Reading: Siemens PLC Mathematics Instructions
Inst Tools > Blog > PLC Tutorials > Siemens PLC Mathematics Instructions
Siemens PLC Mathematics Instructions : Implement ADD, SUB, MUL, DIV, MOD and NEG instructions in S7-1200 PLC using ladder diagram language.
Last updated: November 3, 2023 3:14 pm
This is Program for Siemens PLC Mathematics Instructions.
Siemens PLC Math InstructionsProblem DiagramSolutionList of Inputs/OutputsPLC Ladder diagram for mathematical instructionsProgram Description
Problem Diagram
Solution
We can use the Add instruction to add the value at input IN1 and the value at input IN2 and query the sum at output OUT (OUT := IN1+IN2).
Subtract instruction is used to subtract the value at input IN2 from the value at input IN1 and query the difference at output OUT (OUT := IN1-IN2).
Multiply instruction is used to multiply the value at input IN1 with the value at input IN2 and query the product at output OUT (OUT := IN1*IN2).
Divide instruction is used to divide the value at input IN1 by the value at input IN2 and query the quotient at output OUT (OUT := IN1/IN2).
We can use the Return remainder of division instruction to divide the value at input IN1 by the value at input IN2 and query the remainder of division at output OUT.
We can use the “Create twos complement” instruction to change the sign of the value at the IN input and query the result at the OUT output. If there is a positive value at input IN, for example, the negative equivalent of this value is sent to output OUT.
M memory
  • MW0 :- “ADD_VALUE 1”
  • MW2 :- “ADD_VALUE 2”
  • MW4 :- “ADD_RESULT”
  • MW6 :- “SUB_VALUE 1”
  • MW8 :- “SUB_VALUE 2”
  • MW10 :- “SUB_RESULT”
  • MW12 :- “MUL_VALUE 1”
  • MW14 :- “MUL_VALUE 2”
  • MW16 :- “MUL_RESULT”
  • MW18 :- “DIV_VALUE 1”
  • MW20 :- “DIV_VALUE 2”
  • MW22 :- “DIV_RESULT”
  • MW24 :- “NEG_VALUE”
  • MW226 :- “NEG_RESULT”
  • MD100 :- “MOD_VALUE 1”
  • MD104 :- “MOD_VALUE 2”
  • MD108 :- “MOD_RESULT”
PLC ADD Instruction
PLC SUB Instruction
PLC MUL Instruction PLC DIV Instruction PLC MOD Instruction PLC NEG Instruction Program Description
In this program we have used Siemens S7-1200 PLC and TIA Portal Software for programming.
Network 1:
The value of MW0 is added to the value of MW2.The result of the addition is stored in the MW4.
Network2:
The value of MW6 is subtracted from the value of MW8.The result of the subtraction is stored in MW10.
Network 3:
The value of operand MW12 is multiplied by the value of MW14. The result of the multiplication is stored in MW16.
Network 4:
The value of operand MW18 is divided by the value of MW20. The division result is stored in MW22.
Network 5:
The value of MD100 is divided by the value of MD104. The remainder of division is stored in operand MD108.
Network 6:
The sign of the value at input MW24 is changed and the result is provided at output MW26.
Author: Bhavesh
  • Conveyor System using PLC
  • PLC Program using Counters
  • Documents in a PLC System
  • Allen Bradley PLC Subroutines
  • PLC Analog and Network I/O
How to Use Encode and Decode Instructions in PLC ?
Sheets, Tags, Elements in Functional Block Diagram of Studio 5000
CODESYS HMI Interface
How to use JUMP Instruction in PLC Ladder Logic?
PLC Program for Ceramic Burning Oven Conveyor System
PLC to PLC Communication using S7 Connection PUT & GET Instructions
How to Protect Siemens PLC using Password?
PID Block in RSLogix 500
How to use Sub Routines with Allen Bradley PLC
PLC Program to Separate Different Size Objects
What is Seal-in Circuit ?
Types of PLC Memory
Identify the Problem in the PLC Program
Motor Trip Logic using PLC Programming
Top 100 PLC Projects List
Simple PLC example Hardware configurations
Omron PLC washing machine automation
Omron PLC Logic for Washing Machine Automation
Gas Turbine Temperature Control using Siemens Tia Portal
How to Delay a Sensor Signal in PLC?
SCADA Interview Questions
Electrical Cabinet Air Conditioner
Electrical Cabinet Air Conditioner – Enclosure Cooling, Maintenance
Reformer Fan Bearing Change Times cut by 90%
Sensors and Transducers Classification
What is WHCP?
Root Locus in Control Systems
Liquid management using PLC programming
PLC Programming for Loss in Weight Liquid Systems
PLC Latching circuit Animation
Site Commissioning Steps for PLC Programmers
Electronic Devices & Circuits Quiz – Set 8
