Reading: Structured Text PLC Example for Motor Interlocking and Control
Inst Tools > Blog > PLC Tutorials > Structured Text PLC Example for Motor Interlocking and Control
In this Structured Text PLC Example, learn how to interlock two motors and run them simultaneously to control them as per logic.
Last updated: September 17, 2024 11:19 am
Motors are a common type of output used in industrial automation. Motors control and interlocking must be properly done by a programmer for efficient and reliable operation. When he is writing the logic, he often thinks first which language to write in.
Motor Interlocking and ControlStructured Text PLC Example
One of the most highly popular languages in PLC programming is structured text. Due to it’s syntax similar to an IT language program, it is preferred for complex calculations and logic writing. In this post, we will see how to interlock two motors and run them simultaneously through structured text PLC programming.
Let us understand the case scenario first. There are two motors in the circuit. When the start button is pressed, the first motor will run for 10 seconds and after that, it will stop and the second motor will run for 10 seconds. This continues until the stop button is pressed, which resets and stops the whole logic. Now, when the first motor is running and someone presses the bypass button, then it will stop immediately and start the second motor. The same goes for the second motor.
Now, let us start the logic development. First, let us freeze the IOs.
There are four digital inputs – start push button, stop push button, motor-1 bypass button, and motor-2 bypass button.
There are two digital outputs – motor-1 and motor-2.
Refer to the below image. As per the first condition, when the start button is pressed, then logic starts. So, we write it in an if statement and set the logic running bit to 1.
Now, when the stop button is pressed, then logic stops. So, we write it in an if statement and set the logic running bit to 0.
Now, we start the timer logic. When logic starts, then motor-1 runs for 10 seconds and then stops. So, we link the logic running bit and an internal bit – motor-1 timer done bit as negate. When the timer finishes, then we set motor-1 timer done bit to 1 and this cuts off the timer-1.
Next, motor-2 runs for 10 seconds after motor-1 timer has been done and then stops. So, we link the logic running bit and the internal bit – motor-1 timer done bit. When the timer finishes, then we set motor-1 timer done bit to 0 and this cuts off the timer-2. The cycle repeats once again.
To bypass the timers, we have used two separate push buttons. On pressing the motor-1 bypass button, timer-1 will be done immediately. So, we link it with the OR condition with the motor-1 timer done. On pressing the motor-2 bypass button, timer-2 will be done immediately. So, we link it with the OR condition with the motor-2 timer done.
Now, to turn the motors on or off, we link the timer input condition to it. This makes the logic simple to use.
In this way, we saw how to operate the motors simultaneously with interlocks.
  • PLC Ladder Logic for Alarm Security System
  • How Modbus is used in Industrial Networks?
  • Conveyor Speed Logic using Structured Text
  • FBD PLC Example for Traffic Light System
  • Burglar Alarm Security System PLC FBD Logic
What is a Wet Contact? – Basics of PLC Wiring
Instrumentation Earthing
PLC based Gas Detection System using Ladder Logic Project
Structured Text in PLC: Parking Information Systems
Allen Bradley PLC Interview Questions and Answers
  • Abduslam sultan says:
    October 14, 2024 at 4:00 pm
    thanks for great subject and good explanation
PLC Program for Food Processing Industry
Pulse Generation using Timer in Siemens PLC
PLC Programming for Pumping and Draining System
Siemens PLC Interview Questions and Answers
Motor ON OFF Logic in PLC
PLC Program – Controls Conveyors ON and OFF Sequence
PLC SCADA Water Pump
PLC Program for Controlling a Water Pump with 3 Power Sources
High-Speed and Fast Counters in PLC
What are High-Speed Counters and Fast Counters in PLC?
Global Data Blocks in PLC
What is a Data Block? Global Data Blocks in PLC
PLC Motor Control Ladder Logic
PLC Program for Star Delta Motor Starter
PLC programming for clothes washing machine automation
LS Electric PLC Program Example: Clothes Washing System
Select Security type Intouch
How to Add Security in InTouch SCADA?
Pneumatic valve operation in sequence mode
Sequential PLC Programming for the Pneumatic Valves
Permanent magnet moving coil instruments (PMMC)
Permanent Magnet Moving Coil Instruments (PMMC)
Change-of-Quantity Flow Measurement
Laws of Thermocouples
DP transmitter Errors
DP Transmitter Calibration Errors
Password Protect Apps and Files
custom metal fabrication
Custom Metal Fabrication Techniques for Quality Machined Parts
GuideLines for Loop Checks
How to Do Loop Checks During Plant Pre-Commissioning
Capacitive Tank Gauges
