Reading: Start Stop of one Motor from the same Push button PLC program
Inst Tools > Blog > PLC Tutorials > Start Stop of one Motor from the same Push button PLC program
Last updated: March 4, 2021 11:32 am
4 Comments
2 Min Read
In some applications, it may be required to use one single push button in order to save inputs or for whatever reason to start and stop the same motor.
Start Stop of one Motor from same Push buttonPLC Program
It is simple, all you need is to acquire an instruction that could register the output status (on or off), and upon the status of the output, it should decide the next action to on or off the output.
Note: The best practice to learn the PLC programming is to start writing the PLC program, take your time before you review the answer.
Download: Tia Portal
Inputs & Outputs:
I0.0: Push-button
Q0.0: Motor
M0.0: Positive Trigger
M0.1: Negative Trigger
Start Stop of one Motor from same Push button PLC program
PLC Program
In this network you can find the SR flip flop where:
If the motor Q0.0 is OFF and the Push-button (PB) I0.0 is pressed for one time, the set value would be energized and sets the output Q0.0 to ON. So the motor will be started.
If the motor Q0.0 is ON and the PB I0.0 is pressed for one time, the reset value would be energized and sets the output Q0.0 to OFF. So the motor will be stopped.
The positive edge detector in the set branch is used to ensure that the press of the I0.0 should be executed for a single scan cycle.
The negative edge detector is to ensure that the reset should not be energized unless the motor is ON.
Author: Karim Ali Anwar
  • PLC Logic Stair-Case wiring
  • InTouch Scada Trends
  • PLC Move Instruction
  • Latching Function of PLC
  • Siemens S7-1200 Simulator
PLC Programming Example on Timers Function Block
Parts of PLC
#18 PLC Best Practices – Store PLC Hard Stop Events from Faults
Retentive ON Delay Timer using PLC
What is Namur Digital Input Card?
4 Comments
  • sai says:
    January 5, 2021 at 12:01 pm
    thank u inst tools. with this blog i learn so many new concepts which are help to reach the real time industrial basis
  • Archimedes says:
    March 10, 2021 at 12:34 pm
    thank you sir for this site!
    All these tutorials are very useful for plc programming. I wish to be able to save them to our PC…
  • Sohel khalfa says:
    September 14, 2021 at 8:11 am
    Start stop puss botton se vfd se motor kese opret kare
  • hamdan firas says:
    March 8, 2022 at 3:49 pm
    good ,but u forgot nc coil before pos edge detector that ensure q0.0 is off
FactoryTalk Studio and SQL Server for Data Logging
Basics of PLC Programming
What is an RTU? – Remote Terminal Unit
How to Download EcoStruxure Machine Expert? Schneider PLC Software
Finding the Best PLC for Your Project – Tips and Tricks
Introduction to PLC – Advantages of PLC
Simulation of Studio 5000 and FactoryTalk View Studio
Difference between PLC and HMI
WinCC data logging
How to Export Data from WinCC Runtime Advanced into Excel using VB Script
PLC Timers with Practical Examples
Omron PLC Timer Example Explained
RSlogix 500 to communicate with Excel
How to Communicate with Excel from RsLinx?
Allen Bradley RSLogix 500 PLC Programming
Relay Motor Logic Circuit
Motor Control Circuits
PLC program for Sorting System by Size Example
PLC Based Product Sorting Machine System – Lift Control
Top PLC Manufacturers
Studio 5000 Define Program or Operator Control in Functional Block Diagram
Studio 5000: Define Program or Operator Control in Functional Block Diagram
Functional Block Diagram PLC Example for Traffic Light System
Air Pressure Regulator cut-away diagram
Air Pressure Regulator Questions
Foundation Fieldbus Signal Conversion Formula
PLC Karnaugh maps
How to Simplify PLC Coding Using Karnaugh Maps?
Analog Electronics Objective Questions – Set 7
Stability in Frequency Domain
The Design Problem
Air Filter Regulator Working Principle Animation
circuit-breaker-working-principle-animation
Circuit Breaker Working Principle Animation
