0006
Jump Instruction is used to skip the Fine grinding  process in any case.
Rung 0007 and RUNG 0008
When Fine sensor detects object, Conveyor motor should turn OFF and  Fine grinding motor will turn ON for 20 sec. After 20 sec, Conveyor motor should turn on automatically
Program runs continuously until STOP PB is pressed.
Note: In this program, JUMP function is used to skip the rough grinding process and fine grinding process because some objects need only rough or fine grinding or in some maintenance case jump function is used to skip the process.
Conclusion:
The above explained Surface grinding process is for example only.
Author : Hema Sundaresan
PLC Mixing Process Logic
Industry Shutter PLC Operation
PLC Practice Questions
PLC Cabinet Earthing
Test Process Control Loop
Establish Communication Between Two PLC Via PROFIBUS Protocol
UPS Working Principle and Types – Offline and Online UPS Systems
Motion Detection based Street Light: PLC Logic Solution
PLC Data Comparison Instructions
Create PLC Program based on Logic Circuit
  • Meghavath Jama says:
    March 12, 2023 at 1:49 pm
    Setpoints & Alarms in Control Systems
PLC Based Industrial Conveyor Ladder Logic
Step by Step Guidelines for Downloading Free PLC software
User Defined Data Types (UDT) – Purpose, Need, Tutorial
MCQ on PLC (Programmable Logic Controller)
Feedback Monitoring in Safety PLC
PLC Program for Flow Totalizer
Automatic Packing of Bottles Programming
Data Handling Instructions in PLC Programming
PLC Based Metro Automation Project
PLC based Metro Automation Project
IP Address Change in Simatic
PLC Configuration of Profinet I/O System
Function and Application of FIFO Block
How to use FIFO Block in TIA Portal? – Siemens PLC Programming
how-a-plc-do-the-scaling-for-a-sensor
How a PLC do the Scaling for a Sensor ?
Studio 5000 Tutorial PLC Programming for Digital Alarms
Studio 5000 Tutorial: PLC Programming for Digital Alarms
PLC Program for Car Parking
PLC Program for Entry and Exit Control of Car Parking
PLC Circuit with Switches
PLC Example with Switches
Functions of Instrument Transformers
Functions of Instrument Transformers (CTs and PTs)
Argonite Fire Suppression System Animation
Argonite Fire Suppression System Working Principle
Piezo Electric Transducers Objective Questions
Digital Electronics MCQ
Binary Coded Decimal (BCD) Objective Questions
Difference Between LAN and WAN Networks
Industrial Automation Protocols
PLC Program for Conditional Control Logic
Stepper Motor Working Principle Animation
