Reading: Siemens S7 1200 PLC configuration in TIA Portal
Inst Tools > Blog > PLC Tutorials > Siemens S7 1200 PLC configuration in TIA Portal
In this example, we use Siemens S7 1200 PLC and TIA portal software for configuration. For S7-1200 PLC we need TIA portal software for configuration.
Last updated: November 3, 2023 1:59 pm
3 Min Read
This is the PLC Program for the S7-1200 PLC configuration in the TIA portal.
Siemens S7 1200 PLCProblem SolutionPLC Program for the hardware configuration of S7-1200 PLCCreating an S7-1200 CPU
Siemens S7 1200 PLC
Implement the PLC program for S7-1200 PLC configuration in the TIA portal.
Siemens-PLC-configuration-in-TIA-portal
Problem Solution
In this system, we will consider S7-200 PLC and TIA portal software for configuration.
For S7-1200 PLC we need TIA portal software for configuration of hardware.
The SIMATIC S7-1200 system comes in four different models, with CPU 1211C, CPU 1212C, CPU 1214C, and CPU 1215C, that may each be expanded to exactly fit the application requirements.
Here we consider CPU 1214 AC/DC/RLY for hardware configuration.
All data which is generated during the creation of an automation solution is saved in the project file.
The data is stored in the form of objects. Within the project, the objects are arranged in a tree structure.
The project hierarchy is based on the devices and stations along with the configuration data and programs belonging to them.
Following the step, you will create a new project.
Step 1:-  Click “Create new project”.
Step 2:-  Enter a name for your project.
Step 3:-  Click “Create” to create the new project.
plc configuration in tia portal
The project has been created. All data, such as the hardware configuration, the CPU programming and the visualization in HMI, is saved in the project.
Siemens S7 1200 PLC
Open the “Devices & Networks” portal.
Add new device.
Open the “SIMATIC S7-1200” folder.
plc program for s7-1200 plc
Select the CPU.
Create the CPU with a double-click
program for s7-1200 plc configuration
The unspecified CPU is created in the project file.
Then select CPU from the right side “catalog” option, as shown below.
s7-1200 plc configuration in tia
Open the program block and double click to Main [OB1].
This is working environment for create a new project.
Siemens S7 PLC
Note: – Here we have configured only S7-1200 PLC (CPU 1214 ACDCRLY) for explanation purpose however we can configure S7-300 PLC, HMI, drives in TIA portal (Totally Integrated Automation portal) also.
Author: Bhavesh
  • PLC Time Cycle Sequence
  • Water filling and Discharging Process
  • PLC Burglar Alarm Security System
  • Automatic Door Control System
  • Siemens PLC Comparator Logic
Difference Between PNP and NPN Sensors
Best 100 PLC Projects for Final Year Engineering Students
Basic PLC Ladder Programming Example
  • gebremedhinb gwahid says:
    May 22, 2021 at 3:58 am
    its goods and i got very important points
Use of Regions in SCL Language
Wiring in a PLC Control Panel
CW and CCW Operation of Motor from Same Push button
Free Omron PLC Programming Course in HINDI
What are Trends in SCADA?
Distributed IO Sharing Between PLC Systems – Technical Insights
Types of Digital Outputs in PLC
One-Shot Rising and Falling Edge Instructions in Rockwell PLC
SCADA
Top 100+ SCADA Questions
PLC Program for Water filling and Discharging Process
PLC Motor Control Circuit
Motor Trip Logic using PLC Programming
PLC Latched Circuit Example
PLC Latching Function
Functional Block Diagram in PLC for Oil and Water Process
Motor Library in Studio 5000 PLC
Create User-Defined Data Types and Function Blocks in Studio 5000
Overview of Resistor
The Information About Resistor Color Code You Should Know
Thermocouples Problem
Fire burnt Ammonia Converter Thermocouples Problem
Proper Earthing Practices Used for PLC Control Panel
Controllability & Observability
Instrument Calibration Record
How to Create Calibration Records?
Alarm Management Practices
Control Room Alarm Management Practices
Purpose of Flow Ratio Controller
Identify the Purpose of Flow Ratio Controller
Feedback Accelerometer System Objective Questions
